[应用相关] BK4811程序问题
572|0
 楼主| jcky001 发表于 2021-2-23 15:56 | 显示全部楼层 |阅读模式
void BK_Set_Freq(UINT8 dir,  double frequency) //frequencyP 这个参数为什么没有使用
        UINT16         val = 0;
        if(DIR_TX==dir)
                BK_RampDown_Enable();
        if((chan_num == 1)||(chan_num == 2))  //chan_num 这个变量没看到赋值,怎么做判断
                val = BK_Read_Reg(126);
                val |= 0x0010;
                BK_Write_Reg(126, val);
                if(chan_num == 1)
                        BK_Write_Reg(127, 0x4719);
                else
                        BK_Write_Reg(127, 0x1095);
        if((chan_num == 3)||(chan_num == 4)||(chan_num == 5))
                val &= 0xffef;
                if(chan_num == 3)
                        BK_Write_Reg(127, 0xDa11);
                else if(chan_num == 4)
                        BK_Write_Reg(127, 0xA38D);
                        else
                        BK_Write_Reg(127, 0x6D08);
        BK_Write_Reg(113, freq_h);//freq_h这个也没见给赋值
        BK_Write_Reg(114, freq_l);//freq_l这个也没见给赋值
        BK_SPI_trigger();
        g_reg0_15_buff[3]&=0x1FFF;
        if(chan_num == 1)
                g_reg0_15_buff[3]|=0x8000;
        else if(chan_num == 2)
                g_reg0_15_buff[3]|=0x6000;
        else if(chan_num == 3)
                g_reg0_15_buff[3]|=0x4000;
                g_reg0_15_buff[3]|=0x2000;
        else if(chan_num == 5)
                g_reg0_15_buff[3]|=0x0000;
        BK_Write_Reg(3, g_reg0_15_buff[3]);
        delay_ms(15);
        if(DIR_TX==dir)
                BK_RampUp_Enable();
求解 谢谢
