[应用方案] N76E003 IIC OLED
2713|21
 楼主| 晓伍 发表于 2021-7-2 13:03 | 显示全部楼层 |阅读模式
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include  "math.h"
#include "oledfont.h"
#define u8 unsigned char
#define u32 unsigned int
/*SCL    P1.3
SDA      P1.4*/
#define OLED_SCLK_Clr() SCL=0
#define OLED_SCLK_Set() SCL=1
#define OLED_SDIN_Clr() SDA=0
#define OLED_SDIN_Set()        SDA=1
#define SYS_CLK_EN              0
#define SYS_SEL                 2
#define SYS_DIV_EN              0                   //0: Fsys=Fosc, 1: Fsys = Fosc/(2*CKDIV)
#define SYS_DIV                 1
#define I2C_CLOCK               2
#define TEST_OK                 0x00
bit I2C_Reset_Flag;
#define OLED_CMD  0        //写命令
#define OLED_DATA 1        //写数据
#define OLED_MODE 0
#define SIZE 16
#define XLevelL                0x02
#define XLevelH                0x10
#define Max_Column        128
#define Max_Row                64
#define        Brightness        0xFF
#define X_WIDTH         128
#define Y_WIDTH         64
//IIC GPIO Init
(必须配置为开漏模式,并加上拉电阻)
void Init_I2C(void)
                P13_OpenDrain_Mode;                                        // Modify SCL pin to Open drain mode. don't forget the pull high resister in circuit
                P14_OpenDrain_Mode;                                        // Modify SDA pin to Open drain mode. don't forget the pull high resister in circuit
    /* Set I2C clock rate */
    I2CLK = I2C_CLOCK;
    /* Enable I2C */
    set_I2CEN;
//IIC Start
void IIC_Start()
        OLED_SCLK_Set() ;
        OLED_SDIN_Set();
        OLED_SDIN_Clr();
        OLED_SCLK_Clr();
 楼主| 晓伍 发表于 2021-7-2 13:04 | 显示全部楼层
//IIC Stop
void IIC_Stop()
        OLED_SCLK_Set() ;
        OLED_SDIN_Clr();
        OLED_SDIN_Set();
 楼主| 晓伍 发表于 2021-7-2 13:05 | 显示全部楼层
//IIC Ack
void IIC_Wait_Ack()
                while(1)
                        if(!SDA)                                //判断是否接收到应答信号
                                break;
        OLED_SCLK_Set() ;
        OLED_SCLK_Clr();
 楼主| 晓伍 发表于 2021-7-2 13:06 | 显示全部楼层
// IIC Write byte
void Write_IIC_Byte(unsigned char IIC_Byte)
        unsigned char i;
        unsigned char m,da;
        da=IIC_Byte;
        OLED_SCLK_Clr();
        for(i=0;i<8;i++)
                        m=da;
                m=m&0x80;
                if(m==0x80)
                {OLED_SDIN_Set();}
                else OLED_SDIN_Clr();
                        da=da<<1;
                OLED_SCLK_Set();
                OLED_SCLK_Clr();
 楼主| 晓伍 发表于 2021-7-2 13:07 | 显示全部楼层
// IIC Write Command
void Write_IIC_Command(unsigned char IIC_Command)
   IIC_Start();
   Write_IIC_Byte(0x78);            //Slave address,SA0=0
        IIC_Wait_Ack();
   Write_IIC_Byte(0x00);                        //write command
        IIC_Wait_Ack();
   Write_IIC_Byte(IIC_Command);
        IIC_Wait_Ack();
   IIC_Stop();
 楼主| 晓伍 发表于 2021-7-2 13:08 | 显示全部楼层
// IIC Write Data
void Write_IIC_Data(unsigned char IIC_Data)
   IIC_Start();
   Write_IIC_Byte(0x78);                        //D/C#=0; R/W#=0
        IIC_Wait_Ack();
   Write_IIC_Byte(0x40);                        //write data
        IIC_Wait_Ack();
   Write_IIC_Byte(IIC_Data);
        IIC_Wait_Ack();
   IIC_Stop();
 楼主| 晓伍 发表于 2021-7-2 13:10 | 显示全部楼层
// IIC WriteReadCmd
void OLED_WR_Byte(unsigned dat,unsigned cmd)
        if(cmd)
   Write_IIC_Data(dat);
        else {
   Write_IIC_Command(dat);
 楼主| 晓伍 发表于 2021-7-2 13:11 | 显示全部楼层
// fill_Picture
void fill_picture(unsigned char fill_Data)
        unsigned char m,n;
        for(m=0;m<8;m++)
                OLED_WR_Byte(0xb0+m,0);                //page0-page1
                OLED_WR_Byte(0x00,0);                //low column start address
                OLED_WR_Byte(0x10,0);                //high column start address
                for(n=0;n<128;n++)
                                OLED_WR_Byte(fill_Data,1);
//坐标设置
        void OLED_Set_Pos(unsigned char x, unsigned char y)
{         OLED_WR_Byte(0xb0+y,OLED_CMD);
        OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
        OLED_WR_Byte((x&0x0f),OLED_CMD);
//开启OLED显示
void OLED_Display_On(void)
        OLED_WR_Byte(0X8D,OLED_CMD);  //SET DCDC命令
        OLED_WR_Byte(0X14,OLED_CMD);  //DCDC ON
        OLED_WR_Byte(0XAF,OLED_CMD);  //DISPLAY ON
//关闭OLED显示
void OLED_Display_Off(void)
        OLED_WR_Byte(0X10,OLED_CMD);  //DCDC OFF
        OLED_WR_Byte(0XAE,OLED_CMD);  //DISPLAY OFF
 楼主| 晓伍 发表于 2021-7-2 13:12 | 显示全部楼层
// OLED Clear Display
void OLED_Clear(void)
        u8 i,n;
        for(i=0;i<8;i++)
                OLED_WR_Byte (0xb0+i,OLED_CMD);    //设置页地址(0~7)
                OLED_WR_Byte (0x00,OLED_CMD);      //设置显示位置—列低地址
                OLED_WR_Byte (0x10,OLED_CMD);      //设置显示位置—列高地址
                for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
        } //更新显示
