[技术问答] 关于IAR中使用官方例程报__stdout 和 __stdin was declared 问题
4689|2
 楼主| 海滨消消 发表于 2021-9-27 15:19 | 显示全部楼层 |阅读模式
IAR, COM, ev, sd, TE
Error[Pe235]: variable "__stdout" was declared with a never-completed type
Error[Pe235]: variable "__stdin" was declared with a never-completed type
编绎器IAR V8.30.1,在使用新唐NM1200官方例程时,产生上述报错问题,请各位大神指教。
classroom 发表于 2022-2-21 17:24 | 显示全部楼层
//#if!(defined(ICCARM (VER >= 6010000))
struct FILE l int handle; /* Add whatever you need here * };
//#endif
请屏蔽这两行代码
laocuo1142 发表于 2022-2-21 17:24 | 显示全部楼层
可以参考https://devzone.nordicsemi.com/f/nordic-q-a/21960/iar-8-11---issue-when-compiling-ble_app_uart-example
