STM32H750 QSPI内存映射模式不能随机访问
5560|4
 楼主| op07 发表于 2021-6-27 22:46 | 显示全部楼层 |阅读模式
我在使用W25Q128FV这个flash,stm32h750, qspi能读能写,数据OK,但是使用HAL_QSPI_MemoryMapped内存映射后,从地址0x9000000直接读取数据也正常,但是我想随意定一个地址开始读取数据,比如从0x90001000开始读取,就发现全是FF。按理说这个地址也在flash范围以内啊?这是个bug么?
 楼主| op07 发表于 2021-6-27 22:48 | 显示全部楼层
下面是我的内存映射代码:uint32_t QSPI_EnableMemoryMappedMode()
        QSPI_CommandTypeDef      s_command;
  QSPI_MemoryMappedTypeDef s_mem_mapped_cfg;
  /* Configure the command for the read instruction */
  s_command.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
  s_command.Instruction       =  Fast_Read_Quad;
  s_command.AddressMode       = QSPI_ADDRESS_4_LINES;
  s_command.AddressSize       = QSPI_ADDRESS_24_BITS;
  s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
  s_command.DataMode          = QSPI_DATA_4_LINES;
  s_command.DummyCycles       = 26;
  s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
  s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_HALF_CLK_DELAY;
  s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
        s_command.Address = 0;
        s_command.NbData            = 2;
  /* Configure the memory mapped mode */
  s_mem_mapped_cfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_DISABLE;
  s_mem_mapped_cfg.TimeOutPeriod     = 0;
  return HAL_QSPI_MemoryMapped(&hqspi, &s_command, &s_mem_mapped_cfg);
musich 发表于 2021-6-28 05:53 | 显示全部楼层
瞎猜一个,  是不是没有开启MPU保护
 楼主| op07 发表于 2021-6-28 22:02 | 显示全部楼层
瞎猜一个,  是不是没有开启MPU保护
MPU保护了也没用,应该不是这个问题
