PMS154C_WS281215*7显示时间
521|0
 楼主| 34af9uc 发表于 2021-3-12 21:49 | 显示全部楼层 |阅读模式
/****************WS281215*7************************//****************QQ:774145445**********************//****************快手:共同学习STM8*****************//*****************20210316*************************///              PMS154C//           ______@______//          |1 PB4  PB3 16|-0//        0-|2 PB5  PB2 15|-kr//       ks-|3 PB6  PB1 14|-kg//          |4 PB7  PB0 13|-0//          |5 VDD  GND 12|//       x1-|6 PA7  PA0 11|----WS281215*7//       x2-|7 PA6  PA4 10|-kb//          |8_PA5__PA3__9|-0////           WS2812B串联15*7//pa0--→→→→→→→→ →→→→→→→|//                                    |//    |←←←←←←←← ←←←←←←←|//    |//    |→→→→→→→→ →→→→→→→|//                                    |//    |←←←←←←←← ←←←←←←←|//    |//    |→→→→→→→→ →→→→→→→|//                                    |//    |←←←←←←←← ←←←←←←←|//    |
//    |→→→→→→→→ →→→→→→→/**************************************************///memory 0x74 ~ 0x7F for stack, vector = 0x0//memory 0x0 ~ 0x73 are free//Check Sum is 0x8C136F//PMS154C  : ROM Size : 0x7E8//PMS154C  : Last use Code : 0x511 , Remain Free-Code : 0x2D7 [+33] , Remain Free-RAM : 82//ICE     : ROM Size : 0x7E8//ICE     : Last use Code : 0x50F , Remain Free-Code : 0x2D9 [+33] , Remain Free-RAM : 82/**************************************************/#include        "extern.h"byte                x_0_1,x_0_2;                //显示rambyte                x_1_1,x_1_2;byte                x_2_1,x_2_2;byte                x_3_1,x_3_2;byte                x_4_1,x_4_2;byte                x_5_1,x_5_2;byte                x_6_1,x_6_2;byte                shi,fen,miao;                //时,分,秒byte                dian;                                //点:byte                lv,hong,lan;byte                shi_shi,shi_ge;                //小时十位,小时个位byte                fen_shi,fen_ge;                //分钟十位,分钟个位byte                qumo_a1;byte                zimo_a1,zimo_a2,zimo_a3;                //字模byte                xian_xian;                        //显示一次标志位//byte                k_a1;                                //按键调时退出条件/**************************************************/void                zimo_0();                //字模0void                zimo_1();                //字模1void                zimo_2();                //字模2void                zimo_3();                //字模3void                zimo_4();                //字模4void                zimo_5();                //字模5void                zimo_6();                //字模6void                zimo_7();                //字模7void                zimo_8();                //字模8void                zimo_9();                //字模9void                yi();                        //发1void                ling();                        //发0void                shijian_fenjie();//时间分解void                qing_ram();                //清ramvoid                qumo();                        //取模void                fuzhi();                //赋值void                xianshi();                //显示void                xianshi_1();        //显示第一行void                xianshi_2();        //显示第二行//反取void                xianshi_3();        //显示第三行void                xianshi_4();        //显示第四行//反取void                xianshi_5();        //显示第五行void                xianshi_6();        //显示第六行//反取void                xianshi_7();        //显示第七行void                xian_1();                //显1void                xian_0();                //显0void                anjian();                //按键/**************************************************/chuan                bit                pa.0;                //串行口ks                        bit                pb.6;                //设置kr                        bit                pb.2;                //红色,小时+kg                        bit                pb.1;                //绿色,分钟+kb                        bit                pa.4;                //蓝色
