仿真时候出现的问题
2381|7
 楼主| heweibig 发表于 2012-2-26 14:55 | 显示全部楼层 |阅读模式
Error connecting to the target:
Error 0x80000200/-1047
Fatal Error during: OCS,
PTI_ERR_EMU_CLOSE Error Occured at 0x00000000
I/O Port = 240
Board Name: F2812 XDS510 Emulator_1
Cpu Name: CPU_1
Abort:  Close Code Composer Studio.
Retry:  Try to connect to the target again.
Cancel:  Remain disconnected from the target
Diagnostic: Run diagnostic utility.
jiahy 发表于 2012-2-26 14:56 | 显示全部楼层
是语法问题吗?
lizye 发表于 2012-2-26 14:57 | 显示全部楼层
先复位一下仿真器debug-->reset  emulator,再连接一下看看,
 楼主| heweibig 发表于 2012-2-26 14:58 | 显示全部楼层
lizye 发表于 2012-2-26 15:00 | 显示全部楼层
断电重新连接几次
总之就是先复位仿真器,然后断电几次试试。
 楼主| heweibig 发表于 2012-2-26 15:03 | 显示全部楼层
嗯,我试试把,多谢啦哈
 楼主| heweibig 发表于 2012-2-26 15:04 | 显示全部楼层
结贴之
