低成本TrueTouch方案
2839|5
Go_PSoC|  楼主 | 2012-3-1 20:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Cypress Introduces New TrueTouch® Solution That Provides High-Performance Touchscreens for Lower-Cost Phones
最近更新:
2012 年 02 月 24 日
New TMA140 Family Offers Multi-Finger Support, Best-in-Class SNR, Cypress’s Exclusive Charger Armor™ Feature for Screen Sizes up to 5 Inches
SAN JOSE, Calif., February 26, 2012 – Cypress Semiconductor Corp. (NASDAQ: CY) today introduced the TMA140 TrueTouch® controllers for lower-cost mobile phones. The new family offers high-performance touchscreen control, including multi-finger support and best-in-class Signal-to-Noise Ratio (SNR) for screens of up to five inches. The new controllers also support Cypress’s patent-pending Charger Armor™ feature, which uses adaptive frequency hopping and other techniques to prevent false touches due to excessive noise from a charger.
The new TMA140 family delivers high performance multi-touch capabilities on a feature phone budget. The low power family offers better than 0.5-mm accuracy, delivers gesture capability, works flawlessly with Android and is now in mass production.
TMA140 was designed to work with SLIM®, Cypress’s Single Layer Independent Multi-touch sensor. SLIM is a true single-substrate, single layer ITO touchscreen sensor.  Unlike competitive solutions, it requires no additional insulation layers or bridges. This reduces the cost of traditional multi-touch sensors by roughly 40%, and also greatly reduces the thickness of the sensor module. TMA140 and SLIM create the world’s lowest cost multi-touch solution in the market, making multi-touch affordable for feature phones.
“By delivering a high-performance solution for the lower-cost phone market, Cypress is offering our customers a chance to shine versus their competition in very high volume markets,” said John Carey, Director of TrueTouch Marketing at Cypress. “We also have announced the SLIM sensor that enables true multi-touch into lower-cost phones via a single-layer sensor. TrueTouch now offers the industry’s best solution for the hottest new smartphones (our Gen4™ controllers) as well as lower cost features phones, and everything in between.”
Availability
The TMA140 sensor family is available today from Cypress. Customers can select from either 36-pin or 48-pin QFN packages.
About TrueTouch
Cypress’s TrueTouch technology provides the industry’s best noise immunity, highest signal to noise ratio (SNR), fastest refresh rates, lowest power consumption, and world’s best accuracy and linearity. The flexible TrueTouch solution allows customers to rapidly develop leading-edge solutions without having to buy turnkey modules. They have a choice of using touch sensors (glass or film) and LCDs from preferred partners, and can develop innovative mechanical designs ranging from flat to curved surfaces of varying thickness. Additional TrueTouch information is available at touch.cypress.com.
Go_PSoC|  楼主 | 2012-3-1 20:53 | 只看该作者
中文的新闻应该马上就出来了,我们先看英文的先睹为快吧!
Go_PSoC|  楼主 | 2012-3-2 21:27 | 只看该作者
2012 年 3 月 2日,北京讯,加州圣何塞讯——赛普拉斯半导体公司(纳斯达克股票代码:CY)日前推出面向较低成本手机的 TMA140 TrueTouch® 控制器。该全新系列产品可面向最大 5 英寸的屏幕提供高性能触摸屏控制功能,包括多手指操控支持以及业界最佳的信噪比 (SNR)。此外,这种全新控制器还支持赛普拉斯正在申请专利的 Charger Armor™ 功能,可通过自适应跳频等技术来避免充电器额外噪声引起的虚假触摸问题。
全新 TMA140 系列可在功能手机的预算限度内提供高性能多点触摸功能。这种低功耗系列产品不仅将精确度控制在 0.5 毫米以内,而且可提供多种手势操控功能,还能与 Android 系统完美协作,目前已经投入量产。
TMA140 经过精心设计,可与赛普拉斯的单层独立多点触摸传感器 SLIM®实现完美协作。SLIM 是一款真正的单基底单层 ITO 触摸屏传感器。与同类竞争解决方案不同的是,它不需要额外的绝缘层或桥接器,从而相对于多点触摸传感器而言能将成本降低约 40%,而且还能显著减少传感器模块的厚度。TMA140 和 SLIM 的完美组合可为市场带来成本最低的多点触摸解决方案,使功能手机的成本预算也能支持多点触摸功能。
赛普拉斯 TrueTouch 市场营销总监 John Carey 指出:“通过为较低成本手机市场推出一款高性能解决方案,赛普拉斯帮助客户在非常大批量的市场中赢得优于同类竞争解决方案的显著优势。此外,我们还推出了 SLIM 传感器,其通过单层传感器能让较低成本的手机支持真正的多点触摸功能。TrueTouch 现在可提供面向全新最热门智能手机的业界最佳解决方案(我们的 Gen4™ 控制器),而且还能充分满足较低成本功能手机的需求以及最高性能和低成本二者之间的各种差异化需求。”
供货情况
赛普拉斯现已全面推出 TMA140 传感器系列。客户可选择 36 引脚 QFN 封装或者 48 引脚 QFN 封装。
关于 TrueTouch
赛普拉斯的 TrueTouch 技术可提供业界最佳的抗噪性、最高的性噪比、最快的刷新率、最低的功耗以及全球最佳的精确度与线性度。灵活的 TrueTouch 解决方案可以使客户快速开发先进的解决方案,而无需购买交钥匙模块。他们可以从自己的供应商处选择触摸传感器(玻璃或薄膜)和 LCD,且可以开发出从平面到曲面的各种厚度的创新机械设计。如欲了解有关 TrueTouch 解决方案的更多详情,敬请访问:touch.cypress.com。
关于赛普拉斯
赛普拉斯提供高性能、混合信号、可编程解决方案,加快客户产品的上市进程并提供出色的系统价值。赛普拉斯的产品包括旗舰产品 PSoC® 可编程片上系统系列,及其多种衍生产品,如应用于高压和 LED 照明领域的 PowerPSoC®、用于触摸感应的 CapSense®,以及用于触摸屏的 TrueTouch 解决方案。赛普拉斯在 USB 控制器领域居全球领先地位,这类产品中包括能提升多媒体手机的连接性和性能的高性能 West Bridge® 解决方案。赛普拉斯还是高性能存储器和可编程时序器件的领先供应商。赛普拉斯的产品应用于众多领域,包括消费电子、手机、计算、数据通信、汽车、工业和军事等。赛普拉斯的股票在纳斯达克全球精选市场上交易,股票代码为 CY。如欲了解更多详情,敬请访问赛普拉斯网站:www.cypress.com。
wsdxs| | 2012-3-4 00:05 | 只看该作者
haohaohao
rocky_bian| | 2012-5-25 16:24 | 只看该作者
非常适用于One Glass 上面,看来CY 的春天又来了!! 21434 out了
TMA140 in 了
wsdxs| | 2012-5-26 20:23 | 只看该作者
这个好
