[STM32F4] stm32f413can接收中断不响应
1944|12
 楼主| tongwei 发表于 2021-3-19 15:36 | 显示全部楼层 |阅读模式
调试现象:can1,can2,can3发送数据均正常,接收采用中断接收方式,can1,can3能响应中断,can2无法进入接收中断,曾怀疑can2配置的CAN_FilterNumber参数设置的不对,但是试验了0~27,都不行,各位大佬有啥好的办法,还望指教。的配置代码如下:
void CAN1_Init(void)
  CAN_InitTypeDef CAN_InitStructure;
  CAN_FilterInitTypeDef CAN_FilterInitStructure;
  NVIC_InitTypeDef  NVIC_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1,ENABLE);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource11,GPIO_AF_CAN1);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource12,GPIO_AF_CAN1);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11| GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  CAN_StructInit(&CAN_InitStructure);
  CAN_DeInit(CAN1);
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = ENABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1 = CAN_BS1_4tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
  CAN_InitStructure.CAN_Prescaler = 10;
  CAN_Init(CAN1, &CAN_InitStructure);
  CAN_FilterInitStructure.CAN_FilterNumber=0;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(CAN1,&CAN_FilterInitStructure);
  CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE);
  NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x02;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x02;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void CAN2_Init(void)
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOG,ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN2,ENABLE);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource11,GPIO_AF_CAN2);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource12,GPIO_AF_CAN2);
  GPIO_Init(GPIOG, &GPIO_InitStructure);
  CAN_DeInit(CAN2);
  CAN_Init(CAN2, &CAN_InitStructure);
  CAN_FilterInitStructure.CAN_FilterNumber=14;
  CAN_FilterInit(CAN2,&CAN_FilterInitStructure);
  CAN_ITConfig(CAN2,CAN_IT_FMP0,ENABLE);
  NVIC_InitStructure.NVIC_IRQChannel = CAN2_RX0_IRQn;
香水城 发表于 2021-3-24 17:58 | 显示全部楼层
说实话 从配置上没看出问题所在。
你将CAN1/CAN2的FIFO分别指定不同的试试。
另外 CAN1/CAN2共用26个Filter.
代码是基于别的移植过来的吗? 尽量用最新版cube库来做。
香水城 发表于 2021-4-2 12:04 | 显示全部楼层
另外你注意下滤波器配置那个地方,
CAN1 CAN2公用filter,由CAN1掌管。即配置CAN2滤波器时还是用CAN1.
 楼主| tongwei 发表于 2021-4-7 15:08 | 显示全部楼层
另外你注意下滤波器配置那个地方,
CAN1 CAN2公用filter,由CAN1掌管。即配置CAN2滤波器时还是用CAN1. ...
多谢香版主
 楼主| tongwei 发表于 2021-4-7 15:17 | 显示全部楼层
说实话 从配置上没看出问题所在。
代码是由407直接移植过来的,以后会更多的尝试用Cube来做
 楼主| tongwei 发表于 2021-4-7 15:21 | 显示全部楼层
另外你注意下滤波器配置那个地方,
最终问题还是出在can接收滤波器上了,感觉是库的bug,只是感觉
gwsan 发表于 2021-4-8 14:02 | 显示全部楼层
配置没有问题
coshi 发表于 2021-4-8 14:04 | 显示全部楼层
为什么最新版cube不可以做啊
aoyi 发表于 2021-4-8 14:05 | 显示全部楼层
这个can真的很不容易调试
drer 发表于 2021-4-8 14:07 | 显示全部楼层
这边已经有数据发送出来了吗
kxsi 发表于 2021-4-8 14:07 | 显示全部楼层
这三个can是不一样的吗
CAN1 CAN2是共享1个滤波控制器,由CAN1掌管。  发表于 2021-4-11 20:56
jsj0716 发表于 2022-4-6 10:37 | 显示全部楼层
大佬把搞定的代码贴一下,我也遇到了这个问题。
