sbit LS138A=P2^2;
sbit LS138B=P2^3;
sbit LS138C=P2^4;
unsigned int LedNumVal = 0 ,LedOut[8];
// 此表为 LED 的字模            // 0    1    2    3    4    5    6   7    8    9    A    b    c    d    E    -    L   P    U    Hidden  _ (20)
unsigned char code Disp_Tab[] = { ~0xC0,~0xF9,~0xA4,~0xB0,~0x99,~0x92,~0x82,~0xF8,~0x80,~0x90,~0x88,~0x83,~0xC6,~0xA1,~0x86,~0xbf,~0xc7,~0x8c,~0xc1, ~0xff,  ~0xf7 };
void delay(unsigned int i)
    char j;
    for(i; i > 0; i--)
        for(j = 200; j > 0; j--);
display()
{  unsigned char i;
     LedOut[0]=Disp_Tab[LedNumVal%10000/1000];
     LedOut[1]=Disp_Tab[LedNumVal%1000/100]&0x7f;
     LedOut[2]=Disp_Tab[LedNumVal%100/10];
     LedOut[3]=Disp_Tab[LedNumVal%10];
         for( i=0; i<8; i++)
         {         P0 = LedOut[i];
          switch(i)
                        case 0S138A=0; LS138B=0; LS138C=0; break;
                case 1S138A=1; LS138B=0; LS138C=0; break;
                case 2S138A=0; LS138B=1; LS138C=0; break;
                case 3S138A=1; LS138B=1; LS138C=0; break;
                        case 4S138A=0; LS138B=0; LS138C=1; break;
                        case 5S138A=1; LS138B=0; LS138C=1; break;
                        case 6S138A=0; LS138B=1; LS138C=1; break;
                        case 7S138A=1; LS138B=1; LS138C=1; break;
                delay(150);
* 主程序                                               *
void main(void)
   P0=0xff;
   P1=0xff;
   P2=0xff;
// IT0=0;       //低电平触发
   IT0=1;       //下降沿触发
   EX0=1;
   while(1)
     display();
* INT0中断函数
(crazybc.com)                                      *
void  counter(void) interrupt 0
//   unsigned char  x;
   EX0=0;
   LedNumVal++;     //中断计数
   EX0=1;
