[STM32F1] ADC采集
1199|27
 楼主| wenfen 发表于 2021-3-4 17:32 | 显示全部楼层 |阅读模式
数据只有0和4095,是什么问题?
chuxh 发表于 2021-3-4 17:36 | 显示全部楼层
数据只有0和4095,是什么问题?
 楼主| wenfen 发表于 2021-3-4 17:40 | 显示全部楼层
STM32F103VET6,ADC+DMA采集,电压是16.8V电池电阻6分压的电压
接上电池AD数据就是4095,不接就是0,IO口量过电压是2点多伏
程序在RET6上正常使用,到VET6上由IO口由C口换到了PB1,仔细检查过很多遍了
估计可能是什么原因?帮我指点下方向我再检查
juventus9554 发表于 2021-3-4 17:42 | 显示全部楼层
程序的问题,再检查下你的程序。
stly 发表于 2021-3-4 17:44 | 显示全部楼层
ADC+DMA 我也遇到了这个现象读回来的数不是0就是4095或者1023,2047这几种。
 楼主| wenfen 发表于 2021-3-4 17:47 | 显示全部楼层
后来怎么解决的?
ipman 发表于 2021-3-4 17:49 | 显示全部楼层
检查是否IO口设为AD了,ADC时钟是否打开等等,这是低级错误
 楼主| wenfen 发表于 2021-3-4 17:55 | 显示全部楼层
初始化程序很简单,用的引脚是PA0,PA1和PB1
void  Adc_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB |RCC_APB2Periph_ADC1,ENABLE );
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        ADC_DeInit(ADC1);
            ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
            ADC_InitStructure.ADC_ScanConvMode = ENABLE;//DISABLE;
            ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
            ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
            ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
            ADC_InitStructure.ADC_NbrOfChannel = 5;
            ADC_Init(ADC1, &ADC_InitStructure);
          ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
           ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
           ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 3, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 4, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_17, 5, ADC_SampleTime_239Cycles5 );
            ADC_Cmd(ADC1, ENABLE);
            ADC_DMACmd(ADC1, ENABLE);
        ADC_TempSensorVrefintCmd(ENABLE);
            ADC_ResetCalibration(ADC1);
            while(ADC_GetResetCalibrationStatus(ADC1));
            ADC_StartCalibration(ADC1);
            while(ADC_GetCalibrationStatus(ADC1));
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
void DMA_Config(void)
    DMA_InitTypeDef DMA_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = 5;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    DMA_Cmd(DMA1_Channel1, ENABLE);
dingy 发表于 2021-3-4 17:58 | 显示全部楼层
换了IO,通道也要换下;
wyjie 发表于 2021-3-4 18:00 | 显示全部楼层
还没解决。因为我这是用的STM32 linux系统,ADC驱动是linux里的,跟STM32的固件库完全不同。
pengf 发表于 2021-3-4 18:03 | 显示全部楼层
看一下示例代码。再改改就行了
zhuhuis 发表于 2021-3-4 18:06 | 显示全部楼层
外部电平问题或者引脚配置问题
renyaq 发表于 2021-3-4 18:10 | 显示全部楼层
直接接地看看
ousj 发表于 2021-3-4 18:12 | 显示全部楼层
程序问题吧
houcs 发表于 2021-3-4 18:15 | 显示全部楼层
寄存器怎么设置的
wuhany 发表于 2021-3-4 18:18 | 显示全部楼层
是不是寄存器设置有问题啊
午夜粪车 发表于 2021-3-4 18:21 | 显示全部楼层
也有可能是你读错寄存器了
jiajs 发表于 2021-3-4 18:23 | 显示全部楼层
应该是程序问题
wyjie 发表于 2021-3-4 18:32 | 显示全部楼层
硬件没毛病的话那就是软件的问题喽
happy_10 发表于 2021-3-4 18:36 | 显示全部楼层
应该就是你设置有问题
