[STM32H7] QSPI内存映射不能随机读取数据
2298|2
 楼主| op07 发表于 2021-6-28 22:09 | 显示全部楼层 |阅读模式
我在使用W25Q128FV这个flash,stm32h750, qspi能读能写,数据OK,但是使用HAL_QSPI_MemoryMapped内存映射后,从地址0x9000000直接读取数据也正常,但是我想随意定一个地址开始读取数据,比如从0x90001000开始读取,就发现全是FF。按理说这个地址也在flash范围以内啊?这是个bug么?
 楼主| op07 发表于 2021-6-28 22:10 | 显示全部楼层
下面是我内存映射代码,从0x90000000顺序读取,数据就是对的,从0x90001000读取就全是FF,跟MPU无关
uint32_t QSPI_EnableMemoryMappedMode()
        QSPI_CommandTypeDef      s_command;
  QSPI_MemoryMappedTypeDef s_mem_mapped_cfg;
  /* Configure the command for the read instruction */
  s_command.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
  s_command.Instruction       =  Fast_Read_Quad;
  s_command.AddressMode       = QSPI_ADDRESS_4_LINES;
  s_command.AddressSize       = QSPI_ADDRESS_24_BITS;
  s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
  s_command.DataMode          = QSPI_DATA_4_LINES;
  s_command.DummyCycles       = 26;
  s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
  s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_HALF_CLK_DELAY;
  s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
        s_command.Address = 0;
        s_command.NbData            = 1;
  /* Configure the memory mapped mode */
  s_mem_mapped_cfg.TimeOutActivation = QSPI_TIMEOUT_COUNTER_DISABLE;
  s_mem_mapped_cfg.TimeOutPeriod     = 0;
  return HAL_QSPI_MemoryMapped(&hqspi, &s_command, &s_mem_mapped_cfg);
carpsnow 发表于 2021-6-30 16:40 | 显示全部楼层
qspi是个啥呢?跟SPI区别大么
