[DemoCode下载]
N76E003的PWM死区使用方法
2410|2
huangcunxiake|  楼主 | 2021-9-26 22:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 PWM Output with dead time insert demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
////--------- PMW clock source select define ---------------------
//#define                PWM_CLOCK_FSYS                                        CKCON&=0xBF
//#define                PWM_CLOCK_TIMER1                                CKCON|=0x40
////--------- PWM clock devide define ----------------------------
//#define                PWM_CLOCK_DIV_2                                        PWMCON1|=0x01;PWMCON1&=0xF9
//#define                PWM_CLOCK_DIV_4                                        PWMCON1|=0x02;PWMCON1&=0xFA
//#define                PWM_CLOCK_DIV_8                                        PWMCON1|=0x03;PWMCON1&=0xFB
//#define                PWM_CLOCK_DIV_16                                PWMCON1|=0x04;PWMCON1&=0xFC
//#define                PWM_CLOCK_DIV_32                                PWMCON1|=0x05;PWMCON1&=0xFD
//#define                PWM_CLOCK_DIV_64                                PWMCON1|=0x06;PWMCON1&=0xFE
//#define                PWM_CLOCK_DIV_128                                PWMCON1|=0x07
////--------- PWM I/O select define ------------------------------
//#define                PWM5_P15_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x20;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.5 as PWM5 output enable
//#define                PWM5_P03_OUTPUT_ENABLE                PIOCON0|=0x20        //P0.3 as PWM5
//#define                PWM4_P01_OUTPUT_ENABLE                PIOCON0|=0x10        //P0.1 as PWM4 output enable
//#define                PWM3_P04_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x08;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P0.4 as PWM3 output enable
//#define                PWM3_P00_OUTPUT_ENABLE                PIOCON0|=0x08        //P0.0 as PWM3
//#define                PWM2_P05_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x04;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.0 as PWM2 output enable
//#define                PWM2_P10_OUTPUT_ENABLE                PIOCON0|=0x04        //P1.0 as PWM2
//#define                PWM1_P14_OUTPUT_ENABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1|=0x02;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.4 as PWM1 output enable
//#define                PWM1_P11_OUTPUT_ENABLE                PIOCON0|=0x02        //P1.1 as PWM1
//#define                PWM0_P12_OUTPUT_ENABLE                PIOCON0|=0x01        //P1.2 as PWM0 output enable
//#define         ALL_PWM_OUTPUT_ENABLE                        PIOCON0=0xFF;PIOCON1=0xFF
//#define                PWM5_P15_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xDF;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.5 as PWM5 output disable
//#define                PWM5_P03_OUTPUT_DISABLE                PIOCON0&=0xDF        //P0.3 as PWM5
//#define                PWM4_P01_OUTPUT_DISABLE                PIOCON0&=0xEF        //P0.1 as PWM4 output disable
//#define                PWM3_P04_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xF7;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P0.4 as PWM3 output disable
//#define                PWM3_P00_OUTPUT_DISABLE                PIOCON0&=0xF7        //P0.0 as PWM3
//#define                PWM2_P05_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xFB;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.0 as PWM2 output disable
//#define                PWM2_P10_OUTPUT_DISABLE                PIOCON0&=0xFB        //P1.0 as PWM2
//#define                PWM1_P14_OUTPUT_DISABLE                BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;SFRS|=0x01;PIOCON1&=0xFD;TA=0xAA;TA=0x55;SFRS&=0xFE;EA=BIT_TMP                                //P1.4 as PWM1 output disable
//#define                PWM1_P11_OUTPUT_DISABLE                PIOCON0&=0xFD        //P1.1 as PWM1
//#define                PWM0_P12_OUTPUT_DISABLE                PIOCON0&=0xFE        //P1.2 as PWM0 output disable
//#define         ALL_PWM_OUTPUT_DISABLE                PIOCON0=0x00;PIOCON1=0x00
////--------- PWM I/O Polarity Control ---------------------------
//#define                PWM5_OUTPUT_INVERSE                        PNP|=0x20
//#define                PWM4_OUTPUT_INVERSE                        PNP|=0x10
//#define                PWM3_OUTPUT_INVERSE                        PNP|=0x08
//#define                PWM2_OUTPUT_INVERSE                        PNP|=0x04
//#define                PWM1_OUTPUT_INVERSE                        PNP|=0x02
//#define                PWM0_OUTPUT_INVERSE                        PNP|=0x01
