新手求助!STM32F407中断无法实现
15725|2
 楼主| Flareon 发表于 2021-7-25 13:14 | 显示全部楼层 |阅读模式
本人刚入门STM32F4系列(开发板为STM32F407VET6),在学习中断这一章节的时候出现了些问题.
拟设计代码实现功能: 使用中断完成 按下按键后led灯由点亮转向熄灭
问题: 编写完成代码后无法实现该功能
开发板部分原理图如下:(“LED指示灯”和“用户按键”)
设置按下K1按键(PE3)后,D3的LED灯熄灭(PA7)
以下为个人编写代码,可能会有不规范的地方,望见谅
#include "stm32f4xx.h"
#define PAout(n) *(volatile uint32_t *)(0x42000000 + (GPIOA_BASE + 0x10 - 0x40000000)*32 + n*4)
static GPIO_InitTypeDef GPIO_InitStructure;
static EXTI_InitTypeDef EXTI_InitStructure;
static NVIC_InitTypeDef NVIC_InitStructure;
//中断服务函数;
void EXTI3_IRQHandler(void) {
        if (EXTI_GetITStatus(EXTI_Line3) == SET) {
                PAout(7) = 1;
        EXTI_ClearITPendingBit(EXTI_Line3);
int main(void) {
        //初始化led灯;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        //以下设置外部中断;
        //初始化按键;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        //按下按键的外部中断设置;
        RCC_AHB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);//系统时钟;
        SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOE, EXTI_PinSource3);        //设置PE3作为外部中断按键;
        EXTI_InitStructure.EXTI_Line = EXTI_Line3;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        //配置外部中断的NVIC;
        NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x08;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x08;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        while(1){
                PAout(7) = 0;
恳请大佬帮忙分析解决(已被困扰一天)
谢谢!!!
yueguang3048 发表于 2021-8-19 15:30 | 显示全部楼层
main函数初始化PA7的时候置0,保证灯初始化完成是亮的,
while函数在循环执行亮灯操作。
按键后进中断即便灭灯,但时间太短(进出中断很快的),主函数的while会很快就亮灯,你会看不到。
可以考虑在while(1)加延时。 或者改变CPU的运行速率,让它很慢....不可取
爱情海玩偶 发表于 2021-8-20 08:59 | 显示全部楼层
楼上正解
