[STM32F1]
数据只有0和4095,是什么问题?
811|22
wenfen|  楼主 | 2021-3-15 22:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
数据只有0和4095,是什么问题?
pengf| | 2021-3-15 22:28 | 只看该作者
楼主详细说说怎么回事啊,这么说太笼统了
wenfen|  楼主 | 2021-3-15 22:31 | 只看该作者
STM32F103VET6,ADC+DMA采集,电压是16.8V电池电阻6分压的电压
接上电池AD数据就是4095,不接就是0,IO口量过电压是2点多伏
程序在RET6上正常使用,到VET6上由IO口由C口换到了PB1,仔细检查过很多遍了
估计可能是什么原因?帮我指点下方向我再检查
juventus9554| | 2021-3-15 22:33 | 只看该作者
程序的问题,再检查下你的程序。
stly| | 2021-3-15 22:36 | 只看该作者
ADC+DMA 我也遇到了这个现象读回来的数不是0就是4095或者1023,2047这几种。
wenfen|  楼主 | 2021-3-15 22:38 | 只看该作者
后来怎么解决的?
wenfen|  楼主 | 2021-3-15 22:40 | 只看该作者
初始化程序很简单,用的引脚是PA0,PA1和PB1
void  Adc_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB |RCC_APB2Periph_ADC1,ENABLE );
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        ADC_DeInit(ADC1);
            ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
            ADC_InitStructure.ADC_ScanConvMode = ENABLE;//DISABLE;
            ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
            ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
            ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
            ADC_InitStructure.ADC_NbrOfChannel = 5;
            ADC_Init(ADC1, &ADC_InitStructure);
          ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
           ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
           ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 3, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_16, 4, ADC_SampleTime_239Cycles5 );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_17, 5, ADC_SampleTime_239Cycles5 );
            ADC_Cmd(ADC1, ENABLE);
            ADC_DMACmd(ADC1, ENABLE);
        ADC_TempSensorVrefintCmd(ENABLE);
            ADC_ResetCalibration(ADC1);
            while(ADC_GetResetCalibrationStatus(ADC1));
            ADC_StartCalibration(ADC1);
            while(ADC_GetCalibrationStatus(ADC1));
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
void DMA_Config(void)
    DMA_InitTypeDef DMA_InitStructure;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize = 5;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    DMA_Cmd(DMA1_Channel1, ENABLE);
dingy| | 2021-3-15 22:43 | 只看该作者
换了IO,通道也要换下;
wyjie| | 2021-3-15 22:45 | 只看该作者
还没解决。因为我这是用的STM32 linux系统,ADC驱动是linux里的,跟STM32的固件库完全不同。
pengf| | 2021-3-15 22:47 | 只看该作者
看一下示例代码。再改改就行了
zhanghqi| | 2021-3-15 22:49 | 只看该作者
外部电平问题或者引脚配置问题
huwr| | 2021-3-15 22:52 | 只看该作者
直接接地看看
yszong| | 2021-3-15 22:54 | 只看该作者
程序问题吧
chuxh| | 2021-3-15 22:57 | 只看该作者
寄存器怎么设置的
xxmmi| | 2021-3-15 23:01 | 只看该作者
寄存器怎么设置的
stly| | 2021-3-15 23:03 | 只看该作者
是不是寄存器设置有问题啊
houcs| | 2021-3-15 23:04 | 只看该作者
也有可能是你读错寄存器了
ousj| | 2021-3-15 23:11 | 只看该作者
应该是程序问题
kangzj| | 2021-3-15 23:13 | 只看该作者
硬件没毛病的话那就是软件的问题喽
wuhany| | 2021-3-15 23:16 | 只看该作者
应该就是你设置有问题
