[技术问答] 新唐ML51EB9AE的P5端口怎么定义,sbit P51 = P5^1是错的
2904|2
 楼主| rwbycc 发表于 2021-7-27 11:08 | 显示全部楼层 |阅读模式
P5端口不能位寻址
jasontu 发表于 2021-8-3 09:01 | 显示全部楼层
P5 cann't bit addressable
#define clr_IAPCN_FCTRL_0                SFRS=0;IAPCN&=0xFE
/**** P5  B1H  PAGE 0 ****/
#define set_P5_7                         SFRS=0;P5|=0x80
#define set_P5_6                         SFRS=0;P5|=0x40
#define set_P5_5                         SFRS=0;P5|=0x20
#define set_P5_4                         SFRS=0;P5|=0x10
#define set_P5_3                         SFRS=0;P5|=0x08
#define set_P5_2                         SFRS=0;P5|=0x04
#define set_P5_1                         SFRS=0;P5|=0x02
#define set_P5_0                         SFRS=0;P5|=0x01
#define clr_P5_7                         SFRS=0;P5&=0x7F
#define clr_P5_6                         SFRS=0;P5&=0xBF
#define clr_P5_5                         SFRS=0;P5&=0xDF
#define clr_P5_4                         SFRS=0;P5&=0xEF
#define clr_P5_3                         SFRS=0;P5&=0xF7
#define clr_P5_2                         SFRS=0;P5&=0xFB
#define clr_P5_1                         SFRS=0;P5&=0xFD
#define clr_P5_0                         SFRS=0;P5&=0xFE
 楼主| rwbycc 发表于 2021-8-4 10:17 | 显示全部楼层
好的,谢谢!
