关于ST V3.5固件库 can的问题,求教香版~~~~~~~~~~~~
3286|3
kavieen|  楼主 | 2012-3-15 10:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
香版,我使用的是107,在设置can2的时候发现CAN_FilterInit里面只能设置can1,无法配置can2,求教~~~~~~莫非配置can1 就不用配置can2了吗???
void CAN_FilterInit(CAN_FilterInitTypeDef* CAN_FilterInitStruct)
  uint32_t filter_number_bit_pos = 0;
  /* Check the parameters */
  assert_param(IS_CAN_FILTER_NUMBER(CAN_FilterInitStruct->CAN_FilterNumber));
  assert_param(IS_CAN_FILTER_MODE(CAN_FilterInitStruct->CAN_FilterMode));
  assert_param(IS_CAN_FILTER_SCALE(CAN_FilterInitStruct->CAN_FilterScale));
  assert_param(IS_CAN_FILTER_FIFO(CAN_FilterInitStruct->CAN_FilterFIFOAssignment));
  assert_param(IS_FUNCTIONAL_STATE(CAN_FilterInitStruct->CAN_FilterActivation));
  filter_number_bit_pos = ((uint32_t)1) << CAN_FilterInitStruct->CAN_FilterNumber;
  /* Initialisation mode for the filter */
  CAN1->FMR |= FMR_FINIT;
  /* Filter Deactivation */
  CAN1->FA1R &= ~(uint32_t)filter_number_bit_pos;
  /* Filter Scale */
  if (CAN_FilterInitStruct->CAN_FilterScale == CAN_FilterScale_16bit)
    /* 16-bit scale for the filter */
    CAN1->FS1R &= ~(uint32_t)filter_number_bit_pos;
    /* First 16-bit identifier and First 16-bit mask */
    /* Or First 16-bit identifier and Second 16-bit identifier */
    CAN1->sFilterRegister[CAN_FilterInitStruct->CAN_FilterNumber].FR1 =
    ((0x0000FFFF & (uint32_t)CAN_FilterInitStruct->CAN_FilterMaskIdLow) << 16) |
        (0x0000FFFF & (uint32_t)CAN_FilterInitStruct->CAN_FilterIdLow);
    /* Second 16-bit identifier and Second 16-bit mask */
    /* Or Third 16-bit identifier and Fourth 16-bit identifier */
    CAN1->sFilterRegister[CAN_FilterInitStruct->CAN_FilterNumber].FR2 =
    ((0x0000FFFF & (uint32_t)CAN_FilterInitStruct->CAN_FilterMaskIdHigh) << 16) |
        (0x0000FFFF & (uint32_t)CAN_FilterInitStruct->CAN_FilterIdHigh);
  if (CAN_FilterInitStruct->CAN_FilterScale == CAN_FilterScale_32bit)
    /* 32-bit scale for the filter */
    CAN1->FS1R |= filter_number_bit_pos;
    /* 32-bit identifier or First 32-bit identifier */
    ((0x0000FFFF & (uint32_t)CAN_FilterInitStruct->CAN_FilterIdHigh) << 16) |
    /* 32-bit mask or Second 32-bit identifier */
        (0x0000FFFF & (uint32_t)CAN_FilterInitStruct->CAN_FilterMaskIdLow);
  /* Filter Mode */
  if (CAN_FilterInitStruct->CAN_FilterMode == CAN_FilterMode_IdMask)
    /*Id/Mask mode for the filter*/
    CAN1->FM1R &= ~(uint32_t)filter_number_bit_pos;
  else /* CAN_FilterInitStruct->CAN_FilterMode == CAN_FilterMode_IdList */
    /*Identifier list mode for the filter*/
    CAN1->FM1R |= (uint32_t)filter_number_bit_pos;
  /* Filter FIFO assignment */
  if (CAN_FilterInitStruct->CAN_FilterFIFOAssignment == CAN_Filter_FIFO0)
    /* FIFO 0 assignation for the filter */
    CAN1->FFA1R &= ~(uint32_t)filter_number_bit_pos;
  if (CAN_FilterInitStruct->CAN_FilterFIFOAssignment == CAN_Filter_FIFO1)
    /* FIFO 1 assignation for the filter */
    CAN1->FFA1R |= (uint32_t)filter_number_bit_pos;
  /* Filter activation */
  if (CAN_FilterInitStruct->CAN_FilterActivation == ENABLE)
    CAN1->FA1R |= filter_number_bit_pos;
  /* Leave the initialisation mode for the filter */
  CAN1->FMR &= ~FMR_FINIT;
sjnh| | 2012-3-15 10:46 | 只看该作者
公用一个初始化函数,默认的2是从14组开始,可以更改开始组号
kavieen|  楼主 | 2012-3-20 15:42 | 只看该作者
如果我只是用can2 还需要初始化can1吗?
0sidamingbu0| | 2012-7-18 13:17 | 只看该作者
我调试can的时候用1.0的固件库没问题 换成3.5的库执行到设置发送邮箱的TDTR时候跳到硬件错误中断里 很奇怪 同样的程序只换了一个库
