1.ARM寄å˜å™¨ä¿®æ”¹ï¼Œç¡®è®¤FW.s里SMRDATA DATAæ˜¯å¦æ˜¯è®¾çš„BANKSIZE为128M(默认为128M)还有B6_SCAN设为10BIT<br />2.MAP.aé‡ŒæŠŠåœ°å€æ”¹æˆæ”¯æŒ128Mçš„<br />DCD 0x80000000, 0x02000000, 30 ; 30 MB SRAM(SRAM/ROM) BANK 0<br /> DCD 0x82000000, 0x08000000, 8 ; 32 MB SROM(SRAM/ROM) BANK 1<br /> DCD 0x83000000, 0x0be00000, 2 ; 32 MB SROM(SRAM/ROM) BANK 1<br /> DCD 0x84000000, 0x10000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 2<br /> DCD 0x86000000, 0x18000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 3<br /> DCD 0x87000000, 0x20000000, 1 ; 32 MB SROM(SRAM/ROM) BANK 4<br /> DCD 0x87800000, 0x28000000, 1 ; 32 MB SROM(SRAM/ROM) BANK 5<br /> DCD 0x88000000, 0x30000000, 128 ; 64 MB DRAM BANK 0, 1<br /> DCD 0x90800000, 0x48000000, 1 ; Memory control register<br /> DCD 0x90900000, 0x49000000, 1 ; USB Host register<br /> DCD 0x90A00000, 0x4A000000, 1 ; Interrupt Control register<br /> DCD 0x90B00000, 0x4B000000, 1 ; DMA control register<br /> DCD 0x90C00000, 0x4C000000, 1 ; Clock & Power register<br /> DCD 0x90D00000, 0x4D000000, 1 ; LCD control register<br /> DCD 0x90E00000, 0x4E000000, 1 ; NAND flash control register<br /> DCD 0x90F00000, 0x4F000000, 1 ; Camera control register <br /> DCD 0x91000000, 0x50000000, 1 ; UART control register<br /> DCD 0x91100000, 0x51000000, 1 ; PWM timer register<br /> DCD 0x91200000, 0x52000000, 1 ; USB device register<br /> DCD 0x91300000, 0x53000000, 1 ; Watchdog Timer register<br /> DCD 0x91400000, 0x54000000, 1 ; IIC control register<br /> DCD 0x91500000, 0x55000000, 1 ; IIS control register<br /> DCD 0x91600000, 0x56000000, 1 ; I/O Port register<br /> DCD 0x91700000, 0x57000000, 1 ; RTC control register<br /> DCD 0x91800000, 0x58000000, 1 ; A/D convert register<br /> DCD 0x91900000, 0x59000000, 1 ; SPI register<br /> DCD 0x91A00000, 0x5A000000, 1 ; SD Interface register<br /> DCD 0x91B00000, 0x5B000000, 1 ; AC97 Interface register<br /> DCD 0x92000000, 0x00000000, 32 ; 32 MB SROM(SRAM/ROM) BANK 0<br /> DCD 0x00000000, 0x00000000, 0 ; End of Table (MB MUST BE ZERO!)<br />3.config.bib 里改æˆä»¥ä¸‹ï¼š<br />MEMORY<br /><br />;#define CHAIN_ADDRESS 81E40000<br />; CHAIN $(CHAIN_ADDRESS) 00001000 RESERVED<br />; pdwXIPLoc 00000000 $(CHAIN_ADDRESS) FIXUPVAR<br /><br />;;; Tarzan Debug mode <br /> NK 88200000 01e00000 RAMIMAGE<br />; NK 80040000 01E00000 RAMIMAGE<br />; CHAIN 81E40000 00001000 RESERVED<br />; DRIVERS 81E41000 001BF000 RAMIMAGE<br /><br />; RESERVE 8df00000 00080000<br />; RAM 8c200000 01D00000 RAM<br /> RAM 8a000000 06000000 RAM<br /><br /><br />; Common RAM areas<br /> AUD_DMA 88002000 00002000 RESERVED <br /> DRV_GLB 88010000 00010000 RESERVED<br />; DBGSER_DMA 88022000 00002000 RESERVED<br />; SER_DMA 88024000 00002000 RESERVED<br />; IR_DMA 88026000 00002000 RESERVED<br /> SD_DMA 88028000 00008000 RESERVED<br /><br /> EDBG 88030000 00020000 RESERVED<br />; CAMERA 88050000 000A0000 RESERVED<br />; CAMERA 88088000 00140000 RESERVED<br /> DISPLAY 88100000 00100000 RESERVED <br />; DISPLAY 881d0000 00030000 RESERVED <br /><br /><br />CONFIG<br /><br /> COMPRESSION=ON<br /> KERNELFIXUPS=ON<br /><br />IF IMGPROFILER <br /> PROFILE=ON<br />ENDIF<br /><br />IF IMGPROFILER !<br /> PROFILE=OFF<br />ENDIF<br /><br />IF IMGTRUSTROMONLY<br /> IF IMGNOTALLKMODE<br /> ROMFLAGS=12<br /> ENDIF<br /> IF IMGNOTALLKMODE !<br /> ROMFLAGS=10<br /> ENDIF<br />ENDIF<br /><br />IF IMGTRUSTROMONLY !<br /> IF IMGNOTALLKMODE<br /> ROMFLAGS=2<br /> ENDIF<br /> IF IMGNOTALLKMODE !<br /> ROMFLAGS=0<br /> ENDIF<br />ENDIF<br /><br /> ROMSTART=88200000 <br /> ROMWIDTH=32<br /> ROMSIZE=01e00000<br />4.æœ€åŽæŠŠBSP里所有的和config.bib里相冲çªçš„æ”¹è¿‡æ¥<br /> ok,this is all <br /><br /><br />我们æä¾›å›½å†…最低价的ARM工控主æ¿ï¼Œè¿è¡ŒWINCE或者linuxæ“作系统,å¯ä»¥æ ¹æ®å®¢æˆ·éœ€æ±‚定制,有需è¦çš„请è”系我们<br />è”系电è¯ï¼š021-58443893<br />13918260860<br />MSN:nandcon@hotmail.com<br />QQ:413519861<br /><br />1.SM501扩展(国内第一个æä¾›æ¤æ‰©å±•,包括北京普光,深圳迅龙,æå·ž..æå·ž..çš„æ¿å都æºäºŽæ¤ï¼‰<br /> 扩展sm501坿供2Dç¡¬ä»¶åŠ é€ŸåŠŸèƒ½ï¼Œæ”¯æŒå¤§å±å¹•çš„VGA,分辨率最大å¯è¾¾1280x1024,刷新率å¯ä»¥è¾¾åˆ°85HZ,支æŒå¤šç§LCD,包括800x480的宽å±<br />2.DM9000A扩展支æŒ10/100M以太网,æä¾›æ®äºŽè½¯ä»¶æˆ–者硬件的MAC地å€å˜å‚¨<br />3.支æŒå„ç±»LCD,包括7'模拟å±ï¼Œ7‘’数å—宽å±<br />4.釿–°ç¼–写的WINCE4.2 SDå¡é©±åŠ¨å½»åº•è§£å†³samsungæä¾›çš„SDå¡é©±åŠ¨çš„BUG<br />5.支æŒå„ç±»512å—节,åŠ2048å—节的 nandflash (WINCE4.2䏿”¯æŒ2K页的nandflash)<br />6.支æŒ64M或者128Mçš„SDRAM<br />7.æä¾›IIS接å£çš„音频输入输出,如ä¸éœ€è¦éŸ³é¢‘输入å¯ç”¨å¦å¤–ä¸€ç§æ›´ä½Žä»·çš„音频输出<br />8.支æŒATA接å£ï¼Œå¯ä»¥æ”¯æŒå„ç§å®¹é‡çš„硬盘( EP9315,S3C2440,S3C2410都支æŒï¼‰<br />9.å„类通讯接å£ï¼ŒåŒ…括RS232,RS485,RS422<br />10.居于SJA1000Tçš„CAN接å£<br />11,PS/2键盘接å£<br />12ã€‚å¹¶è¡Œå£æŽ¥å£<br />13.软盘驱动接å£<br />14.WIFI功能(SDå¡ï¼ŒUSB)<br />15.支æŒå„ç±»è§¦æ‘¸å±æŽ¥å£<br />16,USB hoståŠslave接å£<br />17。摄åƒå¤´æŽ¥å£ï¼ˆUSB或者S3C2440本身自带的camera接å£ï¼‰<br /><br />以下列出的一些å“ç§OEMå¤§è‡´ä»·æ ¼(100片的报价)(LCD为全新A级)<br />S3C2440+7'æ¨¡æ‹Ÿå± 1200<br />S3C2440+SM501 +7'模拟å±ï¼ˆ480x234) 1400<br />S3C2440+SM501 +7'æ•°å—宽å±(800x480) 1800<br />S3C2410+7'æ¨¡æ‹Ÿå± 1100<br />S3C2440+SM501 +7'模拟å±ï¼ˆ480x234) 1300<br />S3C2440+SM501 +7'æ•°å—宽å±(800x480) 1700 |
