GD32串口接收发送数据总结
4556|5
 楼主| 磨砂 发表于 2021-7-2 16:00 | 显示全部楼层 |阅读模式
在使用GD32串口接收数据的过程中,遇到了数据无法接收的问题,在导师的帮助下,需要调用usart_flag_get函数来使RBNE置1,RBNE:读数据时缓冲区非空,当数据缓存区接收到来自移位寄存器的数据时,该位置1. 0:读数据缓存区为空, 1:读数据缓存区不为空。主要代码如下:
while(1)  {
                          delay_1ms(400);
                      gd_eval_led_on(LED3);
                      delay_1ms(400);
                        gd_eval_led_off(LED3);
                          for ( i =0;i<16;i++)  {
                            vref_value[i]=adc_value[i]*3.3/4096;
                   **if(usart_flag_get(USART0,USART_FLAG_RBNE)==1) {
                            if(usart_data_receive(USART0)=='0') {**
                            delay_1ms(400);
                gd_eval_led_on(LED2);
                    printf("通道0的值为%5.3f\r\n",vref_value[0]);
 楼主| 磨砂 发表于 2021-7-2 16:01 | 显示全部楼层
使用GD32串口接收ADC通道的值代码如下:
/*GD32通过串口接收ADC通道的值,并打印出  */
    \file  main.c
    \brief USART printf demo
    Copyright (C) 2017 GigaDevice
    2017-06-23, V1.0.0, demo for GD32F30x
#include "gd32f30x.h"
#include "gd32f303c_eval.h"
#include "systick.h"
#include <stdio.h>
#include "gd32f30x_it.h"
uint16_t i;
float adc_value[16];
float vref_value[16];
uint16_t j;
void led_init(void);
void led_flash(int times);
void rcu_config(void);
void gpio_config(void);
void adc_config();
uint16_t adc_channel_sample(uint8_t channel);
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    /* initialize the LEDs */
    led_init();
    /* configure systick */
    systick_config();       //系统滴答定时器配置
    /* flash the LEDs for 1 time */
    led_flash(1);
    /* configure EVAL_COM1 */
    gd_eval_com_init(EVAL_COM1);
   rcu_config();
          gpio_config();
          adc_config();
    /* configure WAKEUP key */
    gd_eval_key_init(KEY_WAKEUP, KEY_MODE_GPIO);
    /* output a message on hyperterminal using printf function */
    printf("\r\n USART receive example: please transmit a number \r\n");
    /* wait for completion of USART transmission */
                    adc_value[0]=adc_channel_sample(ADC_CHANNEL_0);
                          adc_value[1]=adc_channel_sample(ADC_CHANNEL_1);
        adc_value[2]=adc_channel_sample(ADC_CHANNEL_2);
        adc_value[3]=adc_channel_sample(ADC_CHANNEL_3);
        adc_value[4]=adc_channel_sample(ADC_CHANNEL_4);
                          adc_value[5]=adc_channel_sample(ADC_CHANNEL_5);
                          adc_value[6]=adc_channel_sample(ADC_CHANNEL_6);
                          adc_value[7]=adc_channel_sample(ADC_CHANNEL_7);
                          adc_value[8]=adc_channel_sample(ADC_CHANNEL_8);
                          adc_value[9]=adc_channel_sample(ADC_CHANNEL_9);
                          adc_value[10]=adc_channel_sample(ADC_CHANNEL_10);
                          adc_value[11]=adc_channel_sample(ADC_CHANNEL_11);
                          adc_value[12]=adc_channel_sample(ADC_CHANNEL_12);
                          adc_value[13]=adc_channel_sample(ADC_CHANNEL_13);
                          adc_value[14]=adc_channel_sample(ADC_CHANNEL_14);
                          adc_value[15]=adc_channel_sample(ADC_CHANNEL_15);
                while(1){
                                  delay_1ms(400);
                      delay_1ms(400);
                                        //printf("请输入一个数\r\n");
                                        //scanf("%d\r\n",&j);
                            if(usart_data_receive(USART0)=='0'){
                                            delay_1ms(400);
           // printf("%d\r\n",usart_data_receive(USART0));
                                        else if(usart_data_receive(USART0)==1) {
              printf("通道1的值为%5.3f\r\n",vref_value[1]);
          else if(usart_data_receive(USART0)==2){
                                             printf("通道2的值为%5.3f\r\n",vref_value[2]);
          else if(usart_data_receive(USART0)==3) {
                                             printf("通道3的值为%5.3f\r\n",vref_value[3]);
          else if(usart_data_receive(USART0)==4) {
                                             printf("通道4的值为%5.3f\r\n",vref_value[4]);
                                        else if(usart_data_receive(USART0)==5) {
                                             printf("通道5的值为%5.3f\r\n",vref_value[5]);
                                        else if(usart_data_receive(USART0)==6) {
                                             printf("通道6的值为%5.3f\r\n",vref_value[6]);
                                        else if(usart_data_receive(USART0)==7) {
                                             printf("通道7的值为%5.3f\r\n",vref_value[7]);
                                        else if(usart_data_receive(USART0)==8) {
                                             printf("通道8的值为%5.3f\r\n",vref_value[8]);
                                        else if(usart_data_receive(USART0)==9) {
                                             printf("通道9的值为%5.3f\r\n",vref_value[9]);
