[STM32F0] IIC的模拟哪里有错
1074|16
 楼主| feiqi1 发表于 2021-6-8 18:25 | 显示全部楼层 |阅读模式
#define uchar unsigned char
#define uint unsigned int
#define SDA_1  P3OUT|=BIT1 // P3.1为SDA
#define SDA_0  P3OUT&=~BIT1
#define SCL_1 P3OUT |= BIT0 //P3.0为SCL
#define SCL_0 P3OUT &= ~BIT0
#define DIR_IN P3DIR &= ~BIT1
#define DIR_OUT P3DIR |= BIT1
#define SDA_IN ((P3IN >> 1) & 0x01)
#define dis_data  P5OUT  //数码管输出
#define TIME 5
#define SlaveAddress   0xA6
uchar seg_bcd[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //数码管
void delay_nms(unsigned int k)//延时k毫秒
   unsigned int i,j;
   for(i=0;i<k;i++)
       for(j=0;j<121;j++)
void Delay(unsigned int n)    //延时
    unsigned int i;
    for(i = 0;i < n;i++)
void BH1750_Start()         //起始信号
     DIR_OUT;
     SDA_1;
    delay_nms(5);
     SCL_1;
     Delay(TIME);
     SDA_0;
     Delay(TIME);
     SCL_0;
void BH1750_Stop()        //结束信号
     DIR_OUT;
     SDA_0;
     Delay(TIME);
     SCL_1;
     Delay(TIME);
     SDA_1;                    }
void BH1750_SendACK()       //发送Ack
     SCL_0;
     DIR_OUT;
     SDA_0;
     Delay(TIME);
     SCL_1;
     Delay(TIME);
     SCL_0;
void BH1750_RecvACK()         //接受ACK
{   SCL_1;
    Delay(TIME);
     DIR_IN;
     while(SDA_IN);
     DIR_OUT;
     SCL_0;
     Delay(TIME);
void BH1750_SendByte(uchar dat)     //发送一个字节
{   DIR_OUT;
     unsigned int i;
     for(i = 0;i < 8;i++)
     SCL_0;
     Delay(TIME);
     if((dat >> 7) & 0x01) SDA_1;
     else SDA_0;
    Delay(TIME);
     SCL_1;
     Delay(TIME);
     dat <<= 1; //数据左移一位,进入下一轮送数
     Delay(TIME);
uchar BH1750_RecvByte()         //接受一个字节
     uchar i;
     uchar dat = 0;
     uchar datbit=0;
     SCL_0;
     Delay(TIME);
     SDA_1;
     DIR_IN;
     for (i=0; i<8; i++)
         SCL_1;
        Delay(TIME);
        datbit = SDA_IN;
         Delay(TIME);
         dat = ((dat << 1) | datbit);
         SCL_0;
        Delay(TIME);
     return dat;
void Single_Write_BH1750(uchar REG_Address)  //写入
     BH1750_Start();
     BH1750_SendByte(SlaveAddress);
     BH1750_SendByte(REG_Address);
   // BH1750_SendByte(REG_data);
     BH1750_Stop();
void main()
{ uchar tmp;
   float temp;
   int t;
   WDTCTL = WDTPW + WDTHOLD;
   P5DIR |= 0Xff;
   P4DIR |= 0x01;
   P5OUT |= 0x00;
   delay_nms(200);
   Single_Write_BH1750(0x01);
   Single_Write_BH1750(0x10);
  while(1)
    { Single_Write_BH1750(0x01);
      delay_nms(180);
      tmp=BH1750_RecvByte();
      temp=(float)tmp;
      t=temp/100;
      dis_data=seg_bcd[t];
androidbus 发表于 2021-6-8 18:31 | 显示全部楼层
个人一点看法:不要简单的贴代码。很少有人会有耐心看既不知道原理图又不知道具体应用的代码,对大家来说是个挑战。
litengg 发表于 2021-6-8 18:32 | 显示全部楼层
硬件连接有没有问题?检查下外围电路正常否。
qiangweii 发表于 2021-6-8 18:38 | 显示全部楼层
IIC通信的地址波特率设置正确否?
shashaa 发表于 2021-6-8 18:38 | 显示全部楼层
用示波器抓图看看波形。
xia00 发表于 2021-6-8 18:44 | 显示全部楼层
//在此类写数据后没有检查应答信号,在写数据后必须检查应答信号
hfdy01 发表于 2021-6-8 18:44 | 显示全部楼层
有可能是你io电平有问题的,加个上啦电阻之类的。
boy1990 发表于 2021-6-8 18:53 | 显示全部楼层
看iic最好还是 用示波器或者逻辑分析仪
sourceInsight 发表于 2021-6-8 18:53 | 显示全部楼层
光强度检测话应该主要是用到AD采集的,直接采集传感器书吃的电压或者电流信号。
bbapple 发表于 2021-6-8 19:01 | 显示全部楼层
IIC通信关键要看时序和波特率
handleMessage 发表于 2021-6-8 19:01 | 显示全部楼层
IIC出问题通常都是时序,用示波器查看一下吧。
zhouhuanの 发表于 2021-6-8 19:06 | 显示全部楼层
这个注意时钟信号的设计。
Listate 发表于 2021-6-8 19:07 | 显示全部楼层
你看看芯片的地址写对了吗
_gege 发表于 2021-6-8 19:14 | 显示全部楼层
如果硬件连接没有问题,大部分都是时序问题。
Edisons 发表于 2021-6-8 19:15 | 显示全部楼层
读LCD的数据有个读数据的指令就是RS=1
laozhongyi 发表于 2021-6-8 19:17 | 显示全部楼层
unsigned char Read_Lcd_Data()
unsigned char byte = 0;
Busy_Test();
Lcd_E = 0;
Lcd_RW = 1;
Lcd_RS = 1;
Lcd_E = 1;
byte = P0;
Lcd_E = 0;
return byte;
wanglaojii 发表于 2021-6-8 19:19 | 显示全部楼层
像是高低跳变的太快,无法正常执行了。