/**************************************************/void        FPPA0 (void){.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4$                chuan                out,low;                //输出0$                pb.5                out,low;$                pa.3                out,low;$                pb.0                out,low;$                pb.3                out,low;$                ks                        in,pull;                //输入,上拉电阻$                kr                        in,pull;                //$                kg                        in,pull;$                kb                        in,pull;/**************************************************/shi                        =12;fen                        =00;miao                =0;lv                        =1;hong                =1;lan                        =1;xian_xian        =1;/**************************************************/                //开外部晶体eco$                eoscr                enable,32khz;/**************************************************/                //系统时钟切换外部晶体//$                clkmd                eosc/1,en_ihrc;//$                clkmd                EOSC/8;//goto                $+1;/**************************************************/                //timer2定时器500ms中断1次$                tm2c                eosc,disable,period;//$                tm2c                sysclk,disable,period;//$                tm2s                8bit,/4,/11;$                tm2s                8bit,/64,/32;//tm2ct                =0;                        //计数寄存器(初值)tm2b                =16;                        //上限寄存器/**************************************************/                //中断$                inten                tm2;                //开中断//$                inten                ;                        //关中断engint                //允许全部中断//disgint                //停止全部中断/**************************************************/while (1){if(xian_xian)        {        xian_xian                =0;        xianshi();        }.delay                500000;anjian();}}/**************************************************/void                anjian()                //按键{if(ks==0)                //调时模式        {        if(kr==0)                {                shi                ++;                if(shi==24){shi=0;}                xian_xian                =1;                }        if(kg==0)                {                fen                ++;                if(fen==60){fen=0;}                xian_xian                =1;                }        if(kb==0)                {                lv                        =0;                hong                =1;                lan                        =0;                xian_xian        =1;                }        return;        }
if(kr==0)        {hong        ++;        xian_xian        =1;}if(kg==0)        {lv                ++;        xian_xian        =1;}if(kb==0)        {lan        ++;        xian_xian        =1;}}/**************************************************/void        Interrupt (void){pushaf;                //入栈
if (Intrq.6){//tm2ct                =0;                        //计数寄存器初值miao++;xian_xian                =1;if(dian){dian=0;}        else{dian=1;}
if(miao==60)        {        miao                =0;        fen                        ++;        if(fen==60)                {                fen                =0;                shi                ++;                if(shi==24)                        {shi=0;}                if(shi==20)                {                lv                        =1;                hong                =1;                lan                        =1;                }                }        }Intrq.6        =        0;
}popaf;                //出栈}/**************************************************/                //字模//0  fe 82 fe//1  00 fe 00//2  9e 92 f2//3  92 92 fe//4  70 10 fe//5  f2 92 9e//6  fe 92 9e//7  c0 80 fe//8  fe 92 fe//9  f2 92 fevoid                zimo_0()                //字模0{zimo_a1                =0xfe;zimo_a2                =0x82;zimo_a3                =0xfe;}void                zimo_1()                //字模1{zimo_a1                =0x00;zimo_a2                =0xfe;zimo_a3                =0x00;}void                zimo_2()                //字模2{zimo_a1                =0x9e;zimo_a2                =0x92;zimo_a3                =0xf2;}void                zimo_3()                //字模3{zimo_a1                =0x92;zimo_a2                =0x92;zimo_a3                =0xfe;}void                zimo_4()                //字模4{zimo_a1                =0x70;zimo_a2                =0x10;zimo_a3                =0xfe;}void                zimo_5()                //字模5{  zimo_a1                =0xf2;zimo_a2                =0x92;zimo_a3                =0x9e;}void                zimo_6()                //字模6{zimo_a1                =0xfe;zimo_a2                =0x92;zimo_a3                =0x9e;}void                zimo_7()                //字模7{zimo_a1                =0xc0;zimo_a2                =0x80;zimo_a3                =0xfe;}void                zimo_8()                //字模8{zimo_a1                =0xfe;zimo_a2                =0x92;zimo_a3                =0xfe;}void                zimo_9()                //字模9{zimo_a1                =0xf2;zimo_a2                =0x92;zimo_a3                =0xfe;}/**************************************************/void                yi()                                //发1{chuan                =1;nop;nop;nop;nop;chuan                =0;nop;
/**************************************************/void                ling()                                //发0{chuan                =1;//nop;chuan                =0;nop;nop;nop;nop;
/**************************************************/void                shijian_fenjie()                //时间分解{byte                shi_b1,fen_b1;shi_shi                =0;shi_ge                =0;fen_shi                =0;fen_ge                =0;shi_b1                =shi;fen_b1                =fen;while(shi_b1>9)                        //小时分解{shi_shi                ++;                        //小时十位shi_b1                -=10;}shi_ge                =shi_b1;                //小时个位
while(fen_b1>9)                        //分钟分解{fen_shi                ++;                        //分钟十位fen_b1                -=10;}fen_ge                =fen_b1;                //分钟个位}/**************************************************/
void                qing_ram()                //清ram{x_0_1                =0;x_0_2                =0;x_1_1                =0;x_1_2                =0;x_2_1                =0;x_2_2                =0;x_3_1                =0;x_3_2                =0;x_4_1                =0;x_4_2                =0;x_5_1                =0;x_5_2                =0;x_6_1                =0;x_6_2                =0;}/**************************************************/void                qumo()                        //取模{if(qumo_a1==0)        {zimo_0();        return;}if(qumo_a1==1)        {zimo_1();        return;}if(qumo_a1==2)        {zimo_2();        return;}if(qumo_a1==3)        {zimo_3();        return;}if(qumo_a1==4)        {zimo_4();        return;}if(qumo_a1==5)        {zimo_5();        return;}if(qumo_a1==6)        {zimo_6();        return;}if(qumo_a1==7)        {zimo_7();        return;}if(qumo_a1==8)        {zimo_8();        return;}if(qumo_a1==9)        {zimo_9();        return;}}
/**************************************************/void                fuzhi()                //赋值{qumo_a1                =shi_shi;                                        //取模赋值qumo();        //取模//zimo_a1,zimo_a2,zimo_a3;                                //取回的字模值if(zimo_a1.7)        {x_0_1.7        =1;}                //小时十位//竖转横if(zimo_a1.6)        {x_1_1.7        =1;}if(zimo_a1.5)        {x_2_1.7        =1;}if(zimo_a1.4)        {x_3_1.7        =1;}if(zimo_a1.3)        {x_4_1.7        =1;}if(zimo_a1.2)        {x_5_1.7        =1;}if(zimo_a1.1)        {x_6_1.7        =1;}
if(zimo_a2.7)        {x_0_1.6        =1;}if(zimo_a2.6)        {x_1_1.6        =1;}if(zimo_a2.5)        {x_2_1.6        =1;}if(zimo_a2.4)        {x_3_1.6        =1;}if(zimo_a2.3)        {x_4_1.6        =1;}if(zimo_a2.2)        {x_5_1.6        =1;}if(zimo_a2.1)        {x_6_1.6        =1;}
if(zimo_a3.7)        {x_0_1.5        =1;}if(zimo_a3.6)        {x_1_1.5        =1;}if(zimo_a3.5)        {x_2_1.5        =1;}if(zimo_a3.4)        {x_3_1.5        =1;}if(zimo_a3.3)        {x_4_1.5        =1;}if(zimo_a3.2)        {x_5_1.5        =1;}if(zimo_a3.1)        {x_6_1.5        =1;}
qumo_a1                =shi_ge;                                        //取模赋值qumo();        //取模//zimo_a1,zimo_a2,zimo_a3;                                //取回的字模值if(zimo_a1.7)        {x_0_1.3        =1;}                //小时个位//竖转横if(zimo_a1.6)        {x_1_1.3        =1;}if(zimo_a1.5)        {x_2_1.3        =1;}if(zimo_a1.4)        {x_3_1.3        =1;}if(zimo_a1.3)        {x_4_1.3        =1;}if(zimo_a1.2)        {x_5_1.3        =1;}if(zimo_a1.1)        {x_6_1.3        =1;}
if(zimo_a2.7)        {x_0_1.2        =1;}if(zimo_a2.6)        {x_1_1.2        =1;}if(zimo_a2.5)        {x_2_1.2        =1;}if(zimo_a2.4)        {x_3_1.2        =1;}if(zimo_a2.3)        {x_4_1.2        =1;}if(zimo_a2.2)        {x_5_1.2        =1;}if(zimo_a2.1)        {x_6_1.2        =1;}
