[技术讨论] 航顺HK32F103兼容AES加密库问题
1303|0
 楼主| njysyousi 发表于 2021-8-19 17:56 | 显示全部楼层 |阅读模式
STM32的程序写入到航顺的HK32F103VET6中,可以运行,但发现AES加密库不能使用,不知道是不是不支持,不是说完全兼容吗?
我使用的加密库是M3_CryptoFM_2_0_6.lb
版本信息
  * @file    crypto.h
  * @author  MCD Application Team
  * @version V2.0.6
  * @date    25-June-2013
  * @brief   This file contains all the functions prototypes for the config firmware
  *          library.
  * @attention
  * <h2><center>&copy; COPYRIGHT 2013 STMicroelectronics</center></h2>
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
