[STM32F4] stm32f407 hal库如何启用HS
830|8
 楼主| zwll 发表于 2021-7-4 12:53 | 显示全部楼层 |阅读模式
RCC_OscInitStructure.OscillatorType=RCC_OSCILLATORTYPE_HSI;    //时钟源为HSE
    RCC_OscInitStructure.HSEState=RCC_HSI_ON;                      //打开HSE
    RCC_OscInitStructure.PLL.PLLState=RCC_PLL_ON;//打开PLL
    RCC_OscInitStructure.PLL.PLLSource=RCC_PLLSOURCE_HSI;//PLL时钟源选择HSE
    RCC_OscInitStructure.PLL.PLLM=16; //主PLL和音频PLL分频系数(PLL之前的分频),取值范围:2~63.
    RCC_OscInitStructure.PLL.PLLN=plln; //主PLL倍频系数(PLL倍频),取值范围:64~432.
    RCC_OscInitStructure.PLL.PLLP=pllp; //系统时钟的主PLL分频系数(PLL之后的分频),取值范围:2,4,6,8.(仅限这4个值!)
    RCC_OscInitStructure.PLL.PLLQ=pllq; //USB/SDIO/随机数产生器等的主PLL分频系数(PLL之后的分频),取值范围:2~15.
    ret=HAL_RCC_OscConfig(&RCC_OscInitStructure);//初始化
不知为何老通不过这儿  if(ret!=HAL_OK) while(1);????请高手指点下
juventus9554 发表于 2021-7-4 12:54 | 显示全部楼层
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
supernan 发表于 2021-7-4 12:56 | 显示全部楼层
板卡是哪个板卡?不通是没有道理的
 楼主| zwll 发表于 2021-7-4 12:58 | 显示全部楼层
代码可以用啦,谢谢!
heweibig 发表于 2021-7-4 13:00 | 显示全部楼层
看看晶振起振了吗
lizye 发表于 2021-7-4 13:01 | 显示全部楼层
用示波器看看晶振波形
lizye 发表于 2021-7-4 13:03 | 显示全部楼层
用的什么晶振啊
spark周 发表于 2021-7-4 13:05 | 显示全部楼层
不太清楚到底是什么问题
 楼主| zwll 发表于 2021-7-4 13:07 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
