[STM32F4] STM32F446 nucleo板CAN1通信配置不成功
5365|77
 楼主| liuzaiy 发表于 2021-2-9 23:11 | 显示全部楼层 |阅读模式
使用CUBE MX配置CAN1接口,参考官方库资料和网友分享资料,不管怎样在连接USB CAN卡的时候,CAN卡都不能识别到配置好的波特率,请教有没有人遇到此类问题
tian111 发表于 2021-2-9 23:13 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| liuzaiy 发表于 2021-2-9 23:15 | 显示全部楼层
主要代码如下:
static void MX_CAN1_Init(void)
  /* USER CODE BEGIN CAN1_Init 0 */
  /* USER CODE END CAN1_Init 0 */
  /* USER CODE BEGIN CAN1_Init 1 */
  /* USER CODE END CAN1_Init 1 */
  hcan1.Instance = CAN1;
  hcan1.Init.Prescaler = 5;
  hcan1.Init.Mode = CAN_MODE_NORMAL;
  hcan1.Init.SyncJumpWidth = CAN_SJW_1TQ;
  hcan1.Init.TimeSeg1 = CAN_BS1_6TQ;
  hcan1.Init.TimeSeg2 = CAN_BS2_2TQ;
  hcan1.Init.TimeTriggeredMode = DISABLE;
  hcan1.Init.AutoBusOff = DISABLE;
  hcan1.Init.AutoWakeUp = DISABLE;
  hcan1.Init.AutoRetransmission = ENABLE;
  hcan1.Init.ReceiveFifoLocked = DISABLE;
  hcan1.Init.TransmitFifoPriority = DISABLE;
  if (HAL_CAN_Init(&hcan1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN CAN1_Init 2 */
        CAN_User_Init(&hcan1);
  /* USER CODE END CAN1_Init 2 */
void CAN_User_Init(CAN_HandleTypeDef *hcan)
        CAN_FilterTypeDef  sFilterConfig;
//        HAL_StatusTypeDef  HAL_Status;
        sFilterConfig.FilterBank = 0;
        sFilterConfig.FilterMode =  CAN_FILTERMODE_IDMASK;
        sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT;
        sFilterConfig.FilterIdHigh = CAN_CONFIG_INIT.CAN_Rece_ID<<5;
        sFilterConfig.FilterIdLow  = 0 | CAN_ID_STD;
//  sFilterConfig.FilterIdHigh = 0;
//        sFilterConfig.FilterIdLow  = 0;
        sFilterConfig.FilterMaskIdHigh = 0;
        sFilterConfig.FilterMaskIdLow  = 0;
        sFilterConfig.FilterFIFOAssignment = CAN_RX_FIFO0;
        sFilterConfig.FilterActivation = ENABLE;
        sFilterConfig.SlaveStartFilterBank  = 0;
  if (HAL_CAN_ConfigFilter(&hcan1, &sFilterConfig) != HAL_OK)
                Error_Handler();
        if (HAL_CAN_Start(&hcan1) != HAL_OK )
     Error_Handler();
//  if(HAL_CAN_ActivateNotification(&hcan1, CAN_IT_RX_FIFO0_MSG_PENDING | CAN_IT_TX_MAILBOX_EMPTY) != HAL_OK)
        if(HAL_CAN_ActivateNotification(&hcan1, CAN_IT_RX_FIFO0_MSG_PENDING) != HAL_OK)
    Error_Handler();
kangzj 发表于 2021-2-9 23:20 | 显示全部楼层
先测试回环,看下可以通讯不?
huanghuac 发表于 2021-2-9 23:23 | 显示全部楼层
然后再切换成正常模式,连接两个板卡的CAN口
spark周 发表于 2021-2-9 23:26 | 显示全部楼层
注意 CAN_H  -> CAN_H   CAN_L  -> CAN_L
huanghuac 发表于 2021-2-9 23:28 | 显示全部楼层
官方有没有这个例子,直接跑例子试试。
yufe 发表于 2021-2-9 23:34 | 显示全部楼层
硬件没问题吧
zhenykun 发表于 2021-2-9 23:36 | 显示全部楼层
cube有配套的软件啊 对nucleo板子
yufe 发表于 2021-2-9 23:38 | 显示全部楼层
加匹配电阻了没有呀
jlyuan 发表于 2021-2-9 23:40 | 显示全部楼层
还需要有接收方的
songqian17 发表于 2021-2-9 23:45 | 显示全部楼层
接收方用的什么
tian111 发表于 2021-2-9 23:47 | 显示全部楼层
楼主需要两块对接吧
 楼主| liuzaiy 发表于 2021-2-9 23:49 | 显示全部楼层
用示波器卡卡看
 楼主| liuzaiy 发表于 2021-2-9 23:51 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
八层楼 发表于 2021-3-2 23:32 | 显示全部楼层
估计是can有问题
观海 发表于 2021-3-2 23:34 | 显示全部楼层
自己做的usbcan?
guanjiaer 发表于 2021-3-2 23:39 | 显示全部楼层
can非常不好调试
heimaojingzhang 发表于 2021-3-2 23:41 | 显示全部楼层
需要加终端电阻
keaibukelian 发表于 2021-3-2 23:43 | 显示全部楼层
双方都是usb can吗
