PADS 报错怎么回事,请大家帮忙看看,谢谢!
6575|1
 楼主| dc42733255 发表于 2012-2-20 16:00 | 显示全部楼层 |阅读模式
我看了原理图没有发现错误,以下的网络都是我删掉不要的网络,为什么还会报错,不解!
** ECO In Report **
Sat Feb 20 14:19:00 2021
Input  File : D:\PADS projects\eco2pcb.eco
Current Job : HJ-80D21C-MB-V0.0.0_blz3.pcb
Line 270 , Section *DEL_ATTRIBUTE*
"Cost"
* WARNING: Processing command to delete attribute "Cost" from Component U1.
*          The attribute is also inherited from Decal SOP-28.
*          The change is not fully reconciled for cases where the schematic
*          does not support hierarchical attributes.
Line 376 , Section *DELETE_GENERAL_RULES*
HIERARCHY_OBJECT NET:L+12V
* Error in object name
Line 377 , Section *DELETE_GENERAL_RULES*
HIERARCHY_OBJECT NET:16V
Line 379 , Section *DELETE_GENERAL_RULES*
HIERARCHY_OBJECT NET:L16V
Line 380 , Section *DELETE_GENERAL_RULES*
HIERARCHY_OBJECT NET:LVIDEO
Line 382 , Section *DELETE_GENERAL_RULES*
HIERARCHY_OBJECT NET:LVGND
* Warning: deleting single-pin signal T_CTRL
诚莫IC 发表于 2012-3-23 22:33 | 显示全部楼层
我也碰到过这类问题,我一般都没管它,不影响LAYOUT的
