为什么按下S5后定时器没有打开去掉nowshidu=dat_rd1*20就可以了
3356|1
 楼主| wzj20020806 发表于 2021-2-16 15:38 | 显示全部楼层 |阅读模式
#include<STC15F2K60S2.H>
#include"ds1302.h"
#include"iic.h"
sbit S7=P3^0;
sbit S6=P3^1;
sbit S5=P3^2;
sbit S4=P3^3;
unsigned char dat_rd2;
unsigned char kaiguan=0;
unsigned char shidu=50; //初始湿度
unsigned char nowshidu; //当前湿度
unsigned char code table[]={0xc0,0xf9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
0x80,0x90,0x88,0x83,0xA7,0xA1,0x86,0x8E,0xbf,0x7f};
unsigned char write[]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c};
unsigned char read[]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};
unsigned char Time[]={0x16,0x30,0x08,0x02,0x16,0x02,0x21};
void delayms(unsigned char x)
        unsigned char i;
        while(x--)
                for(i=0;i<113;i++);
void select (unsigned char n)
        switch(n)
                case 4:
                        P2=(P2&0x1f)|0x80;
                break;
    case 5:
                        P2=(P2&0x1f)|0xa0;
                break;
                case 6:
                        P2=(P2&0x1f)|0xc0;
                break;
                case 7:
                        P2=(P2&0x1f)|0xe0;
                break;
void guanbi()
        select(5);
        P0=0x00;
        select(4);
        P0=0xff;
void DS1302_write()
        unsigned char i;
        Ds1302_Single_Byte_Write(0x8e,0x00);
        for(i=0;i<7;i++)
                Ds1302_Single_Byte_Write(write[i],Time[i]);
        Ds1302_Single_Byte_Write(0x8e,0x80);
void DS1302_read()
        unsigned char i;
        for(i=0;i<7;i++)
                Time[i]=Ds1302_Single_Byte_Read(read[i]);
void read_rd2()
  IIC_Start();
  IIC_SendByte(0x90);
  IIC_WaitAck();
  IIC_SendByte(0x03);
  IIC_WaitAck();
  IIC_Start();
  IIC_SendByte(0x91);
  IIC_WaitAck();
  dat_rd2=IIC_RecByte();
  IIC_WaitAck();
        IIC_Ack(0);
  IIC_Stop();
void shuma(unsigned char pos,unsigned char date)
        select(6);
        P0=0x01<<pos;
        select(7);
        P0=date;
void dis ()
        nowshidu=dat_rd2*20;     //显示当前湿度
        shuma(0,table[Time[2]/16]);
        delayms(2);
        shuma(1,table[Time[2]%16]);
        delayms(2);
        shuma(2,table[16]);
        delayms(2);
        shuma(3,table[Time[1]/16]);
        delayms(2);
        shuma(4,table[Time[1]%16]);
        delayms(2);
        shuma(5,0xff);
        delayms(2);
        shuma(6,table[nowshidu/10]);
        delayms(2);
        shuma(7,table[nowshidu%10]);
        delayms(2);
void shezi ()
          shuma(0,table[16]);  //进入湿度设置界面
                delayms(2);
                shuma(1,table[16]);
                delayms(2);
                shuma(2,0xff);
                delayms(2);
                shuma(3,0xff);
                delayms(2);
                shuma(4,0xff);
                delayms(2);
                shuma(5,0xff);
                delayms(2);
                shuma(6,table[shidu/10]);
                delayms(2);
                shuma(7,table[shidu%10]);
                delayms(2);
void offall ()
        select(6);
        P0=0xff;
        select(7);
        P0=0xff;
void INT()
        TMOD=0x01;
        TH0=(65535-50000)/256;
        TL0=(65535-50000)%256;
        EA=1;
        ET0=1;
unsigned char count=0;
void serviceINT() interrupt 1
        count++;
        if(count==20)
                nowshidu++;
                count=0;
        if(nowshidu==99)
                TR0=~TR0;
unsigned char stat=0;
void scan ()
        if(S7==0)
                delayms(10);
                if(S7==0)
                        if(stat==0)
                                stat=1; //自动模式
                                select(4);
                                P0=0xfe;
                        else if(stat==1)
                                stat=0; //手动模式
                                select(4);
                                P0=0xfd;
                while(S7==0)
                        dis();
                if(S6==0)
                        delayms(10);
                        if(S6==0)
                                if(stat==0)
                                        if(nowshidu>shidu)
                                                select(5);
                                                P0=0x40;
                                        else if(nowshidu<shidu)
                                                select(5);
                                                P0=0x00;
                                else if(stat==1)
                                        offall ();
                                        while(kaiguan==0)
                                                shezi ();
                                                if(S6==0)
                                                        delayms(10);
                                                        if(S6==0)
        kaiguan=1;
            if(S5==0||S4==0)
                                                        delayms(10);
                                                        if(S5==0||S4==0)
        kaiguan==2;
                                        kaiguan=0;
                if(S5==0)
                                delayms(10);
                                if(S5==0)
                                        if(stat==0)
                                                select(5);
                                                P0=0x10;
                                                TR0=1;
                                        else if(stat==1)
                                                shidu=shidu++;
                                if(S4==0)
                                delayms(10);
                                if(S4==0)
                                        if(stat==0)
                                                select(5);
                                                P0=0x00;
                                                TR0=0;
                                        else if(stat==1)
                                                shidu=shidu--;
void main()
        guanbi();
        INT();
        DS1302_write();
        while(1)
                DS1302_read();
                read_rd2();
                dis ();
                scan ();
MagicSquare834 发表于 2021-3-27 16:00 | 显示全部楼层
你定时器初始化的时候都没开怎么跑?搜索
复制
