[STM8] stm8s003f/103f的tim2 3路pwm都无输出
762|8
 楼主| zhenykun 发表于 2021-6-2 23:23 | 显示全部楼层 |阅读模式
stm8s003f/103f的tim2 3路pwm都无输出,使用的是st 提供的库,option byte也设置了。代码如下:
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
  * @addtogroup TIM2_PWM_DutyCycleConfiguration
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
uint16_t CCR1_Val = 500;
uint16_t CCR2_Val = 250;
uint16_t CCR3_Val = 125;
/* Private function prototypes -----------------------------------------------*/
static void TIM2_Config(void);
/* Private functions ---------------------------------------------------------*/
/* Public functions ----------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
void main(void)
  /* TIM2 configuration -----------------------------------------*/
  TIM2_Config();
  while (1)
  * @brief  Configure TIM2 peripheral in PWM mode
  * @param  None
  * @retval None
  /* Time base configuration */
  TIM2_TimeBaseInit(TIM2_PRESCALER_1, 999);
  /* PWM1 Mode configuration: Channel1 */
  TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR1_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC1PreloadConfig(ENABLE);
  /* PWM1 Mode configuration: Channel2 */
  TIM2_OC2Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR2_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC2PreloadConfig(ENABLE);
  /* PWM1 Mode configuration: Channel3 */
  TIM2_OC3Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,CCR3_Val, TIM2_OCPOLARITY_HIGH);
  TIM2_OC3PreloadConfig(ENABLE);
  TIM2_ARRPreloadConfig(ENABLE);
  /* TIM2 enable counter */
  TIM2_Cmd(ENABLE);
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
huangchui 发表于 2021-6-2 23:26 | 显示全部楼层
先测试一下你的timer有没有正常运行
jlyuan 发表于 2021-6-2 23:28 | 显示全部楼层
确认下 已经定义了 STM8S003或STM8S103
typedef struct TIM2_struct
  __IO uint8_t CR1;   /*!< control register 1 */
#if defined(STM8S103) || defined(STM8S003)
        uint8_t RESERVED1; /*!< Reserved register */
        uint8_t RESERVED2; /*!< Reserved register */
#endif
  __IO uint8_t IER;   /*!< interrupt enable register */
  __IO uint8_t SR1;   /*!< status register 1 */
  __IO uint8_t SR2;   /*!< status register 2 */
 楼主| zhenykun 发表于 2021-6-2 23:29 | 显示全部楼层
从st下载的库和例程,并在IAR中定义了芯片类型,编译都ok,timer1输出没问题。就timer2无输出,一路也没。
 楼主| zhenykun 发表于 2021-6-2 23:32 | 显示全部楼层
先测试一下你的timer有没有正常运行
测试了, 使用timer2中断例程有动作,代码未变更。
xxrs 发表于 2021-6-2 23:34 | 显示全部楼层
既然这样
可能管脚有问题,还有大家为什么总是不说完整芯片型号呢
xxrs 发表于 2021-6-2 23:36 | 显示全部楼层
是否有管脚需要额外OPTION配置的
lizye 发表于 2021-6-2 23:38 | 显示全部楼层
若果是20脚的003/103,不做OPTION AFR配置就出不来。
 楼主| zhenykun 发表于 2021-6-2 23:43 | 显示全部楼层
好的,我明天去单位试一下,多谢各位大侠了哈
