谁知道dotcode数组啥意思
2216|2
newstarman|  楼主 | 2012-2-24 21:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
(部分定义省略)我想知道在这个程序中dotcode数组是什么意思,据我猜测是图形转化代码,另外对为何对result向右移3位不是很理解,也帮忙告知一下好吗?拜托诸位。。。。。
#include <INTRINS.H>
unsigned char code displaybit[]={0xfe,0xfd,0xfb,0xf7,
0xef,0xdf,0xbf,0x7f};
unsigned char code displaycode[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00};
unsigned char code dotcode[32]={0,3,6,9,12,16,19,22,
25,28,31,34,38,41,44,48,
50,53,56,59,63,66,69,72,
75,78,81,84,88,91,94,97};
void delay(void)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
void delay10ms(void)
unsigned int i;
for(i=0;i<1000;i++)
delay();
void i_start(void)
SCL=1;
delay();
SDA=0;
delay();
SCL=0;
delay();
void i_stop(void)
SDA=0;
delay();
SCL=1;
delay();
SDA=1;
delay();
SCL=0;
delay();
void i_init(void)
SCL=0;
i_stop();
void i_ack(void)
SDA=0;
i_clock();
SDA=1;
bit i_clock(void)
bit sample;
SCL=1;
delay();
sample=SDA;
_nop_();
_nop_();
SCL=0;
delay();
return(sample);
bit i_send(unsigned char i_data)
unsigned char i;
for(i=0;i<8;i++)
SDA=(bit)(i_data & 0x80);
i_data=i_data<<1;
i_clock();
SDA=1;
return(~i_clock());
unsigned char i_receive(void)
unsigned char i_data=0;
unsigned char i;
for(i=0;i<8;i++)
i_data*=2;
if(i_clock()) i_data++;
return(i_data);
bit start_temperature_T(void)
i_start();
if(i_send(0x90))
if(i_send(0xee))
i_stop();
delay();
return(1);
else
i_stop();
delay();
return(0);
else
i_stop();
delay();
return(0);
bit read_temperature_T(unsigned char *p)
i_start();
if(i_send(0x90))
if(i_send(0xaa))
i_start();
if(i_send(0x91))
*(p+1)=i_receive();
i_ack();
*p=i_receive();
i_stop();
delay();
return(1);
else
i_stop();
delay();
return(0);
else
i_stop();
delay();
return(0);
else
i_stop();
delay();
return(0);
void main(void)
P1=0xff;
timecount=0;
displaycount=0;
TMOD=0x21;
TH1=0x06;
TL1=0x06;
TR1=1;
ET1=1;
ET0=1;
EA=1;
if(start_temperature_T())
//向DS1624发送启动A/D温度转换命令,成功则启动T0定时1s。
secondflag=0;
secondcount=0;
TH0=55536/256;
TL0=55536%256;
TR0=1;
while(1)
if(secondflag==1)
secondflag=0;
TR0=0;
if(read_temperature_T(temperdata))
//T0定时1s时间到,读取DS1624的温度值
for(x=0;x<8;x++)
displaybuffer[x]=16;
x=2;
result=temperdata[1];
//将读取的温度值进行数据处理,并送到显示缓冲区
while(result/10)
displaybuffer[x]=result%10;
result=result/10;
x++;
displaybuffer[x]=result;
result=temperdata[0];
result=result>>3;
displaybuffer[0]=(dotcode[result])%10;//dotcode是识别图形码
displaybuffer[1]=(dotcode[result])/10;
//温度值数据处理完毕,重新启动DS1624开始温度转换
secondflag=0;
secondcount=0;
TH0=55536/256;
TL0=55536%256;
TR0=1;
void t0(void) interrupt 1 using 0
//T0用于定时1s时间到
secondcount++;
if(secondcount==100)
secondcount=0;
secondflag=1;
TH0=55536/256;
TL0=55536%256;
void t1(void) interrupt 3 using 0
//T1定时1ms用数码管的动态刷新
timecount++;
if(timecount==4)
//T1定时1ms到
timecount=0;
if (displaycount==5)
P0=(displaycode[displaybuffer[7-displaycount]] | 0x80);
//在该位同时还要显示小数点
else
P0=displaycode[displaybuffer[7-displaycount]];
P2=displaybit[displaycount];
displaycount++;
if(displaycount==8)
displaycount=0;
newstarman|  楼主 | 2012-2-25 21:06 | 只看该作者
这是“带有存储器功能的数字温度计-DS1624技术应用”整段程序,然道这里没人回答吗?真叫人急。。。
airwill| | 2012-2-26 09:00 | 只看该作者
是啊, 很多走控制系统里的程序比较难懂, 不是代码难读, 而是它跟硬件和协议有关, 很多知识在程序外面哪.
我看这个完全跟 DS1624 有关, 建议找找这方面的资料先认真学习学习看看,