                                        else if(usart_data_receive(USART0)==10) {
                                             printf("通道10的值为%5.3f\r\n",vref_value[10]);
                                        else if(usart_data_receive(USART0)==11) {
                                             printf("通道11的值为%5.3f\r\n",vref_value[11]);
          else if(usart_data_receive(USART0)==12) {
                                             printf("通道12的值为%5.3f\r\n",vref_value[12]);
          else if(usart_data_receive(USART0)==13) {
                                             printf("通道13的值为%5.3f\r\n",vref_value[13]);
          else if(usart_data_receive(USART0)==14) {
                                             printf("通道14的值为%5.3f\r\n",vref_value[14]);
          else if (usart_data_receive(USART0)==15){
                                                   printf("通道15的值为%5.3f\r\n",vref_value[15]);
          else {
                                                   printf("receive error\r\n");
 楼主| 磨砂 发表于 2021-7-2 16:02 | 显示全部楼层
    /* enable GPIOA clock */
    rcu_periph_clock_enable(RCU_GPIOA);
          rcu_periph_clock_enable(RCU_GPIOB);
          rcu_periph_clock_enable(RCU_GPIOC);
    /* enable ADC clock */
    rcu_periph_clock_enable(RCU_ADC0);
    /* config ADC clock */
    rcu_adc_clock_config(RCU_CKADC_CKAPB2_DIV6);
    /* config the GPIO as analog mode */
          gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_0);
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_1);
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_2);
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_3);
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_4);
          gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_5);
          gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_6);
          gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_7);
          gpio_init(GPIOB, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_0);
          gpio_init(GPIOB, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_1);
          gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_0);
          gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_1);
          gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_2);
    gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_3);
          gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_4);
          gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_10MHZ, GPIO_PIN_5);
 楼主| 磨砂 发表于 2021-7-2 16:03 | 显示全部楼层
void adc_config(void)
    /* ADC mode config */
    adc_mode_config(ADC_MODE_FREE);
    /* ADC data alignment config */
    adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT);
    /* ADC channel length config */
    adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 1U);
    /* ADC trigger config */
    adc_external_trigger_source_config(ADC0, ADC_REGULAR_CHANNEL, ADC0_1_2_EXTTRIG_REGULAR_NONE);
    /* ADC external trigger config */
    adc_external_trigger_config(ADC0, ADC_REGULAR_CHANNEL, ENABLE);
    /* enable ADC interface */
    adc_enable(ADC0);
    delay_1ms(1U);
    /* ADC calibration and reset calibration */
    adc_calibration_enable(ADC0);
 楼主| 磨砂 发表于 2021-7-2 16:05 | 显示全部楼层
    /* ADC regular channel config */
    adc_regular_channel_config(ADC0, 0U, channel, ADC_SAMPLETIME_7POINT5);      //adc规则通道配置
    /* ADC software trigger enable */
    adc_software_trigger_enable(ADC0, ADC_REGULAR_CHANNEL);                     //adc软件触发使能
    /* wait the end of conversion flag */
    while(!adc_flag_get(ADC0, ADC_FLAG_EOC));                              //等待转换完成标志
    /* clear the end of conversion flag */
    adc_flag_clear(ADC0, ADC_FLAG_EOC);                                     //清除转换完成标志
    /* return regular channel sample value */
    return (adc_regular_data_read(ADC0));                                    //返回规则通道样品值
    \brief      initialize the LEDs
    \param[in]  none
    \param[out] none
    \retval     none
void led_init(void)
    gd_eval_led_init(LED2);
    gd_eval_led_init(LED3);
    gd_eval_led_init(LED4);
    gd_eval_led_init(LED5);
 楼主| 磨砂 发表于 2021-7-2 16:06 | 显示全部楼层
    \brief      flash the LEDs for test
    \param[in]  times: times to flash the LEDs
    \param[out] none
    \retval     none
    int i;
    for(i=0; i<times; i++){
        /* delay 400 ms */
        delay_1ms(400);
        /* turn on LEDs */
        gd_eval_led_on(LED4);
        gd_eval_led_on(LED5);
        /* delay 400 ms */
        delay_1ms(400);
        /* turn off LEDs */
        gd_eval_led_off(LED2);
        gd_eval_led_off(LED4);
        gd_eval_led_off(LED5);
/* retarget the C library printf function to the USART */
int fputc(int ch, FILE *f)
    usart_data_transmit(EVAL_COM1, (uint8_t)ch);
    while(RESET == usart_flag_get(EVAL_COM1, USART_FLAG_TBE));
    return ch;
