[研电赛技术支持] GD32F350CBT6 RTC以两倍速度运行怎么回事?
3600|2
 楼主| ypp240124016 发表于 2021-7-5 15:05 | 显示全部楼层 |阅读模式
rtc, RTC, rc, ni, ck, se
描述 :RTC初始化
输入 :
输出 :
void drv_rtc_init(void)
#ifdef        USE_RTC
__IO uint32_t prescaler_a = 0, prescaler_s = 0;
  rcu_periph_clock_enable(RCU_PMU);
  pmu_backup_write_enable();
  #if defined (RTC_CLOCK_SOURCE_IRC40K)
    rcu_osci_on(RCU_IRC40K);
    rcu_osci_stab_wait(RCU_IRC40K);
    rcu_rtc_clock_config(RCU_RTCSRC_IRC40K);
    prescaler_s = 0x18F;
    prescaler_a = 0x63;
  #elif defined (RTC_CLOCK_SOURCE_LXTAL)
    rcu_osci_on(RCU_LXTAL);
    rcu_osci_stab_wait(RCU_LXTAL);
    rcu_rtc_clock_config(RCU_RTCSRC_LXTAL);
    prescaler_s = 0xFF;
    prescaler_a = 0x7F;
  #else
    #error RTC clock source should be defined.
  #endif /* RTC_CLOCK_SOURCE_IRC40K */
  rcu_periph_clock_enable(RCU_RTC);
  rtc_register_sync_wait();
  if(BKP_VALUE != RTC_BKP0)
    rtc_parameter_struct rtc_initpara;
    rtc_initpara.rtc_factor_asyn = prescaler_a;
    rtc_initpara.rtc_factor_syn = prescaler_s;
    rtc_initpara.rtc_year = 0x16;
    rtc_initpara.rtc_day_of_week = RTC_SATURDAY;
    rtc_initpara.rtc_month = RTC_APR;
    rtc_initpara.rtc_date = 0x30;
    rtc_initpara.rtc_display_format = RTC_24HOUR;
    rtc_initpara.rtc_am_pm = RTC_AM;
    rtc_initpara.rtc_hour = 0;
    rtc_initpara.rtc_minute = 0;
    rtc_initpara.rtc_second = 0;
    if(ERROR == rtc_init(&rtc_initpara))
      printf("\n\r** RTC time configuration failed! **\n\r");
    else
      printf("\n\r** RTC time configuration success! **\n\r");
      RTC_BKP0 = BKP_VALUE;
        else
                printf("RTC continue!\n");
#endif
以上是初始化代码,我设置了一个时间后,然后每隔5S打印一次获取到的RTC时间,发现RTC时间的间隔是10S,也就是以正常两倍的速度在运行。
以下是串口打印输出的内容。
[15:02:26.941] app sec counter=175s
[15:02:26.941] hour=12, min=55, sec=24
[15:02:26.941] ***2021-07-05 12:55:24
[15:02:26.941] rtc_time=1625460924s
[15:02:26.947]
[15:02:31.940] app sec counter=180s
[15:02:31.950] hour=12, min=55, sec=34
[15:02:31.950] ***2021-07-05 12:55:34
[15:02:31.950] rtc_time=1625460934s
sonicll 发表于 2021-7-5 16:17 | 显示全部楼层
你RTC的时钟源用的是IRC40K还是LXTAL?如果用的是LXTAL,频率准吗,是32.768K吗?
 楼主| ypp240124016 发表于 2021-7-5 16:28 | 显示全部楼层
你RTC的时钟源用的是IRC40K还是LXTAL?如果用的是LXTAL,频率准吗,是32.768K吗? ...
内外两种都试过了 效果一样,外部晶振是32.768K的
