sc92f7323_LCD显示
934|0
 楼主| 34af9uc 发表于 2021-8-17 23:48 | 显示全部楼层 |阅读模式
/***************SC92F7323+LCD88888*****************/
/***************QQ:74145445************************/
/*************快手:共同学习STM8********************/
/*************keiluvision2*************************/
/*************20210808*****************************/
//                  lcd88888
//|1|2|3|4|5|6|7|8|9|10|11|12|com_4|com_3|com_2|com_1|
//SC92F7323   ________    ________
//        5V-|1 /VDD  \_/  P0.0/28|-com_1
//        0V-|2 /VSS       P0.1/27|-com_2
//          -|3 /P5.1      P0.2/26|-com_3
//          -|4 /P5.0      P0.3/25|-com_4
//          -|5 /P1.0      P0.4/24|-lcd_1
//          -|6 /P1.1      P0.5/23|-lcd_2
//       TCK-|7 /P1.2      P0.6/22|-lcd_3
//      TDIO-|8 /P1.3      P0.7/21|-lcd_4
//          -|9 /P1.4      P2.0/20|-lcd_5
//          -|10/P1.5      P2.1/19|-lcd_6
//          -|11/P1.6      P2.2/18|-lcd_7
//  beiguang-|12/P1.7      P2.3/17|-lcd_8
//    lcd_12-|13/P2.7      P2.4/16|-lcd_9
//    lcd_11-|14/P2.6______P2.5/15|-lcd_10
#include <SC92F732x_C.H>
#define                bit0                0x01
#define                bit1                0x02
#define                bit2                0x04
#define                bit3                0x08
#define                bit4                0x10
#define                bit5                0x20
#define                bit6                0x40
#define                bit7                0x80
#define                com_1_gao                P0VO &= ~bit0;        P00=1
#define                com_1_ban                P0VO |=bit0
#define                com_1_di                        P0VO &= ~bit0;        P00=0
#define                com_2_gao                P0VO &= ~bit1;        P01=1
#define                com_2_ban                P0VO |=bit1
#define                com_2_di                        P0VO &= ~bit1;        P01=0
#define                com_3_gao                P0VO &= ~bit2;        P02=1
#define                com_3_ban                P0VO |=bit2
#define                com_3_di                        P0VO &= ~bit2;        P02=0
#define                com_4_gao                P0VO &= ~bit3;        P03=1
#define                com_4_ban                P0VO |=bit3
#define                com_4_di                        P0VO &= ~bit3;        P03=0
sbit                lcd_1                =P0^4;
sbit                lcd_2                =P0^5;
sbit                lcd_3                =P0^6;
sbit                lcd_4                =P0^7;
sbit                lcd_5                =P2^0;
sbit                lcd_6                =P2^1;
sbit                lcd_7                =P2^2;
sbit                lcd_8                =P2^3;
sbit                lcd_9                =P2^4;
sbit                lcd_10                =P2^5;
sbit                lcd_11                =P2^6;
sbit                lcd_12                =P2^7;
sbit                beiguang        =P1^7;
unsigned char                temp_a1;                //设定温度
unsigned char                temp_a2;                //室温
//unsigned char                temp_a3;                //地温
unsigned char                temp_b1;                //设定温度十位
unsigned char                temp_b2;                //设定温度个位
unsigned char                temp_b3;                //室温十位
unsigned char                temp_b4;                //室温个位
unsigned char                temp_b5;                //室温小数
unsigned char                temp_c1;                //设定温度十位字模
unsigned char                temp_c2;                //设定温度个位字模
unsigned char                temp_c3;                //室温十位字模
unsigned char                temp_c4;                //室温个位字模
unsigned char                temp_c5;                //室温小数字模
unsigned char code biao[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void                lcd_xianshi();                //lcd显示
void                jisuan();                        //计算
void                yanshi();                        //延时
