[STM32F2] 传输大数据量异常
2009|20
 楼主| pangb 发表于 2021-6-17 21:51 | 显示全部楼层 |阅读模式
STM32F205RE SPI DMA
为了提高传输效率我使用 SPI 的 DMA 模式进行传输,测试过程中将 MISO 和 MOSI 短接,直接发送和接收。当数据量为 256 个的时候发送和接收一致。当时数据量为300 的时候后面的20个数据就异常了
 楼主| pangb 发表于 2021-6-17 21:54 | 显示全部楼层
        SPI_InitTypeDef  SPI_InitStructure;
        DMA_InitTypeDef  DMA_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        int ii =0;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
        /*!< Enable SPI2 clocks */
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
        /*!< Enable GPIO clocks */
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
        /*!< Connect SPI pins to AF5 */
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource13,GPIO_AF_SPI2);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource14,GPIO_AF_SPI2);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource15,GPIO_AF_SPI2);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//GPIO_PuPd_NOPULL;
        Cdfinger_BspCs_HIGH();
        //Cdfinger_Bspdelay_ms(1);
  //Cdfinger_BspCs_LOW();
        SPI_Cmd(SPI2,DISABLE);
        SPI_DeInit(SPI2);
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;//;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_CRCPolynomial = 7;
        SPI_Init(SPI2, &SPI_InitStructure);
  memset(&cdfingerimgtxbuf[0],0x55,COMMUNICATIONLEN);
        /* DMA1 Stream0 channel4 spi tx configuration **************************************/
        DMA_DeInit(DMA1_Stream4);
        DMA_InitStructure.DMA_Channel = DMA_Channel_0;
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(SPI2->DR);
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&cdfingerimgtxbuf[0];
        DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
        DMA_InitStructure.DMA_BufferSize = COMMUNICATIONLEN;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;// ;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;//DMA_Priority_Medium;//DMA_Priority_High;
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;//;//DMA_FIFOMode_Enable;
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
        DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
        DMA_Init(DMA1_Stream4, &DMA_InitStructure);
        /* DMA1 Stream0 channel3 spi rx configuration **************************************/
        DMA_DeInit(DMA1_Stream3);
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&cdfingerimgrxbuf[0];//(uint32_t)&cdfingerimgrxbuf[0];
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
        DMA_InitStructure.DMA_BufferSize =COMMUNICATIONLEN;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//DMA_Mode_Circular;
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;//DMA_FIFOMode_Disable;
        DMA_Init(DMA1_Stream3, &DMA_InitStructure);
        //Cdfinger_BspCs_HIGH();
        //发送中断
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x03;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        //接收中断
        NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x04;
        //SPI_TIModeCmd(SPI2,ENABLE);
        SPI_Cmd(SPI2, ENABLE);
        DMA_ITConfig(DMA1_Stream4,DMA_IT_TC,ENABLE);
        DMA_ITConfig(DMA1_Stream3,DMA_IT_TC,ENABLE);
  SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx|SPI_I2S_DMAReq_Rx, ENABLE);
        DMA_Cmd(DMA1_Stream4, ENABLE);
  DMA_Cmd(DMA1_Stream3, ENABLE);
void DMA1_Stream4_IRQHandler(void)
  if(DMA_GetITStatus(DMA1_Stream4,DMA_IT_TCIF4) != RESET)
                DMA_ClearITPendingBit(DMA1_Stream4,DMA_IT_TCIF4);
          DMA_ClearFlag(DMA1_Stream4,DMA_IT_TCIF4);
void DMA1_Stream3_IRQHandler(void)
  if(DMA_GetITStatus(DMA1_Stream3,DMA_IT_TCIF3) != RESET)
                DMA_ClearITPendingBit(DMA1_Stream3,DMA_IT_TCIF3);
          DMA_ClearFlag(DMA1_Stream3,DMA_IT_TCIF3);
songqian17 发表于 2021-6-17 21:56 | 显示全部楼层
cdfingerimgtxbuf这个数组有没有越界?
jiaxw 发表于 2021-6-17 21:59 | 显示全部楼层
这个单片机DMA传输个数的寄存器是不是8位的,导致超过256溢出了?
 楼主| pangb 发表于 2021-6-17 22:01 | 显示全部楼层
请问一下你说的这个数组越界是什么意思,应该不存在这个情况。我看DMA的说明能传 65535 个数据。
chuxh 发表于 2021-6-17 22:03 | 显示全部楼层
我想问的是,你SPI与DMA发送与接收的这个两个数组的大小是多少的?会不会溢出了?
zhenykun 发表于 2021-6-17 22:06 | 显示全部楼层
COMMUNICATIONLEN,这个是传进来的变量么?
llljh 发表于 2021-6-17 22:09 | 显示全部楼层
是什么类型的数据?
dingy 发表于 2021-6-17 22:12 | 显示全部楼层
建议你结合官方相关例程看看手册,弄清原理。
renyaq 发表于 2021-6-17 22:15 | 显示全部楼层
你现在DMA配置为NORMAL模式,你定义的存储数据的内存大小总有个边界的。
huangchui 发表于 2021-6-17 22:17 | 显示全部楼层
目的地址指针配置:
改成disable,是不是就正常了?如果正常说明内存指针越界。
renyaq 发表于 2021-6-17 22:18 | 显示全部楼层
channel3目的地址指针设置:
supernan 发表于 2021-6-17 22:20 | 显示全部楼层
速度太快了?
zwll 发表于 2021-6-17 22:28 | 显示全部楼层
好像SPI有回环测试吧。
tian111 发表于 2021-6-17 22:30 | 显示全部楼层
建议楼主加上间隔。
chenho 发表于 2021-6-17 22:32 | 显示全部楼层
想错了,STM32可以CAN回环测试
jiajs 发表于 2021-6-17 22:34 | 显示全部楼层
不是256的问题吗
zhenykun 发表于 2021-6-17 22:37 | 显示全部楼层
有可能是程序判定问题
 楼主| pangb 发表于 2021-6-17 22:39 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
chenjinyu 发表于 2021-6-28 15:43 | 显示全部楼层
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;  你把8位改成16位试一下
