FPGA程序,不能正确输出,各位帮忙看下
1238|2
 楼主| fengyu2513 发表于 2021-3-5 14:08 | 显示全部楼层 |阅读模式
我编写了两个文件,配置了输出口,,LASER_PWM  始终输出不了波形,请问下,这个是什么原因呀?modesiem仿真是有波形输出的//////////////-------PWM.V   文件
`timescale 1 ns / 1 ps
module pwm(
        input rsn,
        input clk,
        input [15:0]pwm_counter,
        input [15:0]pwm_duty,
        output pwm_out
//reg[15:0]pwm_counter;
//reg [15:0]pwm_duty;
reg [15:0]counter=16'd0;
reg pwm_out_r;
always@(posedge clk or negedge rsn)
        //begin
                if(!rsn)
                        begin
                                counter <= 16'd0;
                        end
                else
                        begin
                                if(counter >= pwm_counter)counter <= 16'd0;
                                else counter <= counter + 1'd1;
                        end
//        end
                if(!rsn)
                        begin
                                pwm_out_r <= 1'd0;
                        end
                else if(counter>=pwm_duty)
                                pwm_out_r<=1'b0;
                        else
                                pwm_out_r<=1'b1;
//wire                 pwm_out;
assign pwm_out = pwm_out_r;//((counter > pwm_duty) ? 1'd0 : 1'd1);
endmodule
//////   top_indepen.v                文件
//-------------------------Timescale----------------------------//
//--------------------FSMC_SIG---------------------//
module FSMC_INDEP(
        FPGA_CLK,        //鏉堟挸鍙嗛弶鑳祰閺呰埖灏烥PGA_CLK,25M
        FPGA_LEDR,
        FPGA_LEDG,
        FPGA_LEDB,
        WR,                        //FSMC閸愭瑤淇婇崣
        RD,                        //FSMC鐠囪淇婇崣
        CS0,                        //FSMC閻楀洭鈧
        A,                                //FSMC閸︽澘**冮幀鑽ゅ殠
        DB,                        //FSMC閺佺増宓侀幀鑽ゅ殠
        NADV,                        //FSMC閻ㄥ嚞ADV
        //LASER PWM
        LASER_PWM,
        //interpn_exti
        Interp_ex,
        testclk,
        testclk_100,
        testclk_50,
        FPGA_KEY
        input FPGA_KEY;
        input FPGA_CLK,NADV;
        input WR,RD,CS0;
        inout [15:0]DB;
        input [24:16]A;
        output FPGA_LEDB,FPGA_LEDG,FPGA_LEDR;
        assign FPGA_LEDR = 1'd1;
        assign FPGA_LEDG = 1'd0;
        assign FPGA_LEDB = 1'd1;
        output LASER_PWM;
        output  Interp_ex,testclk,testclk_100,testclk_50;
//-------------------------MY_PLL-------------------------------//
        wire PLL_100M;
        wire PLL_8M;
        wire PLL_50M;
        wire PLL_12_5M;
        reg LaserCtrl1;
        reg [15:0] dbPower1;//閸旂喓宸 閸楃姷鈹栧В
        reg [15:0]dbQFreq1;//妫版垹宸
        reg [15:0]counter;
        initial
        begin
                dbQFreq1 <= 16'd106;
                dbPower1 <= 16'd53;
                LaserCtrl1 <= 1'd1;
        end
        MY_PLL                                 U1(
        .inclk0(FPGA_CLK),
        .c0(PLL_100M),
        .c1(PLL_50M),
        .c2(PLL_8M),
        .c3(PLL_12_5M)
//------------------------RST_Ctrl-----------------------------//
        wire RST_n;
        RST_Ctrl                                U2(
        .FPGA_CLK(FPGA_CLK),
        .RST_n(RST_n)
        );        //娓氬瀵睷ST_Ctrl濡€虫健,鏉堟挸鍤崗銊ョ湰婢跺秳缍呮穱鈥冲娇RST_n
pwm  U5(
                .rsn(RST_n),
                .clk(PLL_8M),
                .pwm_counter(dbQFreq1),
                .pwm_duty(dbPower1),//閸旂喓宸
                .pwm_out(LASER_PWM)
endmodule
 楼主| fengyu2513 发表于 2021-3-5 14:09 | 显示全部楼层
IO配置是正确的 这点可以保证
GavinZ 发表于 2021-3-6 09:35 | 显示全部楼层
simulation 都过了,就用chipscope看一下就知道问题了。
