[技术问答]
UART0使用 64Bytes FIFO
2310|2
麻花油条|  楼主 | 2021-7-26 10:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大大安安,
官方TRM中提到NUC230/240的UART0有提供到64 Bytes的接收缓冲区,UART1及UART2只提供了16Bytes的接收缓冲区,但uart.h文件中RFITL设定仅供到14 Bytes
想问如果想使用64 Bytes FIFO该如何设定,谢谢
/* UART FIFO size constants definitions        */
#define UART0_FIFO_SIZE 64 /*!< UART0 supports separated receive/transmit 64/64 bytes entry FIFO */
#define UART1_FIFO_SIZE 16 /*!< UART1 supports separated receive/transmit 16/16 bytes entry FIFO */
#define UART2_FIFO_SIZE 16 /*!< UART2 supports separated receive/transmit 16/16 bytes entry FIFO */
/* UA_FCR constants definitions        */
#define UART_FCR_RFITL_1BYTE        (0x0 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 1 bit */
#define UART_FCR_RFITL_4BYTES       (0x1 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 4 bits */
#define UART_FCR_RFITL_8BYTES       (0x2 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 8 bits */
#define UART_FCR_RFITL_14BYTES      (0x3 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 14 bits */
#define UART_FCR_RTS_TRI_LEV_1BYTE        (0x0 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 1 bit */
#define UART_FCR_RTS_TRI_LEV_4BYTES       (0x1 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 4 bits */
#define UART_FCR_RTS_TRI_LEV_8BYTES       (0x2 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 8 bits */
#define UART_FCR_RTS_TRI_LEV_14BYTES      (0x3 << UART_FCR_RTS_TRI_LEV_Pos)  /*!< UA_FCR setting to set RTS Trigger Level to 14 bits */
laocuo1142| | 2021-8-4 15:15 | 只看该作者
uart.h里宏定义没定时64字节的,可以直接写数字修改寄存器的值,也可以自己先添加上宏定义再调用
flycamelaaa| | 2021-8-4 15:15 | 只看该作者
#define UART_FCR_RFITL_64BYTES      (0x6 << UART_FCR_RFITL_Pos)   /*!< UA_FCR setting to set RX FIFO Trigger Level to 64 bits */
