[STM32L4] STM32L4 LPTIM无法进入中断,从STOP模式唤醒
1328|17
 楼主| liliang9554 发表于 2021-4-12 19:37 | 显示全部楼层 |阅读模式
根据官方例子等都不能进入中断
 楼主| liliang9554 发表于 2021-4-12 19:39 | 显示全部楼层
LSE可以使用(LPUART使用LSE能正常工作)
想问下 你可以用LSE给定时器当时钟源吗 停机模式下 我想让定时器输出方波  发表于 2021-6-2 23:37
jlyuan 发表于 2021-4-12 19:42 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
 楼主| liliang9554 发表于 2021-4-12 19:43 | 显示全部楼层
#include "lptim.h"
LPTIM_HandleTypeDef LptimHandle;
void LPTIM1_IRQHandler(void)
    HAL_LPTIM_IRQHandler(&LptimHandle);
    log(DEBUG,"lptim count=%u\n" , HAL_LPTIM_ReadCounter(&LptimHandle));
void HAL_LPTIM1_MspInit(LPTIM_HandleTypeDef *lptimHandle)
    __HAL_RCC_LPTIM1_CLK_ENABLE();
    HAL_NVIC_SetPriority(LPTIM1_IRQn, 5, 0);
    HAL_NVIC_EnableIRQ(LPTIM1_IRQn);
#define Period               (uint32_t) 65535
#define Timeout              (uint32_t) (32768 - 1)
int lptim_hal_init(void)
    RCC_PeriphCLKInitTypeDef        RCC_PeriphCLKInitStruct;
    HAL_Delay(2000);
        /* Select the LSE clock as LPTIM peripheral clock */
    RCC_PeriphCLKInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LPTIM1;
    RCC_PeriphCLKInitStruct.Lptim1ClockSelection = RCC_LPTIM1CLKSOURCE_LSE;
    HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphCLKInitStruct);
    LptimHandle.Instance = LPTIM1;
    LptimHandle.Init.Clock.Source    = LPTIM_CLOCKSOURCE_APBCLOCK_LPOSC;
    LptimHandle.Init.CounterSource   = LPTIM_COUNTERSOURCE_INTERNAL;
    LptimHandle.Init.Clock.Prescaler = LPTIM_PRESCALER_DIV1;
    LptimHandle.Init.Trigger.Source  = LPTIM_TRIGSOURCE_SOFTWARE;
    LptimHandle.Init.OutputPolarity  = LPTIM_OUTPUTPOLARITY_HIGH;
    LptimHandle.Init.UpdateMode      = LPTIM_UPDATE_IMMEDIATE;
    LptimHandle.Init.Input1Source    = LPTIM_INPUT1SOURCE_GPIO;
    LptimHandle.Init.Input2Source    = LPTIM_INPUT2SOURCE_GPIO;
    if (HAL_LPTIM_Init(&LptimHandle) != HAL_OK)
        Error_Handler(__FILE__,__LINE__);
    INIT_PRINT(INIT_OK,"LPTIM1 init");
    if (HAL_LPTIM_Counter_Start(&LptimHandle, 1000) != HAL_OK)
    HAL_PWREx_EnterSTOP1Mode(PWR_STOPENTRY_WFI);
    log(DEBUG,"lptime init\n");
    return 0;
 楼主| liliang9554 发表于 2021-4-12 19:45 | 显示全部楼层
调试过程中进入过2次, 手贱没保存。
morrisk 发表于 2021-4-12 19:47 | 显示全部楼层
因为你根本就没开中断,当然进不去
wuhany 发表于 2021-4-12 19:49 | 显示全部楼层
楼上提醒是有道理的。
HAL库里都有现存代码,你可以比较参考下。
zhenykun 发表于 2021-4-12 19:51 | 显示全部楼层
哈哈,中断没开,
zhaoxqi 发表于 2021-4-12 19:53 | 显示全部楼层
是不是触发源 选的不对或者根本没有触发
chuxh 发表于 2021-4-12 19:56 | 显示全部楼层
在中断向量那解除屏蔽了吗
dingy 发表于 2021-4-12 19:58 | 显示全部楼层
楼主,我遇到了同样的问题,怎么解决的?
 楼主| liliang9554 发表于 2021-4-12 20:00 | 显示全部楼层
设置问题, 你好需要吗, 我贴源码上来, 不过要换电脑
renzheshengui 发表于 2021-5-7 11:51 | 显示全部楼层
是官方的开发板吗
wakayi 发表于 2021-5-7 11:52 | 显示全部楼层
恩恩恩 中断使能没有开启吧
wowu 发表于 2021-5-7 11:55 | 显示全部楼层
其他中断能进入吗
xiaoqizi 发表于 2021-5-7 11:57 | 显示全部楼层
有相应的触发源吗
木木guainv 发表于 2021-5-7 11:58 | 显示全部楼层
修改哪里了啊