void        main()
/**************************************************/                //液晶初始化
P0CON                |=bit0|bit1|bit2|bit3|bit4|bit5|bit6|bit7;                //输出模式
P2CON                |=bit0|bit1|bit2|bit3|bit4|bit5|bit6|bit7;
OTCON                |=bit3|bit2;                //分压电阻87.5k
P1CON                |=bit7;                //背光输出
temp_a1                =12;
temp_a2                =34;
temp_b5                =5;
P1CON                |=bit4;
P1                        |=bit4;
beiguang        =1;
jisuan();
while        (1)
lcd_xianshi();
void                lcd_xianshi()                //lcd显示
/**************************************************/                //lcd正控
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
if(temp_c1&bit5){lcd_1 =0;}        else{lcd_1 =1;}
if(temp_c1&bit0){lcd_2 =0;}        else{lcd_2 =1;}
if(temp_c2&bit5){lcd_3 =0;}        else{lcd_3 =1;}
if(temp_c2&bit0){lcd_4 =0;}        else{lcd_4 =1;}
//if(temp_){lcd_5 =0;}        else{lcd_5 =1;}                //02竖(显示)
lcd_5 =0;
if(temp_c3&bit5){lcd_6 =0;}        else{lcd_6 =1;}
if(temp_c3&bit0){lcd_7 =0;}        else{lcd_7 =1;}
if(temp_c4&bit5){lcd_8 =0;}        else{lcd_8 =1;}
if(temp_c4&bit0){lcd_9 =0;}        else{lcd_9 =1;}
if(temp_c5&bit5){lcd_10 =0;}        else{lcd_10 =1;}
if(temp_c5&bit0){lcd_11 =0;}        else{lcd_11 =1;}
//if(temp_){lcd_12 =0;}        else{lcd_12 =1;}                //01锁定
lcd_12 =1;
com_1_gao;                //com1高
com_2_ban;
com_3_ban;
com_4_ban;
yanshi();
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
if(temp_c1&bit6){lcd_1 =0;}        else{lcd_1 =1;}
if(temp_c1&bit1){lcd_2 =0;}        else{lcd_2 =1;}
if(temp_c2&bit6){lcd_3 =0;}        else{lcd_3 =1;}
if(temp_c2&bit1){lcd_4 =0;}        else{lcd_4 =1;}
//if(temp_){lcd_5 =0;}        else{lcd_5 =1;}                //防冻
lcd_5 =1;
if(temp_c3&bit6){lcd_6 =0;}        else{lcd_6 =1;}
if(temp_c3&bit1){lcd_7 =0;}        else{lcd_7 =1;}
if(temp_c4&bit6){lcd_8 =0;}        else{lcd_8 =1;}
if(temp_c4&bit1){lcd_9 =0;}        else{lcd_9 =1;}
if(temp_c5&bit6){lcd_10 =0;}        else{lcd_10 =1;}
if(temp_c5&bit1){lcd_11 =0;}        else{lcd_11 =1;}
//if(temp_){lcd_12 =0;}        else{lcd_12 =1;}                //中
lcd_12 =1;
com_1_ban;
com_2_gao;                //com2高
com_3_ban;
com_4_ban;
yanshi();
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
if(temp_c1&bit4){lcd_1 =0;}        else{lcd_1 =1;}
if(temp_c1&bit2){lcd_2 =0;}        else{lcd_2 =1;}
if(temp_c2&bit4){lcd_3 =0;}        else{lcd_3 =1;}
if(temp_c2&bit4){lcd_4 =0;}        else{lcd_4 =1;}
//if(temp_){lcd_5 =0;}        else{lcd_5 =1;}                //保护
lcd_5 =1;
if(temp_c3&bit4){lcd_6 =0;}        else{lcd_6 =1;}
if(temp_c3&bit2){lcd_7 =0;}        else{lcd_7 =1;}
if(temp_c4&bit4){lcd_8 =0;}        else{lcd_8 =1;}
if(temp_c4&bit2){lcd_9 =0;}        else{lcd_9 =1;}
if(temp_c5&bit4){lcd_10 =0;}        else{lcd_10 =1;}
if(temp_c5&bit2){lcd_11 =0;}        else{lcd_11 =1;}
//if(temp_){lcd_12 =0;}        else{lcd_12 =1;}                //加热
lcd_12 =1;
com_1_ban;
com_2_ban;
com_3_gao;                //com3高
com_4_ban;
yanshi();
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
//if(temp_){lcd_1 =0;}        else{lcd_1 =1;}                //室温
lcd_1 =1;
if(temp_c1&bit3){lcd_2 =0;}        else{lcd_2 =1;}
//if(temp_){lcd_3 =0;}        else{lcd_3 =1;}                //设定摄氏度(显示)
lcd_3 =0;
if(temp_c2&bit3){lcd_4 =0;}        else{lcd_4 =1;}                //无
lcd_5 =1;
//if(temp_){lcd_6 =0;}        else{lcd_6 =1;}                //地温
lcd_6 =1;
if(temp_c3&bit3){lcd_7 =0;}        else{lcd_7 =1;}
//if(temp_){lcd_8 =0;}        else{lcd_8 =1;}                //℃(显示)
lcd_8 =0;
if(temp_c4&bit3){lcd_9 =0;}        else{lcd_9 =1;}
//if(temp_){lcd_10 =0;}        else{lcd_10 =1;}                //点(显示)
lcd_10 =0;
if(temp_c5&bit3){lcd_11 =0;}        else{lcd_11 =1;}
//if(temp_){lcd_12 =0;}        else{lcd_12 =1;}                //停止
lcd_12 =1;
com_1_ban;
com_2_ban;
com_3_ban;