if(zimo_a3.7)        {x_0_1.1        =1;}if(zimo_a3.6)        {x_1_1.1        =1;}if(zimo_a3.5)        {x_2_1.1        =1;}if(zimo_a3.4)        {x_3_1.1        =1;}if(zimo_a3.3)        {x_4_1.1        =1;}if(zimo_a3.2)        {x_5_1.1        =1;}if(zimo_a3.1)        {x_6_1.1        =1;}
qumo_a1                =fen_shi;                                        //取模赋值qumo();        //取模//zimo_a1,zimo_a2,zimo_a3;                                //取回的字模值if(zimo_a1.7)        {x_0_2.7        =1;}                //分钟十位//竖转横if(zimo_a1.6)        {x_1_2.7        =1;}if(zimo_a1.5)        {x_2_2.7        =1;}if(zimo_a1.4)        {x_3_2.7        =1;}if(zimo_a1.3)        {x_4_2.7        =1;}if(zimo_a1.2)        {x_5_2.7        =1;}if(zimo_a1.1)        {x_6_2.7        =1;}
if(zimo_a2.7)        {x_0_2.6        =1;}if(zimo_a2.6)        {x_1_2.6        =1;}if(zimo_a2.5)        {x_2_2.6        =1;}if(zimo_a2.4)        {x_3_2.6        =1;}if(zimo_a2.3)        {x_4_2.6        =1;}if(zimo_a2.2)        {x_5_2.6        =1;}if(zimo_a2.1)        {x_6_2.6        =1;}
if(zimo_a3.7)        {x_0_2.5        =1;}if(zimo_a3.6)        {x_1_2.5        =1;}if(zimo_a3.5)        {x_2_2.5        =1;}if(zimo_a3.4)        {x_3_2.5        =1;}if(zimo_a3.3)        {x_4_2.5        =1;}if(zimo_a3.2)        {x_5_2.5        =1;}if(zimo_a3.1)        {x_6_2.5        =1;}
qumo_a1                =fen_ge;                                        //取模赋值qumo();        //取模//zimo_a1,zimo_a2,zimo_a3;                                //取回的字模值if(zimo_a1.7)        {x_0_2.3        =1;}                //分钟个位//竖转横if(zimo_a1.6)        {x_1_2.3        =1;}if(zimo_a1.5)        {x_2_2.3        =1;}if(zimo_a1.4)        {x_3_2.3        =1;}if(zimo_a1.3)        {x_4_2.3        =1;}if(zimo_a1.2)        {x_5_2.3        =1;}if(zimo_a1.1)        {x_6_2.3        =1;}
if(zimo_a2.7)        {x_0_2.2        =1;}if(zimo_a2.6)        {x_1_2.2        =1;}if(zimo_a2.5)        {x_2_2.2        =1;}if(zimo_a2.4)        {x_3_2.2        =1;}if(zimo_a2.3)        {x_4_2.2        =1;}if(zimo_a2.2)        {x_5_2.2        =1;}if(zimo_a2.1)        {x_6_2.2        =1;}
if(zimo_a3.7)        {x_0_2.1        =1;}if(zimo_a3.6)        {x_1_2.1        =1;}if(zimo_a3.5)        {x_2_2.1        =1;}if(zimo_a3.4)        {x_3_2.1        =1;}if(zimo_a3.3)        {x_4_2.1        =1;}if(zimo_a3.2)        {x_5_2.1        =1;}if(zimo_a3.1)        {x_6_2.1        =1;}}/**************************************************/void                xianshi()                //显示{shijian_fenjie();                //时间分解qing_ram();                                //清ramfuzhi();                                //赋值
xianshi_1();        //显示第一行xianshi_2();        //显示第二行xianshi_3();        //显示第三行xianshi_4();        //显示第四行xianshi_5();        //显示第五行xianshi_6();        //显示第六行xianshi_7();        //显示第七行
}/**************************************************/void                xian_1()        //显1发送顺序绿红蓝grb{if(lv.7)        {yi();}        else{ling();}if(lv.6)        {yi();}        else{ling();}if(lv.5)        {yi();}        else{ling();}if(lv.4)        {yi();}        else{ling();}if(lv.3)        {yi();}        else{ling();}if(lv.2)        {yi();}        else{ling();}if(lv.1)        {yi();}        else{ling();}if(lv.0)        {yi();}        else{ling();}
if(hong.7)        {yi();}        else{ling();}if(hong.6)        {yi();}        else{ling();}if(hong.5)        {yi();}        else{ling();}if(hong.4)        {yi();}        else{ling();}if(hong.3)        {yi();}        else{ling();}if(hong.2)        {yi();}        else{ling();}if(hong.1)        {yi();}        else{ling();}if(hong.0)        {yi();}        else{ling();}
if(lan.7)        {yi();}        else{ling();}if(lan.6)        {yi();}        else{ling();}if(lan.5)        {yi();}        else{ling();}if(lan.4)        {yi();}        else{ling();}if(lan.3)        {yi();}        else{ling();}if(lan.2)        {yi();}        else{ling();}if(lan.1)        {yi();}        else{ling();}if(lan.0)        {yi();}        else{ling();}}/**************************************************/void                xian_0()                //显0{byte                xian_0_a1;xian_0_a1                =24;while(xian_0_a1--)                //重复24次        {        ling();        }}/**************************************************/void                xianshi_1()        //显示第一行{if                (x_0_1.7)        {xian_1();}        else{xian_0();}if                (x_0_1.6)        {xian_1();}        else{xian_0();}if                (x_0_1.5)        {xian_1();}        else{xian_0();}if                (x_0_1.4)        {xian_1();}        else{xian_0();}if                (x_0_1.3)        {xian_1();}        else{xian_0();}if                (x_0_1.2)        {xian_1();}        else{xian_0();}if                (x_0_1.1)        {xian_1();}        else{xian_0();}if                (x_0_1.0)        {xian_1();}        else{xian_0();}
