2812软仿真问题
3028|0
 楼主| jiajialovefei 发表于 2012-2-21 17:11 | 显示全部楼层 |阅读模式
Error: Can't write to data memory 0x801, check memory config [-2184]
Can't Run Target CPU: Can't write to data memory 0x803, check memory config [-2184]
Can't Run Target CPU: Can't write to data memory 0x805, check memory config [-2184] 这是怎么回事 我用软件仿真时出现了此种错误  还请高手帮忙,谢谢您
