Python 练习实例24
1226|0
 楼主| cooldog123pp 发表于 2021-2-26 16:01 | 显示全部楼层 |阅读模式
题目:有一分数序列:2/1,3/2,5/3,8/5,13/8,21/13...求出这个数列的前20项之和。
程序分析:请抓住分子与分母的变化规律。
程序源代码:
方法一:
  1. #!/usr/bin/python
  2. # -*- coding: UTF-8 -*-
  3. a = 2.0
  4. b = 1.0
  5. s = 0
  6. for n in range(1,21):
  7.     s += a / b
  8.     t = a
  9.     a = a + b
  10.     b = t
  11. print (s)
方法二:
  3. a = 2.0
  4. b = 1.0
  5. s = 0.0
  7.     s += a / b
  8.     b,a = a , a + b
  9. print (s)
  10. s = 0.0
  11. for n in range(1,21):
  12.     s += a / b
  13.     b,a = a , a + b
  14. print (s)
方法三:
  3. a = 2.0
  4. b = 1.0
  5. l = []
  6. l.append(a / b)
  7. for n in range(1,20):
  8.     b,a = a,a + b
  9.     l.append(a / b)
  10. print reduce(lambda x,y: x + y,l)
实例(Python 3.x)
  2. from functools import reduce
  3. a = 2.0
  4. b = 1.0
  5. l = []
  6. l.append(a / b)
  8.     b,a = a,a + b
  9.     l.append(a / b)
  10. print (reduce(lambda x,y: x + y,l))
以上实例输出结果为:
32.6602607986
