有关“带有存储器功能的数字温度计”的问题
1751|2
 楼主| newstarman 发表于 2012-2-22 21:29 | 显示全部楼层 |阅读模式
这篇带有存储器功能的数字温度计程序(限篇幅,部分定义删了)其它好象能懂,就是红色部分不太明白,为什么要连续赋给*p和*p+1相同的值i_receive(),并且result=temperdata[0]调用时还要向右移3位,然后套入dotcode[]数组中赋值给
displaybuffer数组前两组,这几个问题不知如何分析。我水平一般,帮我分析仔细点好吗?拜托。。。
#include <AT89X52.H>
#include <INTRINS.H>
unsigned char code displaybit[]={0xfe,0xfd,0xfb,0xf7,
0xef,0xdf,0xbf,0x7f};
unsigned char code displaycode[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00};
unsigned char code dotcode[32]={0,3,6,9,12,16,19,22,
25,28,31,34,38,41,44,48,
50,53,56,59,63,66,69,72,
75,78,81,84,88,91,94,97};
sbit SDA=P1^6;
sbit SCL=P1^7;
unsigned char displaybuffer[8]={0,1,2,3,4,5,6,7};
void delay(void)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
void delay10ms(void)
unsigned int i;
for(i=0;i<1000;i++)
delay();
void i_start(void)
SCL=1;
delay();
SDA=0;
delay();
SCL=0;
delay();
void i_stop(void)
SDA=0;
delay();
SCL=1;
delay();
SDA=1;
delay();
SCL=0;
delay();
void i_init(void)
SCL=0;
i_stop();
void i_ack(void)
SDA=0;
i_clock();
SDA=1;
bit i_clock(void)
bit sample;
SCL=1;
delay();
sample=SDA;
_nop_();
_nop_();
SCL=0;
delay();
return(sample);
bit i_send(unsigned char i_data)
unsigned char i;
for(i=0;i<8;i++)
SDA=(bit)(i_data & 0x80);
i_data=i_data<<1;
i_clock();
SDA=1;
return(~i_clock());
unsigned char i_receive(void)
unsigned char i_data=0;
unsigned char i;
for(i=0;i<8;i++)
i_data*=2;
if(i_clock()) i_data++;
return(i_data);
bit start_temperature_T(void)
i_start();
if(i_send(0x90))
if(i_send(0xee))
i_stop();
delay();
return(1);
else
i_stop();
delay();
return(0);
else
i_stop();
delay();
return(0);
bit read_temperature_T(unsigned char *p)
i_start();
if(i_send(0x90))
if(i_send(0xaa))
i_start();
if(i_send(0x91))
*(p+1)=i_receive();
i_ack();
*p=i_receive();
i_stop();
delay();
return(1);
else
i_stop();
delay();
return(0);
else
i_stop();
delay();
return(0);
else
i_stop();
delay();
return(0);
void main(void)
P1=0xff;
timecount=0;
displaycount=0;
TMOD=0x21;
TH1=0x06;
TL1=0x06;
TR1=1;
ET1=1;
ET0=1;
EA=1;
if(start_temperature_T())
//向DS1624发送启动A/D温度转换命令,成功则启动T0定时1s。
secondflag=0;
secondcount=0;
TH0=55536/256;
TL0=55536%256;
TR0=1;
while(1)
if(secondflag==1)
secondflag=0;
TR0=0;
if(read_temperature_T(temperdata))
//T0定时1s时间到,读取DS1624的温度值
for(x=0;x<8;x++)
displaybuffer[x]=16;
x=2;
result=temperdata[1];
//将读取的温度值进行数据处理,并送到显示缓冲区
while(result/10)
displaybuffer[x]=result%10;
result=result/10;
x++;
displaybuffer[x]=result;
result=temperdata[0];
result=result>>3;
displaybuffer[0]=(dotcode[result])%10;
displaybuffer[1]=(dotcode[result])/10;
//温度值数据处理完毕,重新启动DS1624开始温度转换
secondflag=0;
secondcount=0;
TH0=55536/256;
TL0=55536%256;
TR0=1;
void t0(void) interrupt 1 using 0
//T0用于定时1s时间到
secondcount++;
if(secondcount==100)
secondcount=0;
secondflag=1;
TH0=55536/256;
TL0=55536%256;
void t1(void) interrupt 3 using 0
//T1定时1ms用数码管的动态刷新
timecount++;
if(timecount==4)
//T1定时1ms到
timecount=0;
if (displaycount==5)
P0=(displaycode[displaybuffer[7-displaycount]] | 0x80);
//在该位同时还要显示小数点
else
P0=displaycode[displaybuffer[7-displaycount]];
P2=displaybit[displaycount];
displaycount++;
if(displaycount==8)
displaycount=0;
yewuyi 发表于 2012-2-23 11:35 | 显示全部楼层
不知道LZ想问什么?
赋值就是为了把那个值保存下来啊。
原野之狼 发表于 2012-2-23 11:44 | 显示全部楼层
第一个问题:这是读取数据的交互过程,一个字节一个字节的读取。
第二个问题:分离数据用于显示。
