[AT32F403/403A] 求解Jlink V9连接正常,用V11就不正常,版本6.82g
2391|7
 楼主| styleno1 发表于 2021-3-29 22:29 | 显示全部楼层 |阅读模式
买了个新仿真器,发现连不上芯片,另外的一块M0连接、仿真都正常,AT403的用V11就连不上,求解?
V9连接正常:
  1. - Executing init sequence ...
  2.   - Initialized successfully
  3. - Target interface speed: 2000 kHz (Auto)
  4. - Found 1 JTAG device. Core ID: 0x2BA01477 (None)
  5. - Connected successfully
V11连接不成功:
  1. Connecting ...
  2. - Connecting via USB to probe/ programmer device 0
  3. - Probe/ Programmer firmware: J-Link V11 compiled Feb  4 2021 12:59:17
  4. - Device "AT32F403_EXT_TYPE2_1MB" selected.
  5. - ConfigTargetSettings() start
  6. - [ConfigTargetSettings]
  7. - ConfigTargetSettings() end
  8. - InitTarget() start
  9. - InitTarget() end
  10. - Found SW-DP with ID 0x2BA01477
  11. - DPIDR: 0x2BA01477
  12. - AP map detection skipped. Manually configured AP map found.
  13. - AP[0]: AHB-AP (IDR: Not set)
  14. - AP[0]: Skipped. Could not read CPUID register
  15. - ConfigTargetSettings() start
  16. - [ConfigTargetSettings]
  17. - ConfigTargetSettings() end
  18. - InitTarget() start
  19. - InitTarget() end
  20. - Found SW-DP with ID 0x2BA01477
  21. - DPIDR: 0x2BA01477
  22. - AP map detection skipped. Manually configured AP map found.
  23. - AP[0]: AHB-AP (IDR: Not set)
  24. - AP[0]: Skipped. Could not read CPUID register
  25. - ERROR: Could not find core in Coresight setup
  26. - Target interface speed: 200 kHz (Auto)
  27. - VTarget = 3.373V
  28. - ConfigTargetSettings() start
  29. - [ConfigTargetSettings]
  30. - ConfigTargetSettings() end
  31. - InitTarget() start
  32. - InitTarget() end
  33. - Found SW-DP with ID 0x2BA01477
  34. - DPIDR: 0x2BA01477
  35. - AP map detection skipped. Manually configured AP map found.
  36. - AP[0]: AHB-AP (IDR: Not set)
  37. - AP[0]: Skipped. Could not read CPUID register
  38. - ConfigTargetSettings() start
  39. - [ConfigTargetSettings]
  40. - ConfigTargetSettings() end
  41. - InitTarget() start
  42. - InitTarget() end
  43. - Found SW-DP with ID 0x2BA01477
  44. - DPIDR: 0x2BA01477
  45. - AP map detection skipped. Manually configured AP map found.
  46. - AP[0]: AHB-AP (IDR: Not set)
  47. - AP[0]: Skipped. Could not read CPUID register
  48. - ERROR: Could not find core in Coresight setup
  49. - ERROR: Failed to connect.
  50. Could not establish a connection to target.
选ARM Cortex-M4时连接正常:
  1. Connecting ...
  3. - Probe/ Programmer firmware: J-Link V11 compiled Jul 17 2020 16:24:07
  4. - Device "CORTEX-M4" selected.
  5. - Target interface speed: 4000 kHz (Fixed)
  6. - VTarget = 3.364V
  7. - Found SW-DP with ID 0x2BA01477
  8. - DPIDR: 0x2BA01477
  9. - Scanning AP map to find all available APs
  10. - AP[1]: Stopped AP scan as end of AP map has been reached
  11. - AP[0]: AHB-AP (IDR: 0x24770011)
  12. - Iterating through AP map to find AHB-AP to use
  13. - AP[0]: Core found
  14. - AP[0]: AHB-AP ROM base: 0xE00FF000
  15. - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
  16. - Found Cortex-M4 r0p1, Little endian.
  17. - FPUnit: 6 code (BP) slots and 2 literal slots
  18. - CoreSight components:
  19. - ROMTbl[0] [url=home.php?mod=space&uid=72445]@[/url] E00FF000
  20. - ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
  21. - ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
  22. - ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
  23. - ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
  24. - ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
  25. - ROMTbl[0][5]: E0041000, CID: 00000000, PID: 00000000 ???
  26. - Executing init sequence ...
  27.   - Initialized successfully
  28. - Target interface speed: 4000 kHz (Fixed)
  29. - Found 1 JTAG device. Core ID: 0x2BA01477 (None)
  30. - Connected successfully
编辑说明:补充Log
084425 发表于 2021-3-30 13:22 来自手机 | 显示全部楼层
理论上来说不应该,连不上什么意思,是指jlink命令行都无法连上吗
 楼主| styleno1 发表于 2021-3-30 16:28 | 显示全部楼层
已更新Log信息
muyichuan2012 发表于 2021-3-30 22:08 来自手机 | 显示全部楼层
你这里device选择很奇怪  怎么会是AT32F403_EXT_TYPE2_1MB,完全不合理,应该是at32的型号才对。
 楼主| styleno1 发表于 2021-3-30 23:08 | 显示全部楼层
你这里device选择很奇怪  怎么会是AT32F403_EXT_TYPE2_1MB,完全不合理,应该是at32的型号才对。 ...
这是官方芯片列表里带的,烧录外挂的SPI Flash。这个到不用困扰,用V9也是这个上位机,它是正常的
muyichuan2012 发表于 2021-3-31 12:51 来自手机 | 显示全部楼层
我知道是spim的文件,这是我写的。我是觉得device 这里选择有点问题。可否告知jlink v11购买链接,我们买一个测试一下。
 楼主| styleno1 发表于 2021-3-31 14:58 | 显示全部楼层
我知道是spim的文件,这是我写的。我是觉得device 这里选择有点问题。可否告知jlink v11购买链接,我们买一 ...
我在贸泽上买的Jlink Base,www.mouser.cn
muyichuan2012 发表于 2021-3-31 19:12 来自手机 | 显示全部楼层
您好 我们的FAE已经与您取得联系,后面我们会持续跟进。
个人签名:www.striverbar.com
16
