[应用相关] F103C8T6 GY-30 光强采集 正点原子版
2758|36
 楼主| drer 发表于 2021-7-5 16:13 | 显示全部楼层 |阅读模式
硬件见下图:
watermark,type_ZmFuZ3poZW5naGVpdGk,shadow_10,text_aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L3gxMTMxMjMwMTIz,size_16,color_FFFFFF,t_70.jpg
 楼主| drer 发表于 2021-7-5 16:15 | 显示全部楼层
BH1750.c
#include "BH1750.h"
void GPIOConfig( void )
        GPIO_InitTypeDef GPIO_InitStruct;
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );
        GPIO_InitStruct.GPIO_Mode        = GPIO_Mode_Out_PP;
        GPIO_InitStruct.GPIO_Speed        = GPIO_Speed_50MHz;
        GPIO_InitStruct.GPIO_Pin        = sda | scl;
        GPIO_Init( GPIOA, &GPIO_InitStruct );
void Delay_5us( void )
        delay_us(5);
void Delay_mms( unsigned int tmp )
        unsigned int i = 0;
        while ( tmp-- )
                delay_ms(1);
 楼主| drer 发表于 2021-7-5 16:16 | 显示全部楼层
void BH1750_Start()
        GPIO_SetBits( GPIOA, sda );
        GPIO_SetBits( GPIOA, scl );
        Delay_5us();
        GPIO_ResetBits( GPIOA, sda );
        Delay_5us();
        GPIO_ResetBits( GPIOA, scl );
void BH1750_Stop()
        Delay_5us();
        Delay_5us();
 楼主| drer 发表于 2021-7-5 16:18 | 显示全部楼层
void BH1750_SendACK( unsigned int ack )
        GPIO_InitStruct.GPIO_Pin        = sda;
        if ( ack == 1 )
        else if ( ack == 0 )
        else
                return;
        Delay_5us();
        Delay_5us();
unsigned int BH1750_RecvACK()
        GPIO_InitStruct.GPIO_Mode        = GPIO_Mode_IPU;
        Delay_5us();
        if ( GPIO_ReadInputDataBit( GPIOA, sda ) == 1 )
                mcy = 1;
        else
                mcy = 0;
        Delay_5us();
        return(mcy);
 楼主| drer 发表于 2021-7-5 16:19 | 显示全部楼层
void BH1750_SendByte( unsigned char dat )
        unsigned char i;
        for ( i = 0; i < 8; i++ )
                if ( 0X80 & dat )
                else
                dat <<= 1;
                Delay_5us();
                Delay_5us();
        BH1750_RecvACK();
unsigned char BH1750_RecvByte()
        unsigned char        i;
        unsigned char        dat = 0;
        unsigned char        bit;
                dat <<= 1;
                Delay_5us();
                if ( SET == GPIO_ReadInputDataBit( GPIOA, sda ) )
                        bit = 0X01;
                else
                        bit = 0x00;
                dat |= bit;
                Delay_5us();
        return(dat);
 楼主| drer 发表于 2021-7-5 16:20 | 显示全部楼层
void Single_Write_BH1750( unsigned char REG_Address )
        BH1750_Start();
        BH1750_SendByte( SlaveAddress );
        BH1750_SendByte( REG_Address );
        /*  BH1750_SendByte(REG_data);
        BH1750_Stop();
 楼主| drer 发表于 2021-7-5 16:21 | 显示全部楼层
void Init_BH1750()
        GPIOConfig();
        Single_Write_BH1750( 0x01 );
 楼主| drer 发表于 2021-7-5 16:22 | 显示全部楼层
void mread( void )
        unsigned char i;
        BH1750_Start();
        BH1750_SendByte( SlaveAddress + 1 );
        for ( i = 0; i < 3; i++ )
                BUF[i] = BH1750_RecvByte();
                if ( i == 3 )
                        BH1750_SendACK( 1 );
                }else  {
                        BH1750_SendACK( 0 );
        BH1750_Stop();
        Delay_mms( 5 );
BH1750.h
#ifndef __BH1750_H__
#define __BH1750_H__
#include "sys.h"
#define sda        GPIO_Pin_4
#define scl        GPIO_Pin_3
#define   SlaveAddress 0x46
extern unsigned char        BUF[8];
extern int        dis_data;
extern int        mcy;
void Init_BH1750( void );
void conversion( unsigned int temp_data );
void Single_Write_BH1750( unsigned char REG_Address );
unsigned char Single_Read_BH1750( unsigned char REG_Address );
void mread( void );
void Delay_5us( void );
void Delay_mms( unsigned int tmp );
void GPIOConfig( void );
#endif
 楼主| drer 发表于 2021-7-5 16:23 | 显示全部楼层
使用:
  • 在main.c里面#include “BH1750.h”
  • 在main.c里声明下面几个全局变量
int                dis_data;
int                mcy;
float                lightPower;
  • 在main.c里初始化 Init_BH1750(); /* init BH1750 */
  • 在while(1)里面,得出的lightPower就是光强 单位是lx
        delay_ms( 5 );
                t++;
                if ( t > 40 )
                        mread();
                        dis_data        = BUF[0];
                        dis_data        = (dis_data << 8) + BUF[1];
                        lightPower        = (float) dis_data / 1.2;
                        Single_Write_BH1750( 0x10 );
                        display();
                        t = 0;
 楼主| drer 发表于 2021-7-5 16:24 | 显示全部楼层
参考main.c
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "timer.h"
#include  "oled.h"      /* oled */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "BH1750.h"
int                dis_data;
int                mcy;
float                lightPower;
extern struct ds1302time time;
char        xianshi[30];
u8        tmp_buf[33];
void display( void )
        memset( xianshi, 0, sizeof(xianshi) );
        sprintf( xianshi, "%02d:%02d:%02d", time.hour, time.minute, time.second );
        OLED_P8x16Str( 0, 2, xianshi, 0 );
        sprintf( xianshi, "%.1f", lightPower );
        OLED_P8x16Str( 0, 4, xianshi, 0 );
 楼主| drer 发表于 2021-7-5 16:25 | 显示全部楼层
int main( void )
        u8        t                = 0;
        NVIC_PriorityGroupConfig( NVIC_PriorityGroup_2 );
        delay_init();
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_AFIO, ENABLE );
        GPIO_PinRemapConfig( GPIO_Remap_SWJ_JTAGDisable, ENABLE );
        uart_init( 9600 );
        Init_BH1750();
        while ( 1 )
                delay_ms( 5 );
                t++;
                if ( t > 40 )
                        mread();
                        dis_data        = BUF[0];
                        display();
                        t = 0;
仰望星期五 发表于 2021-7-6 08:22 | 显示全部楼层
楼主做的什么项目用的
仰望星期五 发表于 2021-7-6 08:23 | 显示全部楼层
APDS9930,这个接触过没,也是IIC,我之前调试过一次,没有成功,有空还得看看。
usysm 发表于 2021-7-6 16:24 | 显示全部楼层
这个就是ADC吧
typeof 发表于 2021-7-6 16:24 | 显示全部楼层
光敏电阻如何采集光强
yujielun 发表于 2021-7-6 16:25 | 显示全部楼层
除了光敏电阻,还有什么可以进行光照采集
