[技术问答]
HK32F030MF4P6 PC3-TIM1_CH3 PWM 没输出
1162|5
lpx280666373|  楼主 | 2021-3-25 15:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pc, TI, PWM, IO, pi
void TIM1_WindPwm_Config(void)                        //16K TIM1_CH3
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOC, ENABLE );
      RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE);
        // 使能IOMUX时钟
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_IOMUX,ENABLE);
      GPIO_IOMUX_PinAFConfig(GPIOC,GPIO_PinSource3,IOMUX_PC3_TIM1CH3);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;//GPIO_PuPd_DOWN;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_PinAFConfig(GPIOC,GPIO_PinSource3,GPIO_AF_3);
        /* Time Base configuration */
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseStructure.TIM_Period = TIM1_PERIOD-1;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
        /* Channel 1, 2,3 and 4 Configuration in PWM mode */
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;//TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_Pulse = 1000;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
        //TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        //TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
        TIM_OC3Init(TIM1, &TIM_OCInitStructure);
        /* TIM1 counter enable */
        TIM_Cmd(TIM1, ENABLE);
        /* TIM1 Main Output Enable */
        TIM_CtrlPWMOutputs(TIM1, ENABLE);
} @annko2005
lpx280666373|  楼主 | 2021-3-25 15:58 | 只看该作者
初次使用
lixuewei520| | 2021-3-25 19:44 | 只看该作者
https://bbs.21ic.com/icview-3114928-1-1.html,看这里
lpx280666373|  楼主 | 2021-3-26 08:41 | 只看该作者
汗。。。。。。。。。。。。。。。。。
lpx280666373|  楼主 | 2021-3-26 08:47 | 只看该作者
TIM1_CH3      不是TIM3_CH1
lpx280666373|  楼主 | 2021-3-26 10:12 | 只看该作者
结贴    屏蔽 //RCC_APB1PeriphClockCmd(RCC_APB1Periph_IOMUX,ENABLE);   正常输出!!!   谢谢 @lixuewei520
