[PIC®/AVR®/dsPIC®产品] [PIC®/AVR® MCU] 【CuriosityNano测评报告】2 内部温度传感器
3288|0
 楼主| wm20031015 发表于 2021-6-24 11:40 | 显示全部楼层 |阅读模式
PIC18F16Q40内部有温度检测单元,可以用来检测芯片内部温度,等同测量了PCBA板上的温度。本应用需要用到ADC、FVR、UART模块,测量内部温度,通过串口打印出来。
1、FVR初始化
void    FVR_Init(void)
    FVRCON = (1 << 7) | (1 << 5) | (1 << 4) | (2 << 2) | (2 << 0);
2、ADC初始化
void    ADC_Init(void)
    ADCON1 = 0;
    ADCON2 = 0x10;
    ADCON3 = 0;
    ADSTAT = 0x00;
    ADCLK = 0x3f;
    ADPRE = 0x03;
    ADREF = 0x03;
    ADCON0 = (1 << 7) | (1 << 4) | (1 << 2);
3、内部温度传感器初始化
void    TIM_Init(void)
    //读取温度增益和温度偏移值
    EEPROM_Read(0x2c0024, (unsigned char *)(&TempGain), 2);
    EEPROM_Read(0x2c0028, (unsigned char *)(&TempOffSet), 2);
    //初始化FVR
    FVR_Init();
    //ADC初始化
    ADC_Init();
    //配置ADC转换通道为内部温度通道
    ADC_Channel(ADC_TempChannel);
    //ADC转换开始
    ADC_Start();
4、内部温度读取,计算函数
void    TIM_ReadValue(void)
    long ADC_Meas;
    ADC_Meas = (ADRESH << 8) | ADRESL;
    ADC_Meas = ADC_Meas * TempGain;
    ADC_Meas = ADC_Meas / 256;
    ADC_Meas = ADC_Meas + TempOffSet;
    TempMeas = ADC_Meas / 10;
    ADC_Start();
5、串口初始化
void    UART_Init(void)
    TRISB = (5 << 0);
    LATA = (1 << 7) | (1 << 5);
    PPS_Unlock();
    U1RXPPS = (1 << 3) | (5 << 0);  //RB5
    RB7PPS = 0x10;   //RB7
    //PPS_Lock();
    U1RXB = 0x0;
    U1RXCHK = 0x0;
    U1TXB = 0x0;
    U1TXCHK = 0x0;
    U1P1L = 0x0;
    U1P1H = 0x0;
    U1P2L = 0x0;
    U1P2H = 0x0;
    U1P3L = 0x0;
    U1P3H = 0x0;
    U1CON0 = 0xB0;
    U1CON1 = 0x80;
    U1CON2 = 0x00;
    //64M时钟,4分频,波特率19200
    U1BRG = (((64UL * 1000000 * 4) / 16)  / 19200) - 1;
    U1FIFO = 0x0;
    U1UIR = 0x0;
    U1ERRIR = 0x0;
    U1ERRIE = 0x0;
6、EEPROM读取函数,
void    EEPROM_Read(__uint24 addr, unsigned char *ptr, int len)
    do{
        TBLPTRU = (uint8_t)(addr >> 16);
        TBLPTRH = (uint8_t)(addr >> 8);
        TBLPTRL = (uint8_t)(addr >> 0);
        asm("TBLRD");
        *ptr = TABLAT;
        addr++;
        ptr++;
    }while(len--);
7、串口打印结果如图:
