[嵌入式linux] RK3399系统刷进去但启动失败请大家帮看看
1064|3
 楼主| robertwang126 发表于 2021-2-20 23:11 | 显示全部楼层 |阅读模式
DDR Version 1.24 20191016
In
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0xD8
MR1=0x0
MR2=0x0
MR3=0x0
MR4=0x3
MR5=0x3
MR6=0x0
MR7=0x0
MR8=0x1F
MR9=0x0
MR10=0x0
MR11=0x0
MR12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
MR16=0x0
CS = 1
MR0=0xD8
MR1=0x0
MR2=0x0
MR3=0x0
MR4=0x3
MR5=0x3
MR6=0x0
MR7=0x0
MR8=0x1F
MR9=0x0
MR10=0x0
MR11=0x0
MR12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
MR16=0x0
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0xD8
MR1=0x0
MR2=0x0
MR3=0x0
MR4=0x3
MR5=0x3
MR6=0x0
MR7=0x0
MR8=0x1F
MR9=0x0
MR10=0x0
MR11=0x0
MR12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
MR16=0x0
CS = 1
MR0=0xD8
MR1=0x0
MR2=0x0
MR3=0x0
MR4=0x3
MR5=0x3
MR6=0x0
MR7=0x0
MR8=0x1F
MR9=0x0
MR10=0x0
MR11=0x0
MR12=0x0
MR13=0x0
MR14=0x0
MR15=0x0
MR16=0x0
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD
OUT
Boot1 Release Time: Dec 24 2019 18:00:26, version: 1.24
CPUId = 0x0
ChipType = 0x10, 334
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 68260
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part:  0, name:            uboot, start:0x4000, size:0x2000
GPT part:  1, name:            trust, start:0x6000, size:0x2000
GPT part:  2, name:             misc, start:0x8000, size:0x2000
GPT part:  3, name:             boot, start:0xa000, size:0x10000
GPT part:  4, name:         recovery, start:0x1a000, size:0x10000
GPT part:  5, name:           backup, start:0x2a000, size:0x10000
GPT part:  6, name:           rootfs, start:0x5a000, size:0x60b200
GPT part:  7, name:         userdata, start:0x665200, size:0x16b9ddf
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xd4748
RunBL31 0x40000 @ 108756 us
NOTICE:  BL31: v1.3(release):57824cc
NOTICE:  BL31: Built : 10:59:12, Jan  6 2020
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-230-g6c76e8a9 #191 Mon Nov 18 07:00:24 UTC 2019 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-03780-geb208cd1c6 (Jun 17 2020 - 15:41:48 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM:  3.8 GiB
Sysmem: init
Relocation Offset: f5bf0000, fdt: f3de4300
Using default environment
dwmmc@fe320000: 1, sdhci@fe330000: 0
sdhci_transfer_data: Transfer data timeout
@hxzzzc125 :AndroidTool  发表于 2021-3-2 20:18
从gea-8319这个设备里拆出来的
