使用430制作的水表---低压检测
1846|0
 楼主| 雁舞白沙 发表于 2012-2-28 09:25 | 显示全部楼层 |阅读模式
#i nclude <GLOBAL.h>
#i nclude <stdlib.h>
#i nclude <stdbool.h>
#i nclude <msp430x43x.h>#define BatPowerChkDirIn          P1DIR &=  ~BIT4
#define BatPowerChkIn             P1IN  &   BIT4
#define BatPowerChk             BIT4
#define MotoConOneOut             P6DIR |=  BIT1
#define MotoConOneHig             P6OUT |=  BIT1
#define MotoConOneLow             P6OUT &=~ BIT1
#define MotoConTwoOut             P6DIR |=  BIT2
#define MotoConTwoHig             P6OUT |=  BIT2
#define MotoConTwoLow             P6OUT &=~ BIT2
void PowerOnChk(void)
    if(SecondsConn&0x20)
        if(PowerLowTimer!=0)
              PowerLowTimer--;
        else
            if(BatPowerChkIn)//---电池电源正常
                 PowerLowFg=0;
                 MeterSt[0]&=0xfb;
            else
                 PowerLowFg=1;
                 MeterSt[0]|=0x04;
                 OpenLcd();
                 MotoStr(0);//--------------------------------------------------关阀
            PowerLowTimer=30;
            BatPowerChkDirIn;
        SecondsConn&=0xdf;