 楼主| 晓伍 发表于 2021-7-2 13:13 | 显示全部楼层
// OLED Update
void OLED_Update(void)
        u8 i,n;
        for(i=0;i<8;i++)
                for(n=0;n<128;n++)OLED_WR_Byte(1,OLED_DATA);
 楼主| 晓伍 发表于 2021-7-2 13:15 | 显示全部楼层
//OLED Display Char
//x:0~127
//y:0~63
//size:16/12
void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size)
        unsigned char c=0,i=0;
                c=chr-' ';//得到偏移后的值
                if(x>Max_Column-1){x=0;y=y+2;}
                if(Char_Size ==16)
                        OLED_Set_Pos(x,y);
                        for(i=0;i<8;i++)
                        OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
                        OLED_Set_Pos(x,y+1);
                        for(i=0;i<8;i++)
                        OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
                        else {
                                OLED_Set_Pos(x,y);
                                for(i=0;i<6;i++)
                                OLED_WR_Byte(F6x8[c][i],OLED_DATA);
 楼主| 晓伍 发表于 2021-7-2 13:16 | 显示全部楼层
//OLED Pow
u32 oled_pow(u8 m,u8 n)
        u32 result=1;
        while(n--)result*=m;
        return result;
 楼主| 晓伍 发表于 2021-7-2 13:17 | 显示全部楼层
//OLED Display Number
//x:0~127
//y:0~63
//num
//len
//size:16/12
void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 Num_size)
        u8 t,temp;
        u8 enshow=0;
        for(t=0;t<len;t++)
                temp=(num/oled_pow(10,len-t-1))%10;
                if(enshow==0&&t<(len-1))
                        if(temp==0)
                                OLED_ShowChar(x+(Num_size/2)*t,y,' ',Num_size);
                                continue;
                        }else enshow=1;
                 OLED_ShowChar(x+(Num_size/2)*t,y,temp+'0',Num_size);
 楼主| 晓伍 发表于 2021-7-2 13:18 | 显示全部楼层
//Show a String
void OLED_ShowString(u8 x,u8 y,u8 *chr,u8 Char_Size)
        unsigned char j=0;
        while (chr[j]!='\0')
        {                OLED_ShowChar(x,y,chr[j],Char_Size);
                        x+=8;
                if(x>120){x=0;y+=2;}
                        j++;
 楼主| 晓伍 发表于 2021-7-2 13:21 | 显示全部楼层
//Show  汉字
void OLED_ShowCHinese(u8 x,u8 y,u8 no)
        u8 t,adder=0;
        OLED_Set_Pos(x,y);
    for(t=0;t<16;t++)
                                OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
                                adder+=1;
    for(t=0;t<16;t++)
                                OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
                                adder+=1;
 楼主| 晓伍 发表于 2021-7-2 13:22 | 显示全部楼层
//Show Img
void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[])
unsigned int j=0;
unsigned char x,y;
  if(y1%8==0) y=y1/8;
  else y=y1/8+1;
        for(y=y0;y<y1;y++)
                OLED_Set_Pos(x0,y);
    for(x=x0;x<x1;x++)
                    OLED_WR_Byte(BMP[j++],OLED_DATA);
 楼主| 晓伍 发表于 2021-7-2 13:23 | 显示全部楼层
//Init OLED
void OLED_Init(void)
        Init_I2C();
        OLED_WR_Byte(0xAE,OLED_CMD);//--display off
        OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
        OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
        OLED_WR_Byte(0x40,OLED_CMD);//--set start line address
        OLED_WR_Byte(0xB0,OLED_CMD);//--set page address
        OLED_WR_Byte(0x81,OLED_CMD); // contract control
        OLED_WR_Byte(0xFF,OLED_CMD);//--128
        OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
        OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
        OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
        OLED_WR_Byte(0x3F,OLED_CMD);//--1/32 duty
        OLED_WR_Byte(0xC8,OLED_CMD);//Com scan direction
        OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset
        OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
        OLED_WR_Byte(0x80,OLED_CMD);//
        OLED_WR_Byte(0xD8,OLED_CMD);//set area color mode off
        OLED_WR_Byte(0x05,OLED_CMD);//
        OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
        OLED_WR_Byte(0xF1,OLED_CMD);//
        OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
        OLED_WR_Byte(0x12,OLED_CMD);//
        OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
        OLED_WR_Byte(0x30,OLED_CMD);//
        OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
        OLED_WR_Byte(0x14,OLED_CMD);//
        OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
 楼主| 晓伍 发表于 2021-7-2 13:24 | 显示全部楼层
void main()
        u8 t,Test=240;
                OLED_Init();//初始化OLED
                OLED_Clear();//清屏
                t=' ';
                OLED_ShowCHinese(1,0,3);//"电"汉字
                OLED_ShowString(1,2,"123AaBbCcDd",16);//显示字符串
                OLED_ShowNum(1,4,Test,3,16);//显示数据
                OLED_ShowChar(1,6,'A',16);
                while(1);
玛尼玛尼哄 发表于 2021-7-3 09:58 | 显示全部楼层
用IO模拟,非常方便移植