//#define                PWM_OUTPUT_ALL_INVERSE        PNP=0xFF
//#define                PWM5_OUTPUT_NORMAL                        PNP&=0xDF
//#define                PWM4_OUTPUT_NORMAL                        PNP&=0xEF
//#define                PWM3_OUTPUT_NORMAL                        PNP&=0xF7
//#define                PWM2_OUTPUT_NORMAL                        PNP&=0xFB
//#define                PWM1_OUTPUT_NORMAL                        PNP&=0xFD
//#define                PWM0_OUTPUT_NORMAL                        PNP&=0xFE
//#define                PWM_OUTPUT_ALL_NORMAL                PNP=0x00
////--------- PWM type define ------------------------------------
//#define                PWM_EDGE_TYPE                                                PWMCON1&=~SET_BIT4
//#define                PWM_CENTER_TYPE                                        PWMCON1|=SET_BIT4
////--------- PWM mode define ------------------------------------
//#define                PWM_IMDEPENDENT_MODE                PWMCON1&=0x3F
//#define                PWM_COMPLEMENTARY_MODE        PWMCON1|=0x40;PWMCON1&=0x7F
//#define                PWM_SYNCHRONIZED_MODE                PWMCON1|=0x80;PWMCON1&=0xBF
//#define         PWM_GP_MODE_ENABLE                        PWMCON1|=0x20
//#define                PWM_GP_MODE_DISABLE                        PWMCON1&=0xDF
////--------- PMW interrupt setting ------------------------------
//#define                PWM_FALLING_INT                                        PWMCON0&=0xF3
//#define                PWM_RISING_INT                                        PWMCON0|=0x04;PWMCON0&=0xF7
//#define                PWM_CENTRAL_POINT_INT                PWMCON0|=0x08;PWMCON0&=0xFB
//#define                PWM_PERIOD_END_INT                        PWMCON0|=0x0C
////--------- PWM interrupt pin select ---------------------------
//#define                PWM_INT_PWM0                                                PWMCON0&=0xFC
//#define                PWM_INT_PWM2                                                PWMCON0|=0x01;PWMCON0&=0xFD
//#define                PWM_INT_PWM4                                                PWMCON0|=0x02;PWMCON0&=0xFE
//#define                PWM_INT_PMW6                                                PWMCON0|=0x03
////--------- PWM Dead time setting ------------------------------
//#define         PWM45_DEADTIME_ENABLE                        BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;PDTEN|=0x04;EA=BIT_TMP
//#define         PWM34_DEADTIME_ENABLE                        BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;PDTEN|=0x02;EA=BIT_TMP
//#define         PWM01_DEADTIME_ENABLE                        BIT_TMP=EA;EA=0;TA=0xAA;TA=0x55;PDTEN|=0x01;EA=BIT_TMP
#endif
void PWM_DEAD_TIME_VALUE(UINT16        DeadTimeData)
        UINT8 deadtmphigh,deadtmplow;
        deadtmplow = DeadTimeData;
        deadtmphigh = DeadTimeData>>8;
        BIT_TMP = EA;
        if (deadtmphigh==0x01)
                EA = 0;
                TA = 0xAA;
                TA = 0x55;
                PDTEN|=0x10;
        TA = 0xAA;
        TA = 0x55;
        PDTCNT = deadtmplow;
        EA = BIT_TMP;
//------------------- PWM Define End ------------------------------
*    Main function
*                 PWM4 P0.5 simple output a 2.7KHz 1/4high duty signal
void main(void)
    Set_All_GPIO_Quasi_Mode;
        PWM frequency         = Fpwm/((PWMPH,PWMPL)+1) = (16MHz/8)/(0x7CF+1) = 1KHz (1ms)
        PWM4 high duty         = PWM4H,PWM4L = 0x01CF = 1/4 PWM period
        PWM0 high duty         = PWM0H,PMW0L = 0x03CF = 1/2 PWM period
        Dead time                         = 0x1FF <PDTEN.4+PDTCNT[7:0]>/Fsys = 0x1FF/Fsys = 512/16000000 = 32 us (max value)
                PWM0_P12_OUTPUT_ENABLE;
                PWM1_P11_OUTPUT_ENABLE;
                PWM4_P01_OUTPUT_ENABLE;
                PWM5_P15_OUTPUT_ENABLE;
                PWM_COMPLEMENTARY_MODE;                                        //Only this mode support deat time function
                PWM_CLOCK_DIV_8;
                PWMPH = 0x07;
                PWMPL = 0xCF;
                PWM0H = 0x03;
                PWM0L = 0xCF;
                set_SFRPAGE;        // PWM4 and PWM5 duty value need set SFPPAGE 1
                PWM4H = 0x01;
                PWM4L = 0xCF;
                clr_SFRPAGE;
                PWM01_DEADTIME_ENABLE;
                PWM45_DEADTIME_ENABLE;
                PWM_DEAD_TIME_VALUE(0x1FF);                        //value never over 0x1FF
//Please always setting Dead time if needed before PWM run.
    set_LOAD;
    set_PWMRUN;
                while(1);
huangcunxiake|  楼主 | 2021-9-26 22:16 | 只看该作者
自从用了库函数,现在看寄存器操作都不知道咋回来 。
598330983| | 2021-9-26 22:40 | 只看该作者
挺好的,这个系列很火。用的人很多。
