FPM10A使用串口驱动,指令完全正确,就是指纹模块没反应...
7316|0
 楼主| cr315 发表于 2021-8-26 16:50 | 显示全部楼层 |阅读模式
第一行数据是单片机发送的,第二行数据是利用串口助手发送红框3的数据后,指纹模块上传的数据,同一条指令,为什么串口助手发送就有用,单片机就没用呢
#include <reg51.h>
unsigned char flag,a,i;
unsigned char code FP_Pack_Head[6] = {0xef,0x01,0xff,0xff,0xff,0xff};  //ЭÒé°üÍ·
unsigned char code FP_Get_Img[6] = {0x01,0x00,0x03,0x01,0x00,0x05};     //»ñµÃÖ¸ÎÆÍ¼Ïñ
unsigned char code FP_Templete_Num[6] ={0x01,0x00,0x03,0x1D,0x00,0x21 }; //»ñµÃÄ£°å×ÜÊý
unsigned char code FP_Search[11]={0x01,0x00,0x08,0x04,0x01,0x0,0x0,0x03,0xA1,0x0,0xB2}; //Ö¸ÎÆËÑË÷·¶Î§0 - 929
unsigned char code FP_Search_0_9[11]={0x01,0x00,0x08,0x04,0x01,0x0,0x0,0x0,0x13,0x0,0x21}; //ËÑË÷0-9ºÅÖ¸ÎÆ
unsigned char code FP_Img_To_Buffer1[7]={0x01,0x00,0x04,0x02,0x01,0x0,0x08}; //½«Í¼Ïñ·ÅÈëBUFFER1
unsigned char code FP_Img_To_Buffer2[7]={0x01,0x00,0x04,0x02,0x02,0x0,0x09}; //½«Í¼Ïñ·ÅÈëBUFFER2
unsigned char code FP_Reg_Model[6]={0x01,0x00,0x03,0x05,0x0,0x09}; //½«BUFFER1ºÍBUFFER2ºÏ³ÉÌØÕ÷Ä£°å
unsigned char code FP_Delet_All_Model[6]={0x01,0x00,0x03,0x0d,0x00,0x11};//ɾ³ýÖ¸ÎÆ¿âÖÐËùÓеÄÄ£°å
volatile unsigned char  FP_Save_Finger[9]={0x01,0x00,0x06,0x06,0x01,0x00,0x0B,0x00,0x19};//½«BUFFER1ÖеÄÌØÕ÷Âë´æ·Åµ½Ö¸¶¨Î»ÖÃ
volatile unsigned char  FP_Delete_Model[10]={0x01,0x00,0x07,0x0C,0x00,0x00,0x00,0x01,0x00,0x00}; //ɾ³ýÖ¸¶¨µÄÄ£°å
volatile unsigned char UART1_FINGERPRINT_RECEVICE_BUFFER[24];
void Delay_Ms(int t)
        int a,b;
        for(a=5*t;a>0;a--)
                for(b=22;b>0;b--)
void UART_init_9600(void)                //9600bps@12.000MHz
          TMOD=0X20;
          TH1=0XFD;
          TL1=0XFD;
          TR1=1;
          REN=1;
          SM0=0;       //´®¿Ú·½Ê½1
          SM1=1;
          EA=1;
          ES=1;
void UART1_Send_Byte(unsigned char c)//·¢ËÍÒ»¸ö×Ö½Ú
        TI=0;
        SBUF = c;
        while(!TI);
        TI = 0;
unsigned char UART1_Receive_Byte()//½ÓÊÕÒ»¸ö×Ö½Ú
unsigned char dat;
        while(!RI);
        RI = 0;
        dat = SBUF;
        return (dat);
//FINGERPRINT»ñÈ¡Ö¸ÎÆÍ¼ÏñÃüÁî
void FINGERPRINT_Cmd_Get_Img(void)
    unsigned char i;
    ES=0;
    for(i=0;i<6;i++)
       UART1_Send_Byte(FP_Pack_Head);   //
    for(i=0;i<6;i++)
       UART1_Send_Byte(FP_Get_Img);
          ES=1;
////½«Í¼Ïñת»»³ÉÌØÕ÷Âë´æ·Åµ½Buffer1ÖÐ
//void FINGERPRINT_Cmd_Img_To_Buffer1(void)
//             unsigned char i;
//               for(i=0;i<6;i++)
//                   UART1_Send_Byte(FP_Pack_Head);
//                      for(i=0;i<7;i++)
//                         UART1_Send_Byte(FP_Img_To_Buffer1);
////½«Í¼Ïñת»»³ÉÌØÕ÷Âë´æ·Åµ½Buffer2ÖÐ
//void FINGERPRINT_Cmd_Img_To_Buffer2(void)
//     unsigned char i;
//           for(i=0;i<6;i++)
//                      for(i=0;i<7;i++)
//                         UART1_Send_Byte(FP_Img_To_Buffer2);
////½«BUFFER1 ºÍ BUFFER2 ÖеÄÌØÕ÷ÂëºÏ²¢³ÉÖ¸ÎÆÄ£°æ
//void FINGERPRINT_Cmd_Reg_Model(void)
//    unsigned char i;
//    for(i=0;i<6;i++)
//    for(i=0;i<6;i++)
//      UART1_Send_Byte(FP_Reg_Model);
////ɾ³ýÖ¸ÎÆÄ£¿éÀïËùÓеÄÖ¸ÎÆÄ£°å
//void FINGERPRINT_Cmd_Delete_All_Model(void)
//     unsigned char i;
//    for(i=0;i<6;i++)
//    for(i=0;i<6;i++)
//      UART1_Send_Byte(FP_Delet_All_Model);
////ɾ³ýÖ¸ÎÆÄ£¿éÀïÖ¸¶¨µÄÖ¸ÎÆÄ£°å
//void FINGERPRINT_Cmd_Delete_Model(unsigned int uiID_temp)
//    volatile unsigned int uiSum_temp = 0;
//        unsigned char i;
//        FP_Delete_Model[4]=(uiID_temp&0xFF00)>>8;
//        FP_Delete_Model[5]=(uiID_temp&0x00FF);
//        for(i=0;i<8;i++)
//            uiSum_temp = uiSum_temp + FP_Delete_Model;
//        //UART0_Send_Byte(uiSum_temp);
//        FP_Delete_Model[8]=(uiSum_temp&0xFF00)>>8;
//        FP_Delete_Model[9]=uiSum_temp&0x00FF;
//    for(i=0;i<6;i++) //
//    for(i=0;i<10;i++) //????????
