GD32F103-EVAL开发板
1046|2
 楼主| 风来吴山 发表于 2021-3-27 15:17 | 显示全部楼层 |阅读模式
#21ic问答#我想将PC6这个引脚作为TIMER2_CH0使用输出PWM,按照手册的说明进行了如下初始化,但是PC6这个引脚在初始化之后,使用示波器查看,没有PWM输出,请问这里是哪的问题呢?
初始化的源码已贴,望大佬指点,万分感谢了。
  1. static void init_laser_output_io(void)
  3.     rcu_periph_clock_enable(RCU_GPIOA | RCU_GPIOB | RCU_GPIOC | RCU_AF);
  4.     gpio_pin_remap_config(GPIO_SWJ_SWDPENABLE_REMAP, ENABLE);
  5.     gpio_pin_remap_config(GPIO_TIMER0_PARTIAL_REMAP, ENABLE);
  6.     gpio_pin_remap_config(GPIO_TIMER2_PARTIAL_REMAP, ENABLE);
  7.     gpio_init(GPIOA, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_11 | GPIO_PIN_15);
  8.     gpio_init(GPIOB, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
  9.     gpio_init(GPIOC, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
  10. }
  1. void init_laser_3(void)
  3.     timer_oc_parameter_struct timer_ocintpara;
  4.     timer_parameter_struct timer_initpara;
  5.     rcu_periph_clock_enable(RCU_TIMER2);
  6.     timer_deinit(TIMER2);
  7.     /* TIMER2 configuration */
  8.     timer_initpara.prescaler         = 9;
  9.     timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
  10.     timer_initpara.counterdirection  = TIMER_COUNTER_UP;
  11.     timer_initpara.period            = 5400;
  12.     timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
  13.     timer_initpara.repetitioncounter = 0;
  14.     timer_init(TIMER2, &timer_initpara);
  15.     /* CH0 configuration in PWM mode1 */
  16.     timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
  17.     timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
  18.     timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
  19.     timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;
  20.     timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_LOW;
  21.     timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
  22.     timer_channel_output_config(TIMER2, TIMER_CH_0, &timer_ocintpara);
  23.     /* CH0 configuration in PWM mode1,duty cycle 50% */
  24.     timer_channel_output_pulse_value_config(TIMER2, TIMER_CH_0, 2700);
  25.     timer_channel_output_mode_config(TIMER2, TIMER_CH_0, TIMER_OC_MODE_PWM0);
  26.     timer_channel_output_shadow_config(TIMER2, TIMER_CH_0, TIMER_OC_SHADOW_DISABLE);
  27.     /* auto-reload preload enable */
  28.     timer_auto_reload_shadow_enable(TIMER2);
  29.     /* enable */
  30.     timer_enable(TIMER2);
  31. }
 楼主| 风来吴山 发表于 2021-3-27 15:59 | 显示全部楼层
  4.     gpio_pin_remap_config(GPIO_SWJ_SWDPENABLE_REMAP, ENABLE);   // PA15
  5.     gpio_pin_remap_config(GPIO_TIMER1_PARTIAL_REMAP0, ENABLE);  // PA15
  6.     gpio_pin_remap_config(GPIO_TIMER2_FULL_REMAP, ENABLE);      // PC6
  10. }
我将PC6这个引脚重新初始化了,还是没有输出PWM。
 楼主| 风来吴山 发表于 2021-3-27 16:27 | 显示全部楼层
  1. rcu_periph_clock_enable(RCU_GPIOA);
  2. rcu_periph_clock_enable(RCU_GPIOB);
  3. rcu_periph_clock_enable(RCU_GPIOC);
  4. rcu_periph_clock_enable(RCU_AF);
在QQ群解决了,时钟不能用或运算符,因为是enum的。