if                (x_0_2.7)        {xian_1();}        else{xian_0();}if                (x_0_2.6)        {xian_1();}        else{xian_0();}if                (x_0_2.5)        {xian_1();}        else{xian_0();}if                (x_0_2.4)        {xian_1();}        else{xian_0();}if                (x_0_2.3)        {xian_1();}        else{xian_0();}if                (x_0_2.2)        {xian_1();}        else{xian_0();}if                (x_0_2.1)        {xian_1();}        else{xian_0();}//if                (x_0_2.0)        {xian_1();}        else{xian_0();}}/**************************************************/void                xianshi_2()        //显示第二行//反取{//if                (x_1_2.0)        {xian_1();}        else{xian_0();}if                (x_1_2.1)        {xian_1();}        else{xian_0();}if                (x_1_2.2)        {xian_1();}        else{xian_0();}if                (x_1_2.3)        {xian_1();}        else{xian_0();}if                (x_1_2.4)        {xian_1();}        else{xian_0();}if                (x_1_2.5)        {xian_1();}        else{xian_0();}if                (x_1_2.6)        {xian_1();}        else{xian_0();}if                (x_1_2.7)        {xian_1();}        else{xian_0();}
if                (x_1_1.0)        {xian_1();}        else{xian_0();}if                (x_1_1.1)        {xian_1();}        else{xian_0();}if                (x_1_1.2)        {xian_1();}        else{xian_0();}if                (x_1_1.3)        {xian_1();}        else{xian_0();}if                (x_1_1.4)        {xian_1();}        else{xian_0();}if                (x_1_1.5)        {xian_1();}        else{xian_0();}if                (x_1_1.6)        {xian_1();}        else{xian_0();}if                (x_1_1.7)        {xian_1();}        else{xian_0();}
}/**************************************************/void                xianshi_3()        //显示第三行{if                (x_2_1.7)        {xian_1();}        else{xian_0();}if                (x_2_1.6)        {xian_1();}        else{xian_0();}if                (x_2_1.5)        {xian_1();}        else{xian_0();}if                (x_2_1.4)        {xian_1();}        else{xian_0();}if                (x_2_1.3)        {xian_1();}        else{xian_0();}if                (x_2_1.2)        {xian_1();}        else{xian_0();}if                (x_2_1.1)        {xian_1();}        else{xian_0();}//if                (x_2_1.0)        {xian_1();}        else{xian_0();}
if                (dian==1)        {xian_1();}        else{xian_0();}                //显示:
if                (x_2_2.7)        {xian_1();}        else{xian_0();}if                (x_2_2.6)        {xian_1();}        else{xian_0();}if                (x_2_2.5)        {xian_1();}        else{xian_0();}if                (x_2_2.4)        {xian_1();}        else{xian_0();}if                (x_2_2.3)        {xian_1();}        else{xian_0();}if                (x_2_2.2)        {xian_1();}        else{xian_0();}if                (x_2_2.1)        {xian_1();}        else{xian_0();}//if                (x_2_2.0)        {xian_1();}        else{xian_0();}}/**************************************************/void                xianshi_4()        //显示第四行//反取{//if                (x_3_2.0)        {xian_1();}        else{xian_0();}if                (x_3_2.1)        {xian_1();}        else{xian_0();}if                (x_3_2.2)        {xian_1();}        else{xian_0();}if                (x_3_2.3)        {xian_1();}        else{xian_0();}if                (x_3_2.4)        {xian_1();}        else{xian_0();}if                (x_3_2.5)        {xian_1();}        else{xian_0();}if                (x_3_2.6)        {xian_1();}        else{xian_0();}if                (x_3_2.7)        {xian_1();}        else{xian_0();}
