使用430制作的水表---脉冲采集累计
2003|0
 楼主| 雁舞白沙 发表于 2012-2-28 09:29 | 显示全部楼层 |阅读模式
#i nclude <GLOBAL.h>
#i nclude <stdlib.h>
#i nclude <stdbool.h>
#i nclude <msp430x41x.h>//*========================================================
  #define    PulseOne      BIT0
  #define    PulseTwo      BIT1
  #define    PulseOneSt      P2IN   & BIT0
  #define    PulseTwoSt      P2IN   & BIT1
  #define    PulsePowerOut      P6DIR |=  BIT3;
  #define    PulsePowerHig      P6OUT |=  BIT3;
  #define    PulseOneDirIn      P2DIR  &= ~BIT0
  #define    PulseTwoDinIn      P2DIR  &= ~BIT1
//*参数定义:
void PulseInit(void)
    PulseOneDirIn;
    PulseTwoDinIn;
    PulsePowerOut;
    PulsePowerHig;
    P2IE  = 0;
    P2IES = 0;
    P2IE  |= PulseOne;
    P2IES |= PulseOne;
    P2IE  |= PulseTwo;
    P2IES |= PulseTwo;
void DataComper(void)
    DptrDecData(AddsBuy,Overal,Residual);//---累计购买量-累计使用量=剩余量
    if(DataThr>0)
        //---检查是否到了关阀报警量
        DptrDecData(Residual,BaoJing,GloBuf);//---剩余量-报警量
        if(DataThr==0)
            ShowBuy=1;
            if(!ClosValveJgEn)
                MotoStr(0);//-----------------------------------------------关阀
                ClosValveJgEn=1;
            else
                MotoStr(1);//--------------------------------------------------开阀
        else
            if(!DisturbFg)
            ShowBuy=0;
            ClosValveJgEn=0;
        OverdraftSt=0;
        MeterSt[0]&=0xfe;
    else
       //---过零关阀
       DptrDecData(Overal,AddsBuy,OverData); //---累计使用量-累计购买量=透支量
       MotoStr(0);//--------------------------------------------------关阀
       OverdraftSt=1;
       ShowBuy=1;
       MeterSt[0]|=0x01;
void PulseAdd(void)
    if(SecondsConn&0x01)
        if(!(PulseOneSt&BIT0))
            if(PulseOneTimes<5)
                PulseOneTimes++;
                if(PulseOneTimes>2)
                    PulseOneEn=1;
        else
            PulseOneTimes=0;
        if(!(PulseTwoSt&BIT1))
            if(PulseTwoTimes<5)
                PulseTwoTimes++;
                if(PulseTwoTimes>2)
                    PulseTwoEn=1;
        else
            PulseTwoTimes=0;
        if((PulseOneEn==1)&(PulseTwoEn==1))
            if(!DisturbFg)
                Overal[0]=Overal[0]>>4;
                Overal[0]++;
                if(Overal[0]>=10)
                    Overal[0]=0;
                    DataAddup(&Overal[1],3);
                    ComperEn=1;
                    DataComper();
                    DataSave();
                Overal[0]=Overal[0]<<4;
                PulseOneEn=0;
                PulseTwoEn=0;
                PulseAddEn=0;
        SecondsConn&=0xfe;
#pragma vector=PORT2_VECTOR
__interrupt void P2ISR(void)
    if(P2IFG&BIT0)
        LPM4_EXIT;
        BasicTimer=75;
    if(P2IFG&BIT1)
        LPM4_EXIT;
        BasicTimer=75;
    P2IFG = 0;
