[STM32F1] 只能写或者读
2630|13
 楼主| happy_10 发表于 2021-9-7 21:00 | 显示全部楼层 |阅读模式
我在编写32f103与at45db041读写程序时,采用模拟spi接口,可是只能写或者读,也就是用82命令写后,马上用03命令读,读出的数据全为零。可是写之后,把写命令屏蔽掉,只用读命令,读出的数据是对的。不知道有什么问题?
dingy 发表于 2021-9-7 21:04 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
llljh 发表于 2021-9-7 21:06 | 显示全部楼层
#define SPI_CS_LOW       (GPIOA->BRR |=GPIO_Pin_5)
#define SPI_CS_HIGH      (GPIOA->BSRR |=GPIO_Pin_5)
#define SPI_SCK_LOW      (GPIOA->BRR |=GPIO_Pin_6)
#define SPI_SCK_HIGH     (GPIOA->BSRR |=GPIO_Pin_6)
#define SPI_MISO_LOW     (GPIOA->BRR |=GPIO_Pin_4)
#define SPI_MISO_HIGH    (GPIOA->BSRR|=GPIO_Pin_4)
#define SPI_MISO_READ    (GPIOA->IDR &GPIO_Pin_4)
#define SPI_MOSI_LOW     (GPIOA->BRR |=GPIO_Pin_7)
#define SPI_MOSI_HIGH    (GPIOA->BSRR|=GPIO_Pin_7)
void Init_45DB041(void)
   GPIO_InitTypeDef  GPIO_InitStruct;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
    //CS
    GPIO_InitStruct.GPIO_Mode=GPIO_Mode_Out_PP;
    GPIO_InitStruct.GPIO_Pin=GPIO_Pin_5;
    GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;
    GPIO_Init(GPIOA, &GPIO_InitStruct);
    //SCK
    GPIO_InitStruct.GPIO_Pin=GPIO_Pin_6;
    GPIO_Init(GPIOA,&GPIO_InitStruct);
    //MISO
    GPIO_InitStruct.GPIO_Pin=GPIO_Pin_4;
    GPIO_InitStruct.GPIO_Mode=GPIO_Mode_IN_FLOATING;//加上拉电阻,其它没加
    //MOSI
    GPIO_InitStruct.GPIO_Pin=GPIO_Pin_7;
    SPI_CS_HIGH;
    SPI_SCK_HIGH;
void read_arry_byte(unsigned long address,unsigned char *d)//Á¬Ðø×Ö½Ú¶Á
unsigned char j=0,k=0,n;
__disable_irq();
n=strlen((const char*)d);//ÇóÊýÁ¿
SPI_SCK_HIGH;
delay_us(100);
SPI_CS_LOW;
//SPI_MISO_HIGH;
delay_us(100);
for(k=0;k<32;k++)//ËÍÃüÁî
  SPI_SCK_LOW;
  delay_us(100);
  if((address&0x80000000)==0x80000000)
  { SPI_MOSI_HIGH;}
  else
  { SPI_MOSI_LOW;}
  delay_us(100);
  SPI_SCK_HIGH;
  address<<=1;
  delay_us(100);
//SPI_SCK_HIGH;
//delay_us(100);
for(j=0;j<n;j++)//¶ÁÊý¾Ý
  for(k=0;k<8;k++)
   d[j]<<=1;
   SPI_SCK_LOW;
   delay_us(100);
   if(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_4))
   {d[j]|=0x01;}
   else
   {d[j]&=0xFE;}
   SPI_SCK_HIGH;
   delay_us(100);
  SPI_CS_HIGH;
  SPI_SCK_LOW;
  delay_us(100);
void write_page(unsigned long address,unsigned char *data)//Á¬Ðø×Ö½Úд
__disable_irq();
n=strlen((const char*)data);//ÇóÊýÁ¿
SPI_SCK_HIGH;
delay_us(100);
SPI_CS_LOW;
delay_us(100);
  SPI_SCK_LOW;
  delay_us(100);
  { SPI_MOSI_HIGH;}
  else
  { SPI_MOSI_LOW;}
  delay_us(100);
  SPI_SCK_HIGH;
  address<<=1;
  delay_us(100);
// SPI_SCK_HIGH;
// delay_us(100);
for(j=0;j<n;j++)//ËÍÊý¾Ý