if                (x_3_1.0)        {xian_1();}        else{xian_0();}if                (x_3_1.1)        {xian_1();}        else{xian_0();}if                (x_3_1.2)        {xian_1();}        else{xian_0();}if                (x_3_1.3)        {xian_1();}        else{xian_0();}if                (x_3_1.4)        {xian_1();}        else{xian_0();}if                (x_3_1.5)        {xian_1();}        else{xian_0();}if                (x_3_1.6)        {xian_1();}        else{xian_0();}if                (x_3_1.7)        {xian_1();}        else{xian_0();}}/**************************************************/void                xianshi_5()        //显示第五行{if                (x_4_1.7)        {xian_1();}        else{xian_0();}if                (x_4_1.6)        {xian_1();}        else{xian_0();}if                (x_4_1.5)        {xian_1();}        else{xian_0();}if                (x_4_1.4)        {xian_1();}        else{xian_0();}if                (x_4_1.3)        {xian_1();}        else{xian_0();}if                (x_4_1.2)        {xian_1();}        else{xian_0();}if                (x_4_1.1)        {xian_1();}        else{xian_0();}//if                (x_4_1.0)        {xian_1();}        else{xian_0();}if                (dian==1)        {xian_1();}        else{xian_0();}                //显示:
if                (x_4_2.7)        {xian_1();}        else{xian_0();}if                (x_4_2.6)        {xian_1();}        else{xian_0();}if                (x_4_2.5)        {xian_1();}        else{xian_0();}if                (x_4_2.4)        {xian_1();}        else{xian_0();}if                (x_4_2.3)        {xian_1();}        else{xian_0();}if                (x_4_2.2)        {xian_1();}        else{xian_0();}if                (x_4_2.1)        {xian_1();}        else{xian_0();}//if                (x_4_2.0)        {xian_1();}        else{xian_0();}}/**************************************************/void                xianshi_6()        //显示第六行//反取{//if                (x_5_1.0)        {xian_1();}        else{xian_0();}if                (x_5_2.1)        {xian_1();}        else{xian_0();}if                (x_5_2.2)        {xian_1();}        else{xian_0();}if                (x_5_2.3)        {xian_1();}        else{xian_0();}if                (x_5_2.4)        {xian_1();}        else{xian_0();}if                (x_5_2.5)        {xian_1();}        else{xian_0();}if                (x_5_2.6)        {xian_1();}        else{xian_0();}if                (x_5_2.7)        {xian_1();}        else{xian_0();}
if                (x_5_1.0)        {xian_1();}        else{xian_0();}if                (x_5_1.1)        {xian_1();}        else{xian_0();}if                (x_5_1.2)        {xian_1();}        else{xian_0();}if                (x_5_1.3)        {xian_1();}        else{xian_0();}if                (x_5_1.4)        {xian_1();}        else{xian_0();}if                (x_5_1.5)        {xian_1();}        else{xian_0();}if                (x_5_1.6)        {xian_1();}        else{xian_0();}if                (x_5_1.7)        {xian_1();}        else{xian_0();}}/**************************************************/void                xianshi_7()        //显示第七行{if                (x_6_1.7)        {xian_1();}        else{xian_0();}if                (x_6_1.6)        {xian_1();}        else{xian_0();}if                (x_6_1.5)        {xian_1();}        else{xian_0();}if                (x_6_1.4)        {xian_1();}        else{xian_0();}if                (x_6_1.3)        {xian_1();}        else{xian_0();}if                (x_6_1.2)        {xian_1();}        else{xian_0();}if                (x_6_1.1)        {xian_1();}        else{xian_0();}if                (x_6_1.0)        {xian_1();}        else{xian_0();}
if                (x_6_2.7)        {xian_1();}        else{xian_0();}if                (x_6_2.6)        {xian_1();}        else{xian_0();}if                (x_6_2.5)        {xian_1();}        else{xian_0();}if                (x_6_2.4)        {xian_1();}        else{xian_0();}if                (x_6_2.3)        {xian_1();}        else{xian_0();}if                (x_6_2.2)        {xian_1();}        else{xian_0();}if                (x_6_2.1)        {xian_1();}        else{xian_0();}//if                (x_6_2.0)        {xian_1();}        else{xian_0();}}/**************************************************//**************************************************//**************************************************//**************************************************/
