真正多点触摸单层sensor- SLIM®
3078|2
Go_PSoC|  楼主 | 2012-3-1 20:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Cypress Introduces Industry's First True Single-Layer Sensor With Multitouch Capability
最近更新: 2012 年 02 月 24 日
New SLIM® Sensor Enables Low-Cost Phones to Include Touchscreens with Popular Gestures; Opens up High-Volume Opportunities for Touchscreens in Low-Cost Markets
SAN JOSE, Calif., February 27, 2012 – Cypress Semiconductor Corp. (NASDAQ: CY) today unveiled the industry’s first single-layer touchscreen sensor solution with multitouch capability. The new SLIM® (Single-Layer Independent Multitouch) sensor delivers high-performance touchscreen accuracy and responsiveness with a true single-layer sensor panel, drastically reducing the cost of the most expensive component of the touchscreen. It enables low-cost touchscreen phones to offer users the ability to perform gestures such as pinch, zoom, flick, drag, swipe and other gestures requiring more than two fingers.
Increasingly, capacitive touchscreens are viewed as a differentiator for mobile devices. Many lower-priced “feature phones” do not offer capacitive touchscreens today because of the cost, or offer only rudimentary touch features. The Slim sensor opens up new “feature phones” and lower-cost smartphones to capacitive touchscreens that include popular multi-finger gesture interfaces.
SLIM is a true single-substrate, single layer ITO touchscreen sensor.  Unlike competitive solutions, it requires no additional insulation layers or bridges. This reduces the cost versus multi-touch sensors by roughly 40%, and also greatly reduces the thickness of the sensor module. SLIM can be deposited directly on the cover glass to create the thinnest touchscreen phones ever.
The SLIM sensor pattern is even more unique in that it can eliminate the requirement for a side-bezel, normally about 2 mm on each side of the end product. This feature enables borderless display modules that allow OEMs to use larger displays without changing the form-factor of the phone.
“The ability to offer thinner, less expensive phones with true multitouch capability is a tremendous advantage for our customers,” said Dhwani Vyas, vice president of the User Interface Business Unit at Cypress. “We are making the SLIM sensor available with our Gen4 controllers, among others, to enable truly outstanding performance. Feature phones with top-notch touchscreen interfaces will be a true differentiator in many high-volume markets.”
The combination of the SLIM sensor and the Gen4 controller will allow the world’s slimmest touchscreen devices, as Gen4’s industry-leading noise immunity enables sensor-on-lens configurations that are directly laminated to the display with no shielding or air gaps.
Traditional capacitive touchscreens use a two-layer sensor to deliver the accuracy and linearity required for today’s user experience. Cypress has developed proprietary algorithms that interface with a true single-layer sensor with no bridges to deliver two-layer performance for an unparalleled combination of user experience and cost sensitivity. The removal of this second sensor layer can save mobile device manufacturers 40 percent or more on sensor costs, which is often the most expensive part of the touchscreen module.
About TrueTouch
Cypress’s TrueTouch technology provides the industry’s best noise immunity, highest signal to noise ratio (SNR), fastest refresh rates, lowest power consumption, and world’s best accuracy and linearity. The flexible TrueTouch solution allows customers to rapidly develop leading-edge solutions without having to buy turnkey modules. They have a choice of using touch sensors (glass or film) and LCDs from preferred partners, and can develop innovative mechanical designs ranging from flat to curved surfaces of varying thickness. Additional TrueTouch information is available at touch.cypress.com.
中文的新闻应该马上就出来了,我们先看英文的先睹为快吧!
Go_PSoC|  楼主 | 2012-3-2 21:29 | 只看该作者
赛普拉斯半导体公司(纳斯达克股票代码:CY)日前宣布推出业界首款具有多点触摸功能的单层触摸屏传感器解决方案。该款全新的 SLIM(单层独立多点触摸)传感器可实现高性能触摸屏精度和高响应性,采用真正的单层传感器面板,可显著降低触摸屏中价格最高的组件成本。它可让低成本触摸屏手机也能为用户带来手势操控功能,包括平移、缩放、轻击、拖曳、晃动以及其他超过两个手指的动作。
  电容式触摸屏正越来越多地被视为移动设备的一项独特创新功能。由于成本的原因,目前众多较低价格的“功能手机”还不支持电容式触摸屏,或者只能提供基本的触控功能。Slim 传感器则为新的“功能手机”和较低成本智能手机采用电容式触摸屏(包括流行的多手指手势操控界面)带来了契机。
  SLIM 是一款真正的单基底单层 ITO 触摸屏传感器。与同类竞争解决方案不同的是,它不需要额外的绝缘层或桥接器,从而相对于多点触摸传感器而言能将成本降低约 40%,而且还能显著减少传感器模块的厚度。此外,SLIM 还能直接安在保护玻璃上,从而实现业界最薄的触摸屏手机。
  SLIM 传感器模式的更为独特之处在于,它不再需要侧边凹槽 (side-bezel),这种侧边凹槽通常要在最终产品每侧占上大约 2 毫米。这项功能可帮助实现无边框显示模块,从而让 OEM 厂商无需改变手机外形就能使用更大的显示屏。
  赛普拉斯用户界面业务部副总裁 Dhwani Vyas 指出:“由于能够推出更薄、价格更低的具有真正多点触摸功能的手机,我们可为客户带来巨大的优势。我们在 Gen4 控制器的基础上推出 SLIM 传感器等,从而实现真正的出色性能。带顶级触摸屏界面的功能手机将在众多大批量市场中成为一项真正的独特创新功能。”
  SLIM 传感器和 Gen4 控制器的完美结合将带来全球最薄的触摸屏器件,可让 Gen4 业界领先的抗噪性支持 sensor-on-lens 配置,从而能够直接层压在显示屏上,且无需屏蔽层和气隙。
  传统的电容式触摸屏采用双层传感器来满足当今用户体验对高精度和线性度的要求。赛普拉斯开发的专有算法无需桥接就能够与真正的单层传感器接口相连,以提供双层传感器的性能水平,从而就用户体验与成本而言实现了无与伦比的超高性价比组合。无需采用第二个传感器层可为移动设备制造商节约 40% 乃至更多的传感器成本,而传感器往往是触摸屏模块中成本最高的组件。