  for(k=0;k<8;k++)
   SPI_SCK_LOW;
   delay_us(100);
    if((data[j]&0x80)==0x80)
     { SPI_MOSI_HIGH;}
    else
     { SPI_MOSI_LOW;}
   delay_us(100);
   SPI_SCK_HIGH;
   data[j]<<=1;
   delay_us(100);
SPI_CS_HIGH;
SPI_SCK_LOW;
delay_us(100);
unsigned char Read_state(void)
unsigned char k=0,i=0xD7;
__disable_irq();
SPI_SCK_HIGH;
delay_us(100);
SPI_CS_LOW;
// SPI_MISO_HIGH;
delay_us(100);
for(k=0;k<8;k++)//ËÍÃüÁî
  SPI_SCK_LOW;
  delay_us(100);
  if((i&0x80)==0x80)
  { SPI_MOSI_HIGH;}
  else
  { SPI_MOSI_LOW;}
  delay_us(100);
  SPI_SCK_HIGH;
  i<<=1;
  delay_us(100);
i=0;
// SPI_SCK_HIGH;
// delay_us(100);
for(k=0;k<8;k++)//¶ÁÊý¾Ý
   i<<=1;
   SPI_SCK_LOW;
   delay_us(100);
   if(SPI_MISO_READ)
   {i|=0x01;}
   else
   {i&=0xFE;}
   SPI_SCK_HIGH;
   delay_us(100);
SPI_CS_HIGH;
SPI_SCK_LOW;
delay_us(100);
return i;
void erase_45(void)
unsigned char j=0,i=0;
unsigned char erease_order[4]={0xc7,0x94,0x80,0x9a};//²Á³ýÃüÁî
  __disable_irq();
SPI_SCK_HIGH;
delay_us(100);
SPI_CS_LOW;
delay_us(100);
while(j<4)
   for(i=0;i<8;i++)
   SPI_SCK_LOW;
   delay_us(100);
   if((erease_order[j]&0x80)==0x80)
   { SPI_MOSI_HIGH;}
   else
   { SPI_MOSI_LOW; }
   delay_us(100);
   SPI_SCK_HIGH;
   erease_order[j]<<=1;
   delay_us(100);
  j++;
SPI_CS_HIGH;
SPI_SCK_LOW;
delay_us(100);
void  main()
  u8 IC_Serial[4];//´æ´¢IC¿¨ÐòÁкÅ
u8 IC_ID[4];//¶ÁÈ¡IC¶Á¿¨Æ÷É豸IDºÅ
Init_45DB041();
IC_Serial[0]=0xDD;IC_Serial[1]=0xFF;IC_Serial[2]=0xFD;IC_Serial[3]=0xDD;
  write_page(0x82000800,IC_Serial);
delay_ms(500);delay_ms(500);delay_ms(500);delay_ms(500); delay_ms(500);//
while((Read_state()&0x80)==0) delay_ms(5);
__enable_irq();
read_arry_byte(0x03000800,IC_ID);
__enable_irq();
  sprintf((char*)p,"DC32(20,120,'%X-%X-%X-%X',15);\r\n",IC_ID[0],IC_ID[1],IC_ID[2],IC_ID[3]);//
   atk_8266_send_cmd(p,"OK",200);
pengf 发表于 2021-9-7 21:08 | 显示全部楼层
写数据需要时间的,延时一下在读就行了
 楼主| happy_10 发表于 2021-9-7 21:11 | 显示全部楼层
我把这一段的程序贴出来了,我检测状态寄存器,同时也延时了,但是问题还是只能读、或者写,不能写之后就读。
 楼主| happy_10 发表于 2021-9-7 21:13 | 显示全部楼层
哪位帮忙分析分析?
 楼主| happy_10 发表于 2021-9-7 21:25 | 显示全部楼层
问题已经解决,出在了读函数中的n=strlen((const char*)d);,数组作为形参,不能求出长度来,改为函数入口直接求数组长度如sizeof(d),并作为形参,就可以解决问题。
llljh 发表于 2021-9-7 21:25 | 显示全部楼层
数组作为形参,怎么操作?想学习一下
 楼主| happy_10 发表于 2021-9-7 21:28 | 显示全部楼层
其实还是不大明白,我再琢磨琢磨吧,多谢了哈先
coshi 发表于 2021-10-4 18:15 | 显示全部楼层
是不是需要一个小延时啊
aoyi 发表于 2021-10-4 18:21 | 显示全部楼层
怎么做形参呢
drer 发表于 2021-10-4 18:27 | 显示全部楼层
恭喜楼主解决问题
gwsan 发表于 2021-10-4 18:31 | 显示全部楼层
一个迂回的 好办法
kxsi 发表于 2021-10-4 18:34 | 显示全部楼层
就是说读写不能同时用 是吗
