GD32F150G8 的USART1 为什么没法接收?
818|1
 楼主| faithswss 发表于 2021-3-5 09:36 | 显示全部楼层 |阅读模式
void rs422_uart_init(uint32_t baudrate, uint16_t data_bits,uint16_t parity, uint16_t stopbits)
        rcu_periph_clock_enable(AS32_GPIO_RX_RCC);
        rcu_periph_clock_enable(AS32_GPIO_TX_RCC);
        rcu_periph_clock_enable(AS32_UART_RCC);
        /* connect port to USARTx_Tx */
    gpio_af_set(AS32_GPIO_TX_PORT, AS32_UART_AF, AS32_GPIO_TX_PIN);
    /* connect port to USARTx_Rx */
    gpio_af_set(AS32_GPIO_RX_PORT, AS32_UART_AF, AS32_GPIO_RX_PIN);
    /* configure USART Tx as alternate function push-pull */
    gpio_mode_set(AS32_GPIO_TX_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, AS32_GPIO_TX_PIN);
    gpio_output_options_set(AS32_GPIO_TX_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, AS32_GPIO_TX_PIN);
    /* configure USART Rx as alternate function push-pull */
    gpio_mode_set(AS32_GPIO_RX_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP, AS32_GPIO_RX_PIN);
    gpio_output_options_set(AS32_GPIO_RX_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, AS32_GPIO_RX_PIN);
        usart_deinit(AS32_UART);
    usart_baudrate_set(AS32_UART, baudrate);
    usart_transmit_config(AS32_UART, USART_TRANSMIT_ENABLE);
        //nvic_irq_enable(AS32_UART_IRQ, 1, 1);
#ifdef AS32_DIR_PORT
        rcu_periph_clock_enable(AS32_DIR_RCC);
        gpio_output_options_set(AS32_DIR_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, AS32_DIR_PIN);
        gpio_mode_set(AS32_DIR_PORT, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, AS32_DIR_PIN);
        gpio_bit_reset(AS32_DIR_PORT, AS32_DIR_PIN);
#endif
        usart_interrupt_flag_clear(RS485_UART,USART_INT_FLAG_RBNE_ORERR);
        usart_interrupt_enable(AS32_UART,USART_INT_RBNE);
        usart_receive_config(AS32_UART, USART_RECEIVE_ENABLE);
        usart_enable(AS32_UART);
        while(usart_flag_get(AS32_UART,USART_FLAG_REA) != SET);
#define AS32_UART                        USART1
#define AS32_UART_IRQ                USART1_IRQn
#define AS32_UART_RCC                RCU_USART1
#define AS32_UART_AF                GPIO_AF_1
#define AS32_GPIO_TX_RCC        RCU_GPIOA
#define AS32_GPIO_TX_PORT        GPIOA
#define AS32_GPIO_TX_PIN        GPIO_PIN_2
#define AS32_GPIO_RX_RCC        RCU_GPIOA
#define AS32_GPIO_RX_PORT        GPIOA
#define AS32_GPIO_RX_PIN        GPIO_PIN_3
本来想好好支持一下国产的, 难道真的还是要放弃?
〽️〽️〽️ 发表于 2021-3-5 21:44 | 显示全部楼层
我用的也是GD32F150G8 串口DMA  串口空闲方式   收发 都好使,没问题的。
你可以GD官网参考下,GD32F1X0那个 库3.1.0,里面有demo的。
