[AVR单片机] ICCAVR编译出错如何处理
2638|1
 楼主| lnww 发表于 2012-3-8 13:52 | 显示全部楼层 |阅读模式
我用ICCAVR编译AVR单片机程序  出现下面的提升错误  该如何处理
C:\iccv7avr\bin\imakew -f CZT_8F.mak
    iccavr -c -e -D__ICC_VERSION=722 -DATMega162  -l -g -MLongJump -MHasMul -MEnhanced  main.c
    iccavr -o CZT_8F -g -e:0x4000 -ucrtatmega.o -bfunc_lit:0x70.0x4000 -dram_end:0x4ff -bdata:0x100.0x4ff -dhwstk_size:30 -beeprom:0.512 -fihx_coff -S2 @CZT_8F.lk   -lcatmega
!E <library>(57): area 'text' not large enough
want size 14618
lo 3158 hi 16384 size 13227
!E main.o(3612): Code address 0:0x1e0 already contains a value
!E main.o(3612): Code address 0:0x1e1 already contains a value
!E main.o(3612): Code address 0:0x1e2 already contains a value
!E main.o(3612): Code address 0:0x1e3 already contains a value
!E main.o(3612): Code address 0:0x1e4 already contains a value
!E main.o(3612): Code address 0:0x1e5 already contains a value
!E main.o(3612): Code address 0:0x1e6 already contains a value
!E main.o(3612): Code address 0:0x1e7 already contains a value
!E main.o(3612): Code address 0:0x1e8 already contains a value
!E main.o(3612): Code address 0:0x1e9 already contains a value
C:\iccv7avr\bin\imakew.exe: Error code 1
Done: there are error(s). Exit code: 1. Thu Mar 08 13:17:32 2012
谢谢回复
 楼主| lnww 发表于 2012-3-11 12:17 | 显示全部楼层
已经解决
这是改原来别人的程序  许多相同的代码片段按顺序重复写。改成子程序的形式进行调用后就没有编译错误了
