[STM32F4] STM32F407独立看门狗
956|1
 楼主| 磨砂 发表于 2021-9-6 15:44 | 显示全部楼层 |阅读模式
iwdg.c
#include "iwdg.h"
//初始化独立看门狗
//prer:分频数:0~7(只有低3位有效!)
//分频因子=4*2^prer.但最大值只能是256!
//rlr:自动重装载值,0~0XFFF. (4095)
//rlr:重装载寄存器值:低11位有效.
//RCC=32Khz
//时间计算(大概):Tout=((4*2^prer)*rlr)/32 (ms).
void IWDG_Init(u8 prer,u16 rlr)
        IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable); //使能对IWDG->PR IWDG->RLR的写
        IWDG_SetPrescaler(prer); //设置IWDG分频系数
        IWDG_SetReload(rlr);   //设置IWDG装载值
        IWDG_ReloadCounter(); //reload
        IWDG_Enable();       //使能看门狗
//喂独立看门狗
void IWDG_Feed(void)
        IWDG_ReloadCounter();//reload
iwdg.h
#ifndef _IWDG_H
#define _IWDG_H
#include "sys.h"
void IWDG_Init(u8 prer,u16 rlr);//IWDG初始化
void IWDG_Feed(void);  //喂狗函数
#endif
 楼主| 磨砂 发表于 2021-9-6 15:46 | 显示全部楼层
main.c 使用基本定时器6喂狗
int main(void)
        /*看门狗*/
        IWDG_Init(3,5000);//看门狗 5S         实际1S
        /*84M/8400=10k=0.1ms  10*0.1ms=1ms */
        TIM6_Config(10-1,8400-1);  //TIM6 定时喂狗        中断优先级 主0子0
        while(1)
timer.c
//TIM6  喂狗
//基本定时器6中断初始化
//这里时钟选择为APB1的2倍,而APB1为42M, 即TIM6时钟为84M
//arr:自动重装值。例1000-1,计数器从0数到1000,即T=1000*1us=1ms
//psc:时钟预分频数。例84-1,若时钟为84M,则分频后为84M/84=1MHz 即1us
//定时器溢出时间计算方法:Tout=((arr+1)*(psc+1))/Ft us.
void TIM6_Config(u16 arr,u16 psc)   //1ms
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6,ENABLE);  ///使能TIM6时钟
    TIM_TimeBaseInitStructure.TIM_Period = arr;         //自动重装载值
        TIM_TimeBaseInitStructure.TIM_Prescaler=psc;  //定时器分频
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM6,&TIM_TimeBaseInitStructure);
        TIM_ITConfig(TIM6,TIM_IT_Update,ENABLE); //允许定时器6更新中断
        TIM_Cmd(TIM6,ENABLE); //使能定时器6
        NVIC_InitStructure.NVIC_IRQChannel=TIM6_DAC_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x00; //抢占优先级0
        NVIC_InitStructure.NVIC_IRQChannelSubPriority=0x00; //子优先级0
        NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
        NVIC_Init(&NVIC_InitStructure);
//喂狗 1ms
void TIM6_DAC_IRQHandler(void)  //中断
        if(TIM_GetITStatus(TIM6,TIM_IT_Update)==SET)
                        IWDG_Feed(); //喂狗
        TIM_ClearITPendingBit(TIM6,TIM_IT_Update);
