01. LT6911GX
1)HDMI 2.1 Receiver *compliant with HDMI 2.1 specification. *support 8K@30Hz,8K@60Hz with DSC. *support HDR 2) Single/Dual/Quad-port MIPI DSI/CSITransmitter. *Side-by-side 3D support *support CSI D-option 8 Lane output 3)Miscellaneous * Zoom scaling up and down. * Support Rotation(Max 1080P) 4) Package:BGA169(9*9)
02.LT6911C
1)HDMI 1.4 Receiver *Compliant with HDMI 1.4,up to 4K@30. *Support HDCP 1.4 2)MIPI CSI/DSI Transmitter *1/2/4 configurable ports *80Mb/s-1.5Gb/s per data lane. *Side-by-Side 3D support. 3)Voltage:3.3V&1.2V 4)Package: QFN64(7.5*7.5)
03.LT8619C
•SupportHDMI 1.4/Dual Mode DP input. •Supportresolution up to 4K. •SupportDDRoutput. •Voltage:3.3V&1.8V •Package:QFN76(9*9)
04.LT9721
*Single-Port MIPI receiver up to 1080P@60Hz for RGB format and 4K@30 Hz for YUV420 format. *HDMI 1.4 receiver up to 4K*2K@30Hz forRGB format and 4K@30 Hz for YUV420 format. *DP 1.2 Transmitter up to 4K*2K@60. *USB Type-C output interface. *Voltage: 3.3V&1.8V *Package:QFN64(7.5*7.5)
05.LT8711UX
1)USB Type-C *Compliant with DP Alt Mode 1.0,PD2.0,Type-C 1.2,HDMI 1.4b Alt Mode 1.0. *Daul CCcontrollers. 2)DP Receiver *Compliant with DP 1.2 HDCP 1.3. 3)HDMI Transmitter *Compliant with HDMI 2.0/1.4,DVI 1.0,HDMI 2.2/1.4 *6G bps *4K@60Hz 4)Voltage:3.3V&1.2V 5)Package:QFN88(10*10)
06.LT8711HE
1)USB Type-C *Compliant with USB Power Deliver specification R2.0,V1.0. 2)DP 1.2 Receiver *1.62/2.7/5.4 Gbps perdata lane. 3)HDMI 2.0 Transmitter *Data rate up to 6Gbps. *Support 4K@60Hz. 4)HDMI 2.0 Transmitter. *Date rate up to 6Gbps. *Support 4K@60. *USB billboard module and USB2.0 switch integrated. 5)Voltage:3.3V&1.2V 6)Package(7.5*7.5)
07.LT7911D
1)TYPE-C/DP 1.2 Receiver *Compliantwith DP 1.2 for 1.62Gb/s,2.7Gb/s,5.4Gb/s,up to 4K@60Hz. 2)MIPI CSI/DSI Transmitter. *1/2/4 configurable port *80Mb/s-1.5Gb/s per data lane. *Side-by-side 3D support. 3)Voltage:3.3V&1.2V 4)Package:QFN64(7.5*7.5)
08.LT8918
*Support 24-bit RGB and BT656/BT1120input. *Resolution up to 1080P@60Hz *Voltage:1.8V *Package:QFN64(7.5*7.5)
09.LT8911EX/LT8911EXB
1)LT8911EX *Support single/Dual LVDS input. *Maximum 1.2Gb/s per data lane. *Support 6-bit or 8-bit input color depth. 2)LT8911EXB *Support single port MIPI CSI/DSI input. *Clock lane and 1-4 configurable data lanes. *80Mb/s-2.0Gb/s per data lane. *Support 16/18/24/30/36 bit RGB format. 3)Voltage: 1.8V 4)Package:QFN48 (9*9)/QFN64(6*6)
10.LT8912B
*Compliant with HDMI 1.4. *Support MIPI DSI Non-Burst Mode(continueMode). *Video Scaler on LVDS path. *Single to dual outputs. *Voltage:1.8V *Package:QFN64(7.5*7.5)
11.LT9211
1)MIPI/LVDSinput mux and output split supported. 2)MIPI/LVDS bypass Single Level shift forFPGA. 3)Up to 1080P@60Hz. 4)Voltage:3.3V&1.8V 5)Package:QFN64(7.5*7.5)
12、联系我们
深圳市新龙鹏科技有限公司 公司地址:深圳市宝安区中粮商务公园2栋1102,1103,1103A,1107室 电话:0755-33673997 传真:0755-33673910
新龙鹏公司**以客户为中心,积极面对未来,不断创新进取,以雄厚的专业实力,优良的服务品质,致力于成为国内一流的芯片供应商,专业的电子产品设计企业。诚愿与各界朋友紧密合作,携手发展,共创美好未来。