com_4_gao;                //com4高
yanshi();
/**************************************************/                //lcd反控
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
if(temp_c1&bit5){lcd_1 =1;}        else{lcd_1 =0;}
if(temp_c1&bit0){lcd_2 =1;}        else{lcd_2 =0;}
if(temp_c2&bit5){lcd_3 =1;}        else{lcd_3 =0;}
if(temp_c2&bit0){lcd_4 =1;}        else{lcd_4 =0;}
//if(temp_){lcd_5 =1;}        else{lcd_5 =0;}                //02竖(显示)
lcd_5 =1;
if(temp_c3&bit5){lcd_6 =1;}        else{lcd_6 =0;}
if(temp_c3&bit0){lcd_7 =1;}        else{lcd_7 =0;}
if(temp_c4&bit5){lcd_8 =1;}        else{lcd_8 =0;}
if(temp_c4&bit0){lcd_9 =1;}        else{lcd_9 =0;}
if(temp_c5&bit5){lcd_10 =1;}        else{lcd_10 =0;}
if(temp_c5&bit0){lcd_11 =1;}        else{lcd_11 =0;}
//if(temp_){lcd_12 =1;}        else{lcd_12 =0;}                //01锁定
lcd_12 =0;
com_1_di;                //com1低
com_2_ban;
com_3_ban;
com_4_ban;
yanshi();
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
if(temp_c1&bit6){lcd_1 =1;}        else{lcd_1 =0;}
if(temp_c1&bit1){lcd_2 =1;}        else{lcd_2 =0;}
if(temp_c2&bit6){lcd_3 =1;}        else{lcd_3 =0;}
if(temp_c2&bit1){lcd_4 =1;}        else{lcd_4 =0;}                //防冻
lcd_5 =0;
if(temp_c3&bit6){lcd_6 =1;}        else{lcd_6 =0;}
if(temp_c3&bit1){lcd_7 =1;}        else{lcd_7 =0;}
if(temp_c4&bit6){lcd_8 =1;}        else{lcd_8 =0;}
if(temp_c4&bit1){lcd_9 =1;}        else{lcd_9 =0;}
if(temp_c5&bit6){lcd_10 =1;}        else{lcd_10 =0;}
if(temp_c5&bit1){lcd_11 =1;}        else{lcd_11 =0;}
//if(temp_){lcd_12 =1;}        else{lcd_12 =0;}                //中
lcd_12 =0;
com_1_ban;
com_2_di;                //com2低
com_3_ban;
com_4_ban;
yanshi();
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
if(temp_c1&bit4){lcd_1 =1;}        else{lcd_1 =0;}
if(temp_c1&bit2){lcd_2 =1;}        else{lcd_2 =0;}
if(temp_c2&bit4){lcd_3 =1;}        else{lcd_3 =0;}
if(temp_c2&bit2){lcd_4 =1;}        else{lcd_4 =0;}
//if(temp_){lcd_5 =1;}        else{lcd_5 =0;}                //保护
lcd_5 =0;
if(temp_c3&bit4){lcd_6 =1;}        else{lcd_6 =0;}
if(temp_c3&bit2){lcd_7 =1;}        else{lcd_7 =0;}
if(temp_c4&bit4){lcd_8 =1;}        else{lcd_8 =0;}
if(temp_c4&bit2){lcd_9 =1;}        else{lcd_9 =0;}
if(temp_c5&bit4){lcd_10 =1;}        else{lcd_10 =0;}
if(temp_c5&bit2){lcd_11 =1;}        else{lcd_11 =0;}
//if(temp_){lcd_12 =1;}        else{lcd_12 =0;}                //加热
lcd_12 =0;
com_1_ban;
com_2_ban;
com_3_di;                //com3低
com_4_ban;
yanshi();
com_1_ban;
com_2_ban;
com_3_ban;
com_4_ban;
//if(temp_){lcd_1 =1;}        else{lcd_1 =0;}                //室温
lcd_1 =0;
if(temp_c1&bit3){lcd_2 =1;}        else{lcd_2 =0;}
//if(temp_){lcd_3 =1;}        else{lcd_3 =0;}                //设定摄氏度(显示)
lcd_3 =1;
if(temp_c2&bit3){lcd_4 =1;}        else{lcd_4 =0;}
//if(temp_){lcd_5 =1;}        else{lcd_5 =0;}                //无
lcd_5 =0;
//if(temp_){lcd_6 =1;}        else{lcd_6 =0;}                //地温
lcd_6 =0;
if(temp_c3&bit3){lcd_7 =1;}        else{lcd_7 =0;}
//if(temp_){lcd_8 =1;}        else{lcd_8 =0;}                //℃(显示
lcd_8 =1;
if(temp_c4&bit3){lcd_9 =1;}        else{lcd_9 =0;}
//if(temp_){lcd_10 =1;}        else{lcd_10 =0;}                //点(显示)
lcd_10 =1;
if(temp_c5&bit3){lcd_11 =1;}        else{lcd_11 =0;}
//if(temp_){lcd_12 =1;}        else{lcd_12 =0;}                //停止
lcd_12 =0;
com_1_ban;
com_2_ban;
com_3_ban;
com_4_di;                //com4低
yanshi();
void                jisuan()                        //计算
temp_b1                =temp_a1/10;
temp_b2                =temp_a1%10;
temp_c1                =biao[temp_b1];
//temp_c1                =biao[temp_a1/10];
temp_c2                =biao[temp_b2];
temp_b3                =temp_a2/10;
temp_b4                =temp_a2%10;
temp_c3                =biao[temp_b3];
temp_c4                =biao[temp_b4];
temp_c5                =biao[temp_b5];
void                yanshi()                        //延时
unsigned        char x,y;
for(x=50;x>0;x--)
        for(y=100;y>0;y--);
319