//      UART1_Send_Byte(FP_Delete_Model);
////»ñÈ¡Ö¸ÎÆÄ£°åÊýÁ¿
//void FINGERPRINT_Cmd_Get_Templete_Num(void)
//{  unsigned int i;
//  // unsigned char temp[14];
//   for(i=0;i<6;i++)
//   for(i=0;i<6;i++)
//     UART1_Send_Byte(FP_Templete_Num);
////ËÑË÷È«²¿Óû§999ö
//void FINGERPRINT_Cmd_Search_Finger(void)
//       unsigned char i;
//           for(i=0;i<6;i++)
//       for(i=0;i<11;i++)
//                  UART1_Send_Byte(FP_Search);
////ËÑË÷È«²¿Óû§999ö
//void FINGERPRINT_Cmd_Search_Finger_Admin(void)
//       unsigned char i;
//           for(i=0;i<6;i++)   //?????????
//                  UART1_Send_Byte(FP_Search_0_9);
////½«BUFFER1ÖеÄÌØÕ÷Âë´æ·Åµ½Ö¸¶¨Î»ÖÃ
//void FINGERPRINT_Cmd_Save_Finger( unsigned char ucH_Char,unsigned char ucL_Char )
//           unsigned long temp = 0;
//                   unsigned char i;
////           SAVE_FINGER[9]={0x01,0x00,0x06,0x06,0x01,0x00,0x0B,0x00,0x19};//?BUFFER1?????????????
//           FP_Save_Finger[5] = ucH_Char;
//           FP_Save_Finger[6] = ucL_Char;
//                   for(i=0;i<7;i++)   //¼ÆËã¼ìÑéºÍ
//                              temp = temp + FP_Save_Finger;
//                   FP_Save_Finger[7]=(temp & 0x00FF00) >> 8; //´æ·Å¼ìÑéÊý¾Ý
//                   FP_Save_Finger[8]= temp & 0x0000FF;
//           for(i=0;i<6;i++)
//           for(i=0;i<9;i++)
//                         UART1_Send_Byte(FP_Save_Finger);
////½ÓÊÕ·µÀ¡Êý¾Ý»º³å
//void FINGERPRINT_Recevice_Data(unsigned char ucLength)
//  unsigned char i;
//  for (i=0;i<ucLength;i++)
//     UART1_FINGERPRINT_RECEVICE_BUFFER = UART1_Receive_Byte();
////Ìí¼ÓÓû§
//unsigned char FP_add_new_user(unsigned char ucH_user,unsigned char ucL_user)
//                       do {
//                    FINGERPRINT_Cmd_Get_Img();   //»ñµÃÖ¸ÎÆÍ¼Ïñ
//                        FINGERPRINT_Recevice_Data(12); //½ÓÊÕ12¸ö³¤¶ÈµÄ·´À¡Âë
//               while ( UART1_FINGERPRINT_RECEVICE_BUFFER[9]!=0x0 ); //¼ì²âÊÇ·ñ³É¹¦µÄ°´ÁËÖ¸ÎÆ
//                                   FINGERPRINT_Cmd_Img_To_Buffer1();  //½«Í¼Ïñת»»Âë´æ·ÅÔÚBuffer1ÖÐ
//                do{
//                                     FINGERPRINT_Cmd_Get_Img();     //»ñÈ¡Ö¸ÎÆÍ¼Ïñ
//                                 while( UART1_FINGERPRINT_RECEVICE_BUFFER[9]!=0x0 );
//                                 FINGERPRINT_Cmd_Img_To_Buffer2();     //½«Í¼Ïñת»»Âë´æ·ÅÔÚBuffer2ÖÐ
//                                 FINGERPRINT_Cmd_Reg_Model();//ת»»³ÉÌØÕ÷Âë
//                                 FINGERPRINT_Cmd_Save_Finger(ucH_user,ucL_user);
//                         return 0;
void main(void)
        unsigned char temp_char = 0;
        UART_init_9600();
        Delay_Ms(500);
        Delay_Ms(500);
        Delay_Ms(500);
        Delay_Ms(500);
        Delay_Ms(500);
                while(1)
